Backfire/cough back through carbs, i think..
Mikey3
PostPosted: 14:35 - 19 Jan 2012    Post subject: Backfire/cough back through carbs, i think.. Reply with quote
I've asked before but i got spammed by a friend Laughing
My SV when cold, sometimes coughs back up through the carb, or it sounds like it at least, or misfires, I don't know.
It makes a cough sound, which sounds like its coming back up through the carb or airbox, of which i'm not too sure either.
revs drop, and pick up again next cycle.
It does this once or twice.
I'd like to know what it is, it isn't a bother, i'd just like to know.
Thanks in advance
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
J8Macbeth
PostPosted: 18:21 - 19 Jan 2012    Post subject: Reply with quote
My friend's XT-350 does this too, and my TTR-125 has done it before. I have recently had to clean out the main jet on mine, as it wasn't running right, and since then I haven't had that problem. My friend's bike does the same, and the valve is definitely open at the wrong time, because we've seen a flame come back up the air intake when the cover has been off. I think the problem could be dirt in the main jet, or somewhere in the carburetter.
Hope this helps,
Josh
Mikey3
PostPosted: 18:28 - 19 Jan 2012    Post subject: Reply with quote
thanks mate,
I had a suspicion it might have been something to do with valve overlap, too much of course, or something like that.
My cam chains are slightly slack and can sometimes rattle a little, so that might have something to do with it.
Its fine once its warmed up, and it is only on occasion
Thanks
Mike
'04 Yamaha WR450F
MickC
PostPosted: 18:49 - 19 Jan 2012    Post subject: Reply with quote
Check valve clearances and timing. Also make sure the down pipes are bolted firmly to the head. Could also be a float sticking, allowing to much fuel through.
But do that rattly cam chain, you really don't want that going or jumping, it can make a really nasty mess - the sort of nasty mess you used to see in the early 80's slasher/gore movies!!!!!.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Mikey3
PostPosted: 18:54 - 19 Jan 2012    Post subject: Reply with quote
Haha, yeah i'm well aware of getting it done! and the consequences.
Its very common on SV's, mainly the older ones like mine.
Ill check the exhaust and bits too.
thanks
Mike
'04 Yamaha WR450F
The last post was made 14 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 45 Kb
