Aqua Physiotherapy
maria383
PostPosted: 20:01 - 16 Jan 2012    Post subject: Aqua Physiotherapy Reply with quote
After months of physio for my dodgy shoulder, and as a last resort before being operated on, I was told today that I'm being referred for aqua therapy. My physio person said that it's a small pool and the physiotherapist will be in the water with me on a 1:1 basis.
Has anyone ever tried it? Did it help? I can't say I've ever heard of it before...
Happiness is realising you have another gear left
Clanger
Stirrer
PostPosted: 20:21 - 16 Jan 2012    Post subject: Reply with quote
Yes...it's usually called Hydrotherapy. I had it to strengthen my leg / foot /ankle again after it got squashed in an accident. And once they thought it was strong enough, they made me walk...and boy did my scream echo around the pool area!!! Laughing
PostPosted: 20:42 - 16 Jan 2012    Post subject: Reply with quote
Didn't like it Laughing
Had to use floatation stuff though...as I had no use of my legs Cool
maria383
PostPosted: 21:17 - 16 Jan 2012    Post subject: Reply with quote
Well I knew you wouldn't like it!
Do they really go in the water with you?
PostPosted: 21:24 - 16 Jan 2012    Post subject: Reply with quote
Yes, I had a guy bending and straightening my legs.
Also had to roll side to side lol...was funny. Looked like a proper mentalist!
swampy
PostPosted: 21:31 - 16 Jan 2012    Post subject: Reply with quote
Yep, and that water is fucking warm... I had to do it years ago with a client, and had sunburned my back before... the prickly heat I had is not a pleasant memory...
Its used as the water to some extent takes the added stress of your limb fighting against gravity out of the question (don't under estimate the power of gravity.. I've seen it really fuck some people up Wink )
TUG
PostPosted: 22:24 - 16 Jan 2012    Post subject: Reply with quote
Whats wrong with your shoulder?
Only time i went in the pool for hydrotherapy was after my nerve swap in rehab, was alright, not 1:1 though.
Haz ER-5, innit!
calyx
PostPosted: 00:49 - 17 Jan 2012    Post subject: Re: Aqua Physiotherapy Reply with quote
Fucking perverts.
Boris - London
maria383
PostPosted: 17:57 - 17 Jan 2012    Post subject: Reply with quote
Calyx.... I thought it seemed a bit pervy!
Bike vs bus. I broke the collar bone, dislocated the shoulder and fractured the ball and socket joint.
Overall it's a bit messed up and is causing pain in my neck and back as well.
The thought of moving my arm through water with the resistance pulling against it makes me cringe Sick
Paivi
PostPosted: 19:11 - 17 Jan 2012    Post subject: Reply with quote
How do you expect them to manipulate your shoulder if they don't get into the pool with you? It's not a bathtub, you know, but a pool of several meters in diameter. And you'll both wear bathing suits. Rolling Eyes
PostPosted: 19:13 - 17 Jan 2012    Post subject: Reply with quote
I think you might just need to get a grip.
Paivi
PostPosted: 19:19 - 17 Jan 2012    Post subject: Reply with quote
She can't, can she, until the shoulder's healed. At the moment, we're looking at surgery, as that's got to be better than jumping into a pool with a hydrotherapist...
TUG
PostPosted: 23:57 - 17 Jan 2012    Post subject: Reply with quote
Sounds painful, mine was nerve damage, when ever i hear the words shoulder, bike accident its all i ever think of, if its pain thats holding you back, turn the pain into pleasure, it's what i did to get through the barrier. Might sound like bull shit but it does actually work.
Haz ER-5, innit!
calyx
PostPosted: 02:17 - 18 Jan 2012    Post subject: Reply with quote
The reason they referred for hydro therapy is because it is cheaper than the surgery. This is how it works;
Hospital's and therapist's budgets are different. So they just keep sending people to each other. In the meantime you may get used to the pain and live with it. Which will save them shed loads of money.
This usually costs NHS more but every single department hits their targets.
If a consultant doctor can't tell if a dislocated shoulder would heal itself or not by looking at a m.r. result then who the f would? Fucking muppets.
Boris - London
swampy
PostPosted: 13:16 - 18 Jan 2012    Post subject: Reply with quote
Well it doesn't work quite like that... Hospitals have an overall budget, and this is split into departmental budgets depending on the needs of the local populace (in theory).
The therapists (in this case I would guess) work for the hospital, and their service has been commissioned to provide x amount of contacts over a year. If they don't make that number of contacts, their budget is reduced the next year. It is important to remember though, that they are dependent on referrals from other departments (or GP) i.e. they cant tout for business, so hitting targets is somewhat irrelevant, as there is nothing the therapists can do about it if they don't.
In terms of reasons for treatment, there are several good clinical reasons for referring to physio prior to surgery. Primary reason for this being that it is safer, less risky and often more beneficial. Cost is a factor, but its the tax payers money at the end of the day.. if you would prefer to spend more money than necessary for the same outcome, then fill your boots.
Shoulders are a pain in the ass. I bollocksed mine 5 years ago in an off in a very similar way to you. Physio worked for me, and although I still get the odd twinge, its not at all bad.
Shoulders aren't really a ball and socket joint in the same way as a hip. The 'socket is formed by the scapula, but is also stabilised by the clavicle at the acromioclavicular joint. There are also a shit load of muscles and tendons that stabilise the joint. Given the OP also has neck and back pain, it would suggest that it is these stabilising structures that have been stretched or torn. In this instance, clinically, physio is absolutely the right way to start as it works in the majority of people, reduces pain, improves function and costs the general public less...
You need to take your tin hat off about the reasons most clinical decisions are taken. In practice we are encouraged to not spend money unnecessarily but on the ground, clinical need will always outweigh this if necessary. We do not spend all day sitting on our arses not seeing patients thinking of how much money we're saving, and I've never in 5 years not given a patient what they need based on funding. What they think they need might be different, but then they can go and train for 4 years and then argue with me.
The last post was made 14 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 88.37 Kb
