RS 125 WONT START :x
jez125
PostPosted: 19:20 - 16 Jan 2012    Post subject: RS 125 WONT START :x Reply with quote
hi
tried the suggestions people said
compression 137psi
kill switch off
carb jets and carb clean
new spark plug
Poured fuel down barrel but still will not start
spark plug is clean with fuel on it
spark is very good
ive cleaned it and tried firing it up just wont have it
i was suppose to be selling it but i carnt now as it isn't running uhhh any more suggestions please
jez125
PostPosted: 19:24 - 16 Jan 2012    Post subject: hi Reply with quote
Dont know if this helps but it has a plastic smell when trying to start it
UrbanRacer
PostPosted: 19:41 - 16 Jan 2012    Post subject: Re: hi Reply with quote
An electrical short, check all the wiring. don't keep trying to start it or the bike will burst into flames.
jez125
PostPosted: 19:44 - 16 Jan 2012    Post subject: hi Reply with quote
kk i will try and trace the wiring back but even with a good spark and fuel down the barrel would this stop the bike from running?
UrbanRacer
PostPosted: 19:49 - 16 Jan 2012    Post subject: Reply with quote
Is the starter turning the engine?
jez125
PostPosted: 19:51 - 16 Jan 2012    Post subject: hi Reply with quote
yeah the engine is turning over but just not firing
starter motor fine and starter gear working
MickC
PostPosted: 20:05 - 16 Jan 2012    Post subject: Reply with quote
First you need to pin down where the smell is coming from. Look for bubbling of blistering on the electrical components and wiring. If something in the ignition circuit was/is shorting it could cause the ignition to fire at the wrong time, or it could be the timing is out or a combination of both.
But find the source of that smell first.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
jez125
PostPosted: 20:09 - 16 Jan 2012    Post subject: hi Reply with quote
hi smell is coming from the carb as ive take the air box off to take a look and when i twist the throttle to fully open the electric dips
jez125
PostPosted: 20:11 - 16 Jan 2012    Post subject: hi Reply with quote
so at the moment ive got the battery on charge as it is properly running low to trying to start the bike
jez125
PostPosted: 22:01 - 16 Jan 2012    Post subject: hi Reply with quote
right found out a bit more the earth wire coming of the battery is getting really hot and started to bubble so you are right so far as its an electrical what is the best option now
bikenut
PostPosted: 14:17 - 17 Jan 2012    Post subject: plastic smell Reply with quote
:karma: jez125 3 posts up you say that lights dip when throttle opened wide..................is throttle cable sawing its way through a wire?????????? or something like that possibly.......long shot but its your bike.........FIND ELECTRICAL PROBLEM!!!!!!!!!!!!!!
Robby
Dirty Old Man
PostPosted: 14:41 - 17 Jan 2012    Post subject: Reply with quote
If the negative (black) lead is getting hot, then it is trying to carry more current than it is rated for. Assuming this is a thick wire, that's an awful lot of current.
Start off by checking for corrosion on the battery terminals, and where the negative battery lead mounts onto the frame or starter solenoid.
If you had a short somewhere you would be blowing fuses. This suggests a short, an internally broken cable, very serious corrosion, or a loose connector somewhere between the negative lead and the fusebox, or on a part that isn't protected by a fuse (possible starter solenoid connection).
A bodge I have used in the past where I suspect that the wiring is corroded somewhere, is simply to run an additional earth wire from the frame back to battery negative terminal.
Teflon-Mike
tl;dr
PostPosted: 16:10 - 17 Jan 2012    Post subject: Reply with quote
To isolate a possibility of the starter motor shorting, try bump starting it; unless the black battery wire gets hot as soon as you connect it.
My best guess, is that the starter motor circuit is earthing out' could be that the brushes or even the windings in the starter have 'gone', or you have a loose starter lead, or something (Throttle cable?) earthinng the starter terminal either at the starter end or the solenoiod.
Other notion I have is something to do with the power valve servo; if the power-valve has siezed/jammed, and that is sucking loads of amps, trying to do it's 'pre-start-swing' between travel stops.
However; if the bike can be 'Bumped', so you dont have the starter motor dropping the battery terminal voltage or letting another electrical gremlin loose; gives you an idea where to start hunting.
PostPosted: 16:27 - 17 Jan 2012    Post subject: Reply with quote
The starter motor doesn't have a separate earth wire. That is the main feed to the starter motor. I would suspect either the starter motor has shorted out internally, the feed wire has chaffed through and is shorting on something or that where the wire connects to the starter the nut it attaches to is shorting to the body of the starter motor.
The power valve doesn't have a servo, rather a solonoid that only draws a decent amount of power for a max of a couple of seconds before the control unit limits the power (ie, it is pulling against a spring, decent power to pull against the spring to open the valve and then less required to keep it open). They stick fairly often and won't cause a major problem (beyond trying to unstick them).
The last post was made 14 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 82.03 Kb
