New Chain and Sprocket Kit
Mrjoolz
PostPosted: 16:38 - 17 Jan 2012    Post subject: New Chain and Sprocket Kit Reply with quote
Hi All,
I am after a new chain and sprocket kit for my E4 ZZR600. I have looked on fleabay and other sites, but have been told that I should get a kit with DID chain and JT Sprockets !!
Is there such a kit and who does it, or do I have to buy separately ?
wemoto do a chain and sprocket kit
https://www.wemoto.com/bikes/Kawasaki/ZZR_600_ZX_600_E4-E5/96-97/picture/Chain_DID_VX_X-Ring_Premium_Gold_&_Black/
should this be OK, or should I get chain from them and sprockets elsewhere.
many thanks
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
Quote Me Happy
PostPosted: 16:54 - 17 Jan 2012    Post subject: Reply with quote
Have a look on B&C Express as well, have bought from there in the past.
If you're set on that combination then you might have to buy separately.
Mrjoolz
PostPosted: 17:56 - 17 Jan 2012    Post subject: Reply with quote
Not set on that, its just that I was told that JT sprockets are better. But I just want to make sure I get a chain that will last as I commute 80 miles each day to and from work. Surprised
thanks though, I'll take a look
Mikey3
PostPosted: 18:05 - 17 Jan 2012    Post subject: Reply with quote
There's plenty of makes and manufacturers out there that will give you substantial functioning over 80 two and from work + more.
As long as its not some cheap rubbish, the correct maintenance, i.e adjustment and lubrication regularly will do the job perfectly, possibly saving you a load of money on top brands Smile
WeMoto is generally fine for that Smile.
HTH
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
Fizzer Thou
PostPosted: 19:04 - 17 Jan 2012    Post subject: Reply with quote
I bought a JT rear sprocket from B&C and I thought that it was too cheap and not particularly well machined.So I bought a https://www.supersprox.com/uk/categories.php rear and a Renthal front together with a DID chain and have used it for years on my Exup1000,covering many miles with just good maintenance and hardly any adjustment.Granted I do not use it for commuting but the equivalent is a 900 mile ride to the South of France in one hit with no problems from my drive line.
Always have a 'Plan B'
Mrjoolz
PostPosted: 11:11 - 18 Jan 2012    Post subject: Reply with quote
wemoto is probably where I will end up getting it from. Chain is adjusted as of Sunday (gone) and its at the correct 25-30mm slack at tightest point but when rotating wheel it then goes to about 45mm, so chain has probably had it now.
Probably the original chain on it. I've done almost as many miles on it in 7 months, as it had on it when I bought it.
Smile
The last post was made 14 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 48.24 Kb
