Removing seized bolts
TheSmiler
PostPosted: 12:51 - 21 Jan 2012    Post subject: Removing seized bolts Reply with quote
Trying to work on the bike today but stuck with seized bolts (jammed on) can't get them off any one got any methods of removing them Question
Tried wd40 but no affect.
Quote Me Happy
PostPosted: 13:09 - 21 Jan 2012    Post subject: Reply with quote
Got access to the bolt and can get a socket on it?
Breaker bar, penetrating oil, impact wrench and heat. One of those or a combination will usually get things moving.
TheSmiler
PostPosted: 13:15 - 21 Jan 2012    Post subject: Reply with quote
I have got access to the bolt it is on the starter motor (8 mm *4) and next to the ignition barrel (10mm*2) but haven't got a socket wrench with enough leverage.
However I will try them methods would a hairdryer work (got no other heat tool) and will price up an impact drill thank you for the reply.
PostPosted: 13:19 - 21 Jan 2012    Post subject: Reply with quote
Buy..
A decent socket set
A newer bike
Choice is yours Wink
I have a basic socket set here... when I go to my dads, his sockets feel so much nicer, work so much better and seem to get the jobs done, mine need some serious throwing away Laughing
Frost
PostPosted: 13:21 - 21 Jan 2012    Post subject: Reply with quote
WD40 is a water repellent and cleaner designed for electronics.
If you're going to try penetrating oil, buy some penetrating oil and read the instructions carefully.
A seized bolt is only an issue as the head might not be able to take as much force as the thread needs to undo it. Cleaning up the head and using the best tool possible helps massively. In order of crap -> best i'd say it goes:
Flat head screw
Phillips screw
Spanner
Allen key
Torx
Ring spanner
Socket
https://upload.wikimedia.org/wikipedia/commons/0/00/Socket_wrench_and_sockets.JPG
Only use sockets like those that grip on the flats, not the corners.
https://www.diytools.co.uk/media/catalog/product/cache/4/image/400x400/9df78eab33525d08d6e5fb8d27136e95/b/r/britool-socket-12-point-standard-3-8-in-drive-13mm.JPG
Avoid that shit like the plague. Also avoid using extensions or universal joints like the one pictured above. If you must use an extension push it on to the bold as hard as you can and don't let it lean.
https://www.audiworld.com/tech/pics/wheel45_DSC03275.jpg
A solid breaker bar won't have a ratchet that you can break and will have a longer handle and will probably allow you to stick something even longer on the end like a bit of pipe.
Some threads get seized in place and though they don't need much force to undo, they need a large amount of force to get them moving initially. A sharp tap with a lump hammer on the breaker bar can sometimes free them right away.
If they still don't want to move it's time to heat things up with a torch as much as you dare. Obviously this will melt plastics and alloy if you get it hot enough.
As a last resort you can cut to head off the bolt. This will allow you to remove whatever was bolted down and will take all the pressure off the thread. Chances are it'll then only be finger tight, but if not you'll have to fight to get it out either with a stud extractor, by filing flats onto it, or if you have enough thread visible you can put 2 nuts onto it, tighten them onto each other then undo the thread using the bottom nut whilst continuing to apply pressure to doing up the top one Laughing
TheSmiler
PostPosted: 13:24 - 21 Jan 2012    Post subject: Reply with quote
##Paddy## wrote:
Buy..
A decent socket set
A newer bike
Laughing don't want a newer bike and the only real socket set I have was kindly given to me by a fellow biker on freecycle (the other is oxford throw away).
Have got my eye on a set at the moment though which should be better, don't have any access to any other tools apart from the ones that I currently have. Might just leave the job till I get the new socket set.
Ichy
PostPosted: 13:34 - 21 Jan 2012    Post subject: Reply with quote
You'll have to PM me your location. Your welcome to use my socket set and I'm stuck in the house decorating (again).
PostPosted: 13:36 - 21 Jan 2012    Post subject: Reply with quote
Fully agree with Frost Thumbs Up
Use breaker bars when it comes to wheel nuts on the car at 120nm... the "spider" doesn't help Laughing
Often use old exhaust pipe as additional leverage if its seriously stuck.
Your best bet is some hardcore tools, even if you have the basic wrench and a few often used sizes 10mm-16mm and grab other ones when you need.
Oh and a hair-dryer will do nothing but dry your hair and warm your hands
TheSmiler
PostPosted: 13:46 - 21 Jan 2012    Post subject: Reply with quote
Thank you mark, will send you a message in a min.
The hair dryer or hand dryer is also the best way to remove a runny nose if you are out and about.
At the moment the best wrench I've got is a drop forged adjustable wrench but not that good when you are trying to grip bolts.
The other main tools that I use are the Wilkinsons spanner set 6-15mm not the best but extremely good.
PostPosted: 13:55 - 21 Jan 2012    Post subject: Reply with quote
Make your next purchase some form of decent socket set, even the halfords professional kit is fairly decent Thumbs Up
whitedevil
PostPosted: 13:57 - 21 Jan 2012    Post subject: Reply with quote
All an adjustable wrench is good for is causing pain and misery. Could also make a good hammer in a pinch
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
TheSmiler
PostPosted: 14:09 - 21 Jan 2012    Post subject: Reply with quote
Will look into that thank you paddy, was told by a security guard that Dr socket sets were good so currently got one on "watch". Any idea if they are any good or not Question
I always though that adjustable wrenches were supposed to be good due to them having hardly any minimum usage. However now I know different I will use it as a hammer if mine fails me.
https://i43.tinypic.com/ngeuyg.jpg
Werny
PostPosted: 15:56 - 21 Jan 2012    Post subject: Reply with quote
That's a man's hammer right there Smiler. With that in your possession there should be no job you can't do Very Happy
*edit for some actual useful advice*
Frost has pretty much covered all the important stuff, but I would add to his final point about cutting the bolt head off. Normally bolt heads are in awkward places, making a saw impossible to use to get the head off. Even if you can get a saw to it, don't do that. The easiset way to remove a bolt head is to drill into the center of the bolt, use a drill smaller than the head but larger than the thread size. Once you have drilled through the head it will just come off, still stuck to your drill bit, and as Frost said it should be easier to remove the stud with the pressure off the thread. It is kind of a last resort though.
Frost
PostPosted: 16:01 - 21 Jan 2012    Post subject: Reply with quote
The halfords pro socket sets are good, but invest in a decent set of these too:
https://image.made-in-china.com/2f0j00GvtQjLosbSpZ/Impact-Socket-Adapter.jpg
I've lost count of the number of broken 1/4 inch adapters i've seen. I bought a Facom one that's lasted me years.
Babba This post is not being displayed because the poster is banned. Unhide this post / all posts.
demon9374
PostPosted: 16:43 - 21 Jan 2012    Post subject: Reply with quote
Get a metal pipe over it, gave me enough leverage to get seized bolts out of my calipers.
The last post was made 14 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 94.84 Kb
