fork spring retainer rusted on solid
skikman
PostPosted: 14:51 - 20 Jan 2012    Post subject: fork spring retainer rusted on solid Reply with quote
hi again folks.im trying to change the fork oil on the old yamaha sr250.at the top of the stanchion the spring is held in with a retainer[like a bung with a lip].held in place with a spring wire[circlip like]that goes into a grove.you are ment to push down on the retainer,release the circlip and the retainer and spring should pop out.when i took off the rubber cap it was all rusty in there.i cleaned and scraped what i could.couln'nt push the retainer so tapped it down a wee bit with hammer and socket.got the clip out but the retainer wont budge.scraped around with wee knife and soaked in wd40 over night twice once compressed under bench.i have scraped and beat it with a dead blow hammer,jumped up and down on it like fuckin zebedee possesses but it wont budge.anyone any ideas?:cursing:
Bezzer
PostPosted: 16:47 - 20 Jan 2012    Post subject: Reply with quote
WD40 is no good, try some PlusGas or diesel on it for a day or so then a bit of heat to make it expand a touch and hopefully break the seal.
skikman
PostPosted: 17:02 - 20 Jan 2012    Post subject: Reply with quote
do i heat up outside of stanchion or in the top? i was thinking of beating it on in with a heavy harmer and socket but afraid it might make it worse
dodgydog
PostPosted: 17:24 - 20 Jan 2012    Post subject: Reply with quote
Jeez that looks well manky, You need to clean it up the best you can, and as suggested, use Plusgas to soak it.
Heat the outside, i.e. the stanchion, to expand it some.
Good luck.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
jjdugen
PostPosted: 18:16 - 20 Jan 2012    Post subject: Reply with quote
Take the forks apart as normal. Undo the retaining bolt at the bottom of the fork and pull the two halves apart (lower and slider). With the forks still under compression this will be a lot easier.
With the spring still in you will need to compress the legs and then relase to shift the seal / bush. If it will part, and I appreciate it will be hard, then its just a tube and a long drift will shift the fork cap.
Ichy
PostPosted: 19:17 - 20 Jan 2012    Post subject: Reply with quote
Just be aware that the fork spring is under that cap. If it does become loose it may well launch itself into whatever is in front of it. Just make sure its not your face.
Stand it up as straight as possible. Fill to the top with diesel. put an old towel or similar over the top and secure the towel around the fork tube, maybe with a jubilee clip. Just leave it for a couple of days.
skikman
PostPosted: 20:32 - 20 Jan 2012    Post subject: Reply with quote
whats the towel for?i was at it just there with a heat gun,still wont budge.i have left it comperssed under the bench with diesel in the top.the top is sitting out a wee bit [to get the diesel in],is that ok?or should i not compress it?
MickC
PostPosted: 21:12 - 20 Jan 2012    Post subject: Reply with quote
With the spring still in you will need to compress the legs and then release to shift the seal / bush. If it will part, and I appreciate it will be hard, then its just a tube and a long drift will shift the fork cap.
Looking at the corrosion on the exposed part I would go with "jjdugen's" suggestion. If the bottom retaining bolt is seized or rounds off, you can always drill it out (had to do it myself one time with a TR1 fork)
I think Marki's towel is to catch bits if it fly's apart in the night!
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Ichy
PostPosted: 01:16 - 21 Jan 2012    Post subject: Reply with quote
You can guarantee that the part will be made of unobtanium or will cost £1,000,000,000 from a dealer.
skikman
PostPosted: 16:21 - 21 Jan 2012    Post subject: Reply with quote
right ive undone the bottom bolt and taken the two halves apart.am i ment to pound down on the long thiner bit at the bottom of the stanchion[dont want to bend it]or what next?
The last post was made 14 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 66.96 Kb
