| 1995dj |
 1995dj Derestricted Danger
| andy_uk |
 andy_uk World Chat Champion
| pepperami |
 pepperami Super Spammer
| st3v3 |
 st3v3 Super Spammer
| 1995dj |
| Pete. |
 Pete. Super Spammer
 Posted: 22:34 - 15 Jan 2012 Post subject: |
It's firing out of the carb, so I'd re-check both the disc timing and the ignition timing. I'd also check the piston correctly covering the ports at the ends of it's stroke.
These are simple. reliable engines, so if it's not starting with good compression and a spark something fundamental is wrong. ____________________ a.k.a 'Geri'
| Ichy |
 Ichy World Chat Champion
| 1995dj |
| Ichy |
 Posted: 12:52 - 16 Jan 2012 Post subject: |
You need to do a compression test first then try easy start. Virtually anything will run on it. If it doesn't fire then there is a good chance it's an electrical issue. If it runs then it's probably the carburettor. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Vincent |
 Vincent Banned
| bikenut |
 bikenut World Chat Champion
| 1995dj |
| Pete. |
 Pete. Super Spammer
 Posted: 00:04 - 17 Jan 2012 Post subject: |
The bag should not be blown back out. Does it come out quite smartly or just a feeble effort? ____________________ a.k.a 'Geri'
| bikenut |
| Vincent |
 Vincent Banned
| 1995dj |
| Vincent |
 Vincent Banned
| Pete. |
 Pete. Super Spammer
 Posted: 19:42 - 17 Jan 2012 Post subject: |
The crank seals go with the grooved face inwards, flat face outwards. If you have two grooved faces, poke around in the grooves and find where the spring is - that face goes inwards. ____________________ a.k.a 'Geri'
| bikenut |
| 1995dj |
| bikenut |
 Posted: 11:11 - 20 Jan 2012 Post subject: ke100 non starter |
so with plug in or out you get spark ( enough to trigger neon strobe or battery powered strobe with clip on sensor ), weakish spark??
with plug in no sign of life with exhaust off, even when primed with petrol?
wire from condenser to ht?
you mean wire from condenser/cb points to coil lt connection?
coil earthed?( spark for strobe so somethin ht wise )
so either weak spark insufficient to ignite fresh petrol, ht failure at k/start speeds and pressures ( inside cyl combustion space ), no fuel in combustion space ( wet plug? proves fuel gettin to plug ), spark happenin at wrong time??????? or combination of above?
and youve tried with exhaust off, yes?
eliminate the possibility that its not an ign kill problem when kicking over, or bad contact or something just as silly.
has frame been painted with now poor earths perhaps?
make safe any try pushing with plug out, spark better at higher engine speeds ( one would expect so ), try pushin with all systems go and exhaust off, better spark may allow eng to burst into life.
what year your bike need to check summut on cmnsl? feedback please. |
| truslack |
 truslack World Chat Champion
| bikenut |
| truslack |
 Posted: 11:53 - 20 Jan 2012 Post subject: Re: ke100 |
| bikenut |
The last post was made 14 years, 25 days ago. Instead of replying here, would creating a new thread be more useful? |
