| johnsmith222 |
 johnsmith222 World Chat Champion
| bwprice100 |
 bwprice100 Borekit Bruiser
 Posted: 14:25 - 20 Jan 2012 Post subject: |
Hi there is enough of a radius on the edge of the bearing to get a blind bearing puller in behind the bearing and then it will slide hammer out.
Always heat the surrounding metal as well.
Brian ____________________ www.eBolt.co.uk www.ToolRoomChucks.co.uk
My bikes 1956 BMW R26 250cc, !981 BMW R80 (was a TIC ex plod), 1994 R100RT, sold my 1981 Yam XS 250 |
| johnsmith222 |
| bwprice100 |
 Posted: 14:38 - 20 Jan 2012 Post subject: |
I have heard some people have had some success in making one from one of those expanding anchor bolts they sell in B+Q a length of thread bar and some nuts (the hexagon type)
Just remember when you are out in the middle of the Kalahari and something breaks, you make a plan and improvise.
| Fizzer Thou |
| johnsmith222 |
 Posted: 15:02 - 20 Jan 2012 Post subject: |
Just realised you can move the inner bit about to get a lip.
Flat screwdriver and a hammer for some "careful persuasion" is the way.
Thanks guys.
https://www.youtube.com/watch?v=1IRBsoeULwA
For anyone reading this and thinking of doing the same. Just be aware you can damage your wheel so be careful.  |
| bwprice100 |
 Posted: 15:16 - 20 Jan 2012 Post subject: |
No substitue for 'Brute force and ignorance' unless it's a bigger hammer  ____________________ www.eBolt.co.uk www.ToolRoomChucks.co.uk
| johnsmith222 |
 Posted: 18:55 - 20 Jan 2012 Post subject: |
Both inner races are SUPPOSED to grip the tube up the middle.
When you tighten everything down in the frame, the whole lot (spindle, nut, wheel spacers, inner races and spacer tube) should be compressed together to act as one solid, stationary piece around which the wheel rotates on the ball bearings.
So clamp it in place, leave the calliper off and give it a spin. It ought to spin and continue spinning through several rotations. If it's rough or stiff, you've done something wrong (most likely deformed a dust shield).
You did drive them in using the outer race yeah? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| johnsmith222 |
The last post was made 14 years, 280 days ago. Instead of replying here, would creating a new thread be more useful? |
