Why do bikes back wheels still rotate reving not in gear ?
B10Hazard
PostPosted: 15:21 - 21 Jan 2012    Post subject: Why do bikes back wheels still rotate reving not in gear ? Reply with quote
Little example
https://www.youtube.com/watch?v=eqxawtr6slk&feature=fvwrel
I have never understood this and cant picture or work out why. Can
someone explains
No longer any socks
PostPosted: 15:24 - 21 Jan 2012    Post subject: Reply with quote
Gears are still in mesh even when you're in neutral, it's the oil film that causes drag between the gear and the shaft it sits on that makes the wheel turn. You could stop the wheel with one finger usually.
AlexW
PostPosted: 16:06 - 21 Jan 2012    Post subject: Reply with quote
What the man above said, If you take time to look at how a gearbox works you will see what causes the drag.
Cars do it too.
weasley
PostPosted: 18:47 - 21 Jan 2012    Post subject: Reply with quote
Exactly what Pete said - it's known as 'viscous coupling'. The same effect acts across your clutch, even if it is open (assuming you have a wet clutch).
This is why a bike is harder to push around if it's in gear with the clutch in, than if it's in neutral (especially when cold as the oil is thicker).
0l0dom0l0
PostPosted: 21:52 - 21 Jan 2012    Post subject: Reply with quote
The problem is enhanced when the bikes cold too because the oil is thicker and causes more drag incase you were interested Thumbs Up
1cyl
PostPosted: 22:52 - 21 Jan 2012    Post subject: Reply with quote
So bikes with dry clutches don't?
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
PostPosted: 11:14 - 22 Jan 2012    Post subject: Reply with quote
A dry clutch can drag just as a wet one can. Doesn't have to be oil stiction, any kind of friction can cause drag.
weasley
PostPosted: 13:20 - 22 Jan 2012    Post subject: Reply with quote
A dry clutch bike will do it if the bike is in neutral and the clutch is closed, but theoretically it shouldn't once the clutch is pulled in as there's no coupling from the engine to the wheel (assuming the clutch opens fully).
In related news, it is this viscous coupling across a wet clutch which causes the 'jolt' when you select 1st; you have the clutch in but there is still some drive through the gearbox as you select 1st, hence the jolt (worse when cold).
PostPosted: 14:44 - 22 Jan 2012    Post subject: Reply with quote
Theory or not if the driven plate is touching the driving plate there will be drag.
Yes, that's right exactly.
weasley
PostPosted: 18:30 - 22 Jan 2012    Post subject: Reply with quote
Quite....
weasley wrote:
...there's no coupling from the engine to the wheel (assuming the clutch opens fully)
PostPosted: 18:56 - 22 Jan 2012    Post subject: Reply with quote
But a fully released clutch doesn't mean the plate isn't dragging - the same as a fully released brake doesn't mean the brakes aren't dragging.
Walloper
PostPosted: 20:10 - 22 Jan 2012    Post subject: Reply with quote
Engine Fairies and Gearbox Goblins have quite a lot to do with the fenomenum
https://www.gadgetjq.com/transmission.htm
The ratios of gearing between the engine flywheel/crankshaft and rear wheel make it 'easier' for the friction between component drive the rear wheel when in neutral.
The same thing will not happen as easily in the reverse direction (wheel driving the gearbox). There will be too much resistance in the engine. Even with the plug/s out.
It will be possible to detect torque if you have a sensitive meter.
The last post was made 14 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 75.59 Kb
