Is this normal?
kevotore75
PostPosted: 17:12 - 18 Jan 2012    Post subject: Is this normal? Reply with quote
Hi I have a Honda CG 125.. When the bike is on idle thehead and tail lights are very dim, however when i rev the engine the lights are bright, Is thia normal?.. Its a 2002 model m1, also over last few days the electric start has turned over but not fast enough to start bike up,..
shippy
PostPosted: 17:36 - 18 Jan 2012    Post subject: Re: Is this normal? Reply with quote
I'm pretty sure it is normal, it does it as well on my bike and it's only a few months old Smile
doggone
PostPosted: 17:42 - 18 Jan 2012    Post subject: Reply with quote
It shows your charging system is all OK anyhow.
MickC
PostPosted: 17:50 - 18 Jan 2012    Post subject: Reply with quote
On my 900 they are slightly dimmer on tick-over, nothing to worry about (unless it starts getting dimmer and dimmer)
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
tomh
PostPosted: 18:00 - 18 Jan 2012    Post subject: Reply with quote
This is completely normal, the cg headlights are powered directly from the alternator instead of from the battery like most modern bikes.
When at idle the alternator is not generating much power so therefore the bulbs are dim.
Also when your starting the bike try giving it a bit of throttle at the same time if your not already doing so and it should start straight away.
kevotore75
PostPosted: 22:23 - 18 Jan 2012    Post subject: Reply with quote
Thanks i'll see how it goes then!!
hornetmike
PostPosted: 22:28 - 18 Jan 2012    Post subject: Reply with quote
If its an older CG this normal.
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
Walloper
PostPosted: 23:12 - 18 Jan 2012    Post subject: Re: Is this normal? Reply with quote
Batteries are very susceptible to cold. During cold or frosty mornings not only will the fuel be more difficult to ignite (due to evaporation at lower temperatures) the battery will not be able to put out the normal maximum amps (power).
It should really be capable of starting even when iced up.
I think you may have a battery on the way out.
That is a normal sign of a battery at the end of it's working life.
I think Halfrauds sell the correct battery for under £40 including the Acid Charge (Six little shampoo bottles of Sulphuric Acid solution) You pour the acid in yourself and let the battery sit for a couple of hours to stabilize. You can fit it in the bike though but do not switch the key on.
The battery will have instructions on it.
As said, the CG 125 needs a good bit of throttle on initial start.
The choke has two positions ONLY USE THE FULL ON POSITION.
Choke full on.
Open the throttle about 20% of maximum.
Hit the start button.
It should go after the engine turns over two or three times.
Hold the throttle open for a few moments then ease it towards idle.
You will learn when the engine can hold idle with choke on.
When the engine has ran for a few minutes the choke can be switched to OFF.
Or ride off and stop a few minutes later to switch off the choke.
The choke is a bsatard to get to when sat on the bike.
PostPosted: 23:44 - 18 Jan 2012    Post subject: Reply with quote
hahadumball wrote:
Pretty sure its a 2010 cg i may be wrong.
You are wrong, they stopped making them ages ago Laughing
Okeydokey
PostPosted: 01:42 - 19 Jan 2012    Post subject: Reply with quote
Its normal
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it in a fruitsalad!
YB100 v. Ford Sierra (1982 I came 2nd place) Honda H100S (Currently 0 - 0) CX500 Cafe project (me 1 - wife 0.... maybe!)
truslack
PostPosted: 09:34 - 19 Jan 2012    Post subject: Reply with quote
It also says 2002 model in the first post Laughing
The last post was made 14 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 77.94 Kb
