Water cracking windscreen
fatpies
PostPosted: 14:03 - 18 Jan 2012    Post subject: Water cracking windscreen Reply with quote
Yesterday was cold, and the wind screen on the car had frozen over. Cue me going inside getting a couple of warm cups of water and throwing it on the screen, using the wipers and drove off.
All while being told by the fat dole chav next door on disability who is fitter than I am, who drives a Nissan Qashqai or something on his disability mobility allowance.
Oh you can't do that you'll crack your screen.
Every winter I get told this and yet I have never yet cracked a screen on a car with lukewarm water.
So is it sn urban legend or are there really some people out there who will use boiling hot water?
Granted one chap from Finland told me to be careful, only because in Finland it would freeze instantly and instead of a small layer of ice it would turn into a big blob so the tempreture was important.
angryjonny
PostPosted: 14:07 - 18 Jan 2012    Post subject: Reply with quote
Once upon a time it was true. Glass technology has come a long way since then though. It's still a risk but a much smaller risk than it used to be.
Blackwolf
Burgerfist
Its not the water, Its the sudden change of temperatures in the glass. Stuff thats cold, usually shrinks, Hot things usually expand.
So its the sudden change between the temps. It proberly happens where theres already a crack or chip.
Also, only use your wipers if all the ice is off them, they usually freeze in the ice and when you use them to clear your screen, you run the risk of them ripping out of it causing damage to the wiper blade.
PostPosted: 14:10 - 18 Jan 2012    Post subject: Reply with quote
Yep, chance of it happening from the sudden change in temperature. But if you are not using hot water the change in temp of the glass should be minimal and is unlikely to do anything nasty.
It is something I do as well when it is frozen up outside.
Just don't get it around the door seals if you do it on the side windows. Having the doors frozen shut is a pain Laughing .
pits
PostPosted: 14:31 - 18 Jan 2012    Post subject: Reply with quote
Use lukewarm at most water and it should be fine, glass does not like extreme temp changes as glass is a fairly weird substance it is a solid state liquid sorta kinda not really just about could be considered by some.
But luke warm water is fine, boiling hot asking for trouble, a mate of mine last year was cleaning out a large jar in the sink, washed it with cold water, some of the stuff in there wouldn't shift with cold water, so he boiled kettle and poured hot water in because, it never happens to your right? Wink Glass exploded, scolding hot water down his front and he had to Hulk out of his shirt.
Kickstart, when I was younger I had an old Seat Toledo, and the doors were very thin at the top and the seals were very tight, I applied some rainX one evening in winter, and thought whilst I am at it, I will quickly wash it, washed it, left it to dry, went into unit sat on PC for 30 minutes come back out, car was a block of ice.
Door locks frozen
Doors frozen shut
Windscreen solid with ice,
The whole car was an ice cube.
Took me about 2 hours with warm water and a hot air gun to get drivers door open, wont be doing that again Thumbs Up
mistergixer
PostPosted: 14:50 - 18 Jan 2012    Post subject: Reply with quote
My old Mk2 MR2 was terrible for the doors freezing shut. It had no frame over the top of the glass, so any moisture would freeze the window glass to the body.
I always kept a can of de-icer in the boot so I could spray it onto the tops of the windows, then after a bit of judicious wiggling of the door it would actually pop open.
Space Monkey #7
MattJ
PostPosted: 14:52 - 18 Jan 2012    Post subject: Reply with quote
What the fuck does that mean? Laughing
As others have said though, the quick change in temp can sometimes crack glass but it's unlikely to do that to a windscreen because of how strong they are.
angryjonny
PostPosted: 15:00 - 18 Jan 2012    Post subject: Reply with quote
My old 325i coupe had the same style frameless windows, but it used to drop them half an inch when you opened the door and raise them half an inch when you closed it again. So if they didn't unstick themselves from the body you really were frozen up.
PostPosted: 16:27 - 18 Jan 2012    Post subject: Re: Water cracking windscreen Reply with quote
fatpies wrote:
fat dole chav next door on disability who is fitter than I am, who drives a Nissan Qashqai or something on his disability mobility allowance wrote:
"When?" might be an appropriate reply.
Can't remember ever not doing it, using tepid room temperature water, can't remember ever having a problem or hearing first hand of anyone who has.
PostPosted: 16:38 - 18 Jan 2012    Post subject: Reply with quote
I tend to just scrape mine, only takes two minutes anyway.
However on frozen doors I prefer to use cold water. Works for me. Thumbs Up
dodgydog
PostPosted: 18:03 - 18 Jan 2012    Post subject: Reply with quote
Warm water on the screen, (never had a problem)
Smear of ptfe spray around the door seals.
Used to melt a little vaseline and work that into the door locks too, never had one froze up.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
flat spot
PostPosted: 18:06 - 18 Jan 2012    Post subject: Reply with quote
Just use cold water then no risk of cracking the screen.
My Calibra had framelesss windows and a handle that was difficult to hold tightly. The amount of times I was frozen out of it wasn't funny. Oddly the boot button also used to freeze so I couldn't get in it that way either.
PostPosted: 18:14 - 18 Jan 2012    Post subject: Reply with quote
Managed to break the door handle off one car a couple of years ago when it was frozen shut. And the door handles on the X type feel very weak and I wouldn't want to pull on them too hard.
lukamon
PostPosted: 18:20 - 18 Jan 2012    Post subject: Reply with quote
HOT TIP: For all those with pillarless doors, (even those with normal doors this helps) spray silicone grease or rub in the tube type stuff on the rubber seals against the glass and infact any seals; this repels water and almost completely prevents freezing up.
also prolongs the life of the seals by p reventing them drying out HTH Thumbs Up
killa wrote: Im an ass man myself
doggone
PostPosted: 18:22 - 18 Jan 2012    Post subject: Reply with quote
If there was already a slight flaw or chip it might turn into a crack from a thermal shock just like going over a bump.
The autoglass advert Rolling Eyes says just turning the car heater on full might crack a frozen screen - seems unlikely as it won't be red hot instantly - but you are only warming a bit in the middle so not total bollocks.
mistergixer
PostPosted: 18:57 - 18 Jan 2012    Post subject: Reply with quote
There was a rather strange case last year of an A3 getting encased in ice in NYC:
https://i.telegraph.co.uk/multimedia/archive/01810/frozen-car_1810560i.jpg
When the owner eventually got into the car and got it running (after chipping off the ice with a hammer and screwdriver), the temperature change shattered a hole in the rear window.
https://www.nypost.com/rw/nypost/2011/01/25/news/photos_stories/012411Ice13BS104928--300x300.jpg
Space Monkey #7
DrDonnyBrago
PostPosted: 19:16 - 18 Jan 2012    Post subject: Re: Water cracking windscreen Reply with quote
I do it.
I'm sure they do crack albeit rarely but deicer is expensive and I have windscreen cover Wink .
Also, wtf happened to the frozen splooge covered car above? A fire hydrant blow up or something?
mistergixer
PostPosted: 19:42 - 18 Jan 2012    Post subject: Re: Water cracking windscreen Reply with quote
A water pipe burst underneath it, then the car sat there for 48hrs with passing cars splashing water over it.
Space Monkey #7
Kwaks
I'm not a fast rider
PostPosted: 19:53 - 18 Jan 2012    Post subject: Reply with quote
Yeah glass is technically a liquid, as it flows, most commonly seem in old church windows where the glass is thicker at the bottom.
www.cliqueycuntsmcc.co.uk
Suntan Sid
PostPosted: 20:16 - 18 Jan 2012    Post subject: Reply with quote
Luke warm, pffft!
I've got to say, in the past I've used, very hot water, never did any damage as far as I could see!
J4mes
PostPosted: 20:21 - 18 Jan 2012    Post subject: Reply with quote
I had this happen to me in a transit connect, which had a small chip in the bottom of the windscreen - it was frozen with a bit of snow on it, I started it up and left it to run for a bit with the heater on full chat on the demist setting.
Came back to the van 10 minutes later, put my seatbelt in, filled in the logbook and watched the screen crack from one side to the other!
Snodvan
PostPosted: 20:43 - 18 Jan 2012    Post subject: Reply with quote
I used to have a VW Dormobile - large area of glass. I soon became used to using warm water to clear the windows. With VW you can TOTALLY FORGET any idea of a "heater" helping clear a window. Heater in a VW Dormobile - don't make me laugh.
Like the OP the guy over the road (big Tranny van and scrape - scrape - scrape job) was always telling me I would crack my windows. NEVER happened in 40 years.
What can be a bugger if it is really cold is that the ice re-forms. What I do is clear each window at a time with warm water in the small household watering can then use a blade wiper to clear as much water as poss from the cleared window. My job on cold mornings - so I can send the wife out to work. I have retired so fair I guess.
Snod
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
DrDonnyBrago
PostPosted: 21:31 - 18 Jan 2012    Post subject: Reply with quote
Incorrect.
Glass is an amporhous solid, similar to, but NOT a liquid.
Glass panes being thicker at the bottom is NOT because they have flowed as a liquid. The reason they are thicker at the bottom is because of the way glass was made. Nowadays we float molten glass on a bath of molten metal which gives perfectly flat and even glass. In the past a ball of molten glass was spun into a big circle and cut into sheets.
Spinning out glass results in a gradual change in thickness from the centre to the edge. A good glazier would fit the thick, heavy part of the sheet at the bottom, hence it LOOKS like it has flowed, it has not. We do not see any flowing in Roman glass despite it being 1000s of years old, you can also see examples where the glazier has done it the other way round and fitted the heavy, thicker part at the top.
The amorphous solid nature of glass means it does flow, but it would take over 100,000,000,000,000,000,000,000,000,000,000 (1 with 32 zeros after it) years for a pane of glass to flow and be a mm or two thicker at the bottom. The universe is less than 15,000,000,000 years old.
A common urban legend, but not true.
Raffles
PostPosted: 21:59 - 18 Jan 2012    Post subject: Reply with quote
If glass is a liquid, why isn't it sold in litres?
Acemastr
PostPosted: 23:21 - 18 Jan 2012    Post subject: Reply with quote
I don't do it on the BMW as it's got so many stone chips it's unreal, but then I also don't put my rear windscreen demister 'lines' on as soon as i get in the car as i've seen a few cases of rear windows imploding because of it.
Anal huh? Very Happy
2016 Toyota Tacoma Limited
The last post was made 14 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 133.53 Kb
