Oem v aftermarket chains and sprockets
sidewinder
PostPosted: 17:33 - 21 Jan 2012    Post subject: Oem v aftermarket chains and sprockets Reply with quote
HI all
After a new c+s for the divvy.And would appreciate your help and wisdom.Is there an advantage of buying a genuine yamaha set compred to an aftermarket one.
genuine £124.00
https://www.ebay.co.uk/itm/GENUINE-YAMAHA-XJ600S-DIVERSION-CHAIN-AND-SPROCKET-KIT-/360420287413?pt=UK_Motorcycle_Parts&hash=item53eab923b5
After market £74.99
https://www.ebay.co.uk/itm/Yamaha-XJ600-SD-SE-SF-DIVERSION-1992-03-Rec-Upgrade-DID-Chain-Sprocket-kit-/330640462109?pt=UK_Motorcycle_Parts&hash=item4cfbb5111d
The yamaha one is £50 more than the other is there a reason eg better suited etc.Or are you just paying for the name here?.Being pretty skint dont really want to pay the extra £50 if there is no ideal reason to. Very Happy
Thank you in advance for any help/wisdom Thumbs Up
sw
neil.
PostPosted: 18:18 - 21 Jan 2012    Post subject: Reply with quote
Well a lot of the time, OEMs will just use the likes of DID anyway... with their name stamped on the links as well. You certainly won't go wrong with DID - they're very good. Thumbs Up
DrDonnyBrago
PostPosted: 18:21 - 21 Jan 2012    Post subject: Re: Oem v aftermarket chains and sprockets Reply with quote
As above, many OEM chains seem to be supplied by DID.
Can't go wrong with DID Thumbs Up .
sidewinder
PostPosted: 18:34 - 21 Jan 2012    Post subject: Reply with quote
Cheers all Thumbs Up
Will get the cheaper one ordered.on monday
sw
Is it worth changing the cush drive rubbers at the same time?
DrDonnyBrago
PostPosted: 18:57 - 21 Jan 2012    Post subject: Reply with quote
sw
Not unless they are knackered.
If you are having problems with a worn cush drive then you can stick slices of bicycle inner tube in the gaps as a temporary bodge fix.
PostPosted: 19:06 - 21 Jan 2012    Post subject: Reply with quote
Might find that there are differences in the sprockets. Original front sprockets often have a rubber lump on the sprocket, while some rear ones have an extra guard on the side (stops chains getting caught between the sprocket and swinging arm should it come off),
sidewinder
PostPosted: 19:28 - 21 Jan 2012    Post subject: Reply with quote
So for you then ks .would you get the oem or aftermarket? Thumbs Up
PostPosted: 19:31 - 21 Jan 2012    Post subject: Reply with quote
I would go for a decent aftermarket one. While I can see the advantages of the OE ones I am way too tight to pay that much for it.
sidewinder
PostPosted: 19:47 - 21 Jan 2012    Post subject: Reply with quote
Thanks again all Thumbs Up
ok about order but what is the difference between these apart from one being gold and more pricey
https://www.ebay.co.uk/itm/XJ600-Diversion-92-03-X-Ring-Chain-and-Sprocket-Kit-/350356673333?pt=UK_Motorcycle_Parts&hash=item5192e29335
Sorry for the stupid questions but just want make the wisest choice
sw
PostPosted: 20:03 - 21 Jan 2012    Post subject: Reply with quote
Don't know. Can't find the specs of those 2 chains. Possible the only real difference is the tarty colour.
sidewinder
PostPosted: 20:11 - 21 Jan 2012    Post subject: Reply with quote
Might as well go with gold one then.maybe the gold coating won't get rusty a quick. Very Happy
Sw
sidewinder
PostPosted: 20:12 - 21 Jan 2012    Post subject: Reply with quote
Sw
DrDonnyBrago
PostPosted: 20:29 - 21 Jan 2012    Post subject: Reply with quote
I have the non gold one on my CBR. As far as I can tell it is identical except for the gold colour.
Do you have a chain riveter tool to fit it with?
sidewinder
PostPosted: 21:04 - 21 Jan 2012    Post subject: Reply with quote
No but got an old gent next door.who does alot of work on classic bikes.So he'll be doing it.he used to work for triumph back in the day.looking at his work i trust him Very Happy
sidewinder
PostPosted: 21:07 - 21 Jan 2012    Post subject: Reply with quote
Muscle Bike Rider
PostPosted: 21:16 - 21 Jan 2012    Post subject: Reply with quote
Can't go wrong with DID chain and sprockets, I stuck a heavy duty on mine as it was only £10 more, In 6 months only had to adjust it once. Thumbs Up
Previously Known As A5tra_G
Old Bikes :2010 Kawasaki ER6 F & 2000 Honda VTR Firestorm
Current Bike : XJR1300
The last post was made 14 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 90.43 Kb
