Want for front aswell .. ???
WannaBeDude
PostPosted: 01:19 - 21 Jan 2012    Post subject: Want for front aswell .. ??? Reply with quote
Says rear, can't see why their not for front aswell ??
Confused Question Karma
https://www.rg-racing.com/browseBike/Cagiva/Mito_125/All_Years/RG370.aspx
dragstaar
PostPosted: 15:52 - 21 Jan 2012    Post subject: Reply with quote
I don't see why they wouldn't work on the front?
Just bear in mind you might need to regulate the flash speed
DrDonnyBrago
PostPosted: 16:03 - 21 Jan 2012    Post subject: Re: Want for front aswell .. ??? Reply with quote
The front indicators on the mito are attached to the fairings which is probably why those are specific to the rear.
Them being specific to the rear rather implies that the mounting hole for the front indicator is a different size or more likely will look messy with after market indicators. For a lot of bikes you can get this sort of thing to hide the hole and any shapes in the fairings designed to hug the shape of the original indicator:
https://www.riffgmbh.com/images/product_images/popup_images/1647_0.jpg
A 12v aftermarket indicator is pretty universal. Flash rate can get messed up if you use LED indi's and don't fit an electronic relay and you will need to chop your wiring and fit bullet connectors unless you buy a brand specific wiring adapter like this:
https://www.carpimoto.com/Images/Products/Zoom/Rizoma_EE075H.jpg
I don't know what the front indicator arrangement is like on the raptor, could be that any universal indicator will fit on neatly, could be that it will look messy because of extra holes and bits of fairings moulded to fit the oem indicator.
WannaBeDude
PostPosted: 16:06 - 21 Jan 2012    Post subject: Reply with quote
Thanks, will give it a try ...... Thumbs Up Karma
The last post was made 14 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 40.33 Kb
