lots and lots of white smoke when warm wr250f 06
jimmyRS
PostPosted: 17:10 - 25 Jan 2012    Post subject: lots and lots of white smoke when warm wr250f 06 Reply with quote
so, i managed to fix the problem with the bike not firing up by cleaning the plug with a copper wire brush and cleaning all the connections to the battery. It then fired up after a few kicks.
At first all seemed well, but once it got warm it started pouring out white smoke from the end of the exhaust and also the place where it slips on to the header (none is coming out of the connection to the barrel).
I then let it cool off and started it up again ready to ride it home (only got round the corner), and at first it seemed fine but then again it started pouring out this white smoke (doesn't seem to smell of anything in particular) and by the time id got 2 minutes, literally, down the road on the way back, it upped to 207*F before i thought id turn it off. Never has it got that high before.
The bike runs lumpy - fine when you open it up but at low revs and easing off the throttle it pops from the exhaust.
Noticed radiator appeared to be low so i topped it up with about 700ml, some of which came out of the overflow when i started it next - still coughing out white smoke.
Also drained all fuel from the tank and replaced with some new stuff - no resolution.
As much as i hate to, I'm thinking its the head gasket or rings. appreciate any help or ways to test, might buy a compression tester to see about the rings.
video here:
https://s1178.photobucket.com/albums/x362/jgrizzla/?action=view¤t=VID_20120125_153013.mp4
thanks
Quote Me Happy
PostPosted: 18:25 - 25 Jan 2012    Post subject: Reply with quote
Radiator low and white smoke? Head gasket leaking?
jimmyRS
PostPosted: 18:31 - 25 Jan 2012    Post subject: Reply with quote
thats what i was thinking, just wanted others opinions on the matter before i went n chucked money at a new gasket,
thanks for confirming though Smile
Dean-J
PostPosted: 20:00 - 25 Jan 2012    Post subject: Reply with quote
Over heating, burning coolant and lobbing out smoke.... Yeah id have to agree with Head Gasket. Which is better than valves though! HG is an easy enough job to do at least Smile
neatbik
PostPosted: 20:04 - 25 Jan 2012    Post subject: Reply with quote
Does sound like the head gasket.
Drop the oil and inspect it for any water contamination.
Baisemontchou
PostPosted: 20:27 - 25 Jan 2012    Post subject: Reply with quote
I concur!
White smoke & overheating = head gasket, do what beatnck2 suggests and look at the oil, water contamination would confirm head-gasket, 99% sure that's what it is.
White smoke = water contamination
Blue = oil, bad, except where it's a good thing! (2 stroke)
jimmyRS
PostPosted: 09:51 - 26 Jan 2012    Post subject: Reply with quote
ordered a new gasket for £36 :/
gonna check the oil tomorrow afternoon n see if its watery, hopefully not but even so i got a spare filter n oil to chuck in there if need be. see how it goes
ty
Johnser
PostPosted: 21:48 - 27 Jan 2012    Post subject: Reply with quote
do you have antifreeze in your coolant?
if not, it is quite possible your head has cracked, letting water spize out into the crankcase. You might not instantly expect this to result in steam coming out of the exhaust but the water/steam coming out of the crack will pressurise the crankcase pushing lots of the steam through the breather. Not sure of your bike, but breathers often exit in the airbox which then allows the engine to suck all that steam through the cylinders.
check your airbox for condensation - if there's water in there, potentially brace yourself for a replacement head!
jimmyRS
PostPosted: 17:40 - 28 Jan 2012    Post subject: Reply with quote
I do use antifreeze and there was no condensation in the air box, fortunately, but thanks for the heads up Smile
Stripped the bike today, and was clear to see the gasket had gone in 2 places. Piston is surprisingly good condition, must of had a rebuild not to long ago. Will post pictures later Smile
Oil was a milky brown colour, so thats been flushed and will replace with fresh stuff n a new filter.
Let you know.how it goes when rebuilt.
Ty
P.
PostPosted: 17:47 - 28 Jan 2012    Post subject: Reply with quote
That... or its just been given an intense steam bath Wink
Mikey3
PostPosted: 17:59 - 28 Jan 2012    Post subject: Reply with quote
fingers crossed it'll all fire up good when the exhaust gasket arrives!
I'm reserving our high 5 until it fires Wink
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
jimmyRS
PostPosted: 21:30 - 28 Jan 2012    Post subject: Reply with quote
aha yeah or that! surprisingly has an ever so feint pink tinge to the edge of the piston where the gasket was leaking aha Razz
jimmyRS
PostPosted: 19:13 - 30 Jan 2012    Post subject: Reply with quote
so, over the weekend had time to get the bike apart n replace the gasket (arrived on sat Very Happy)
Started takin bits n bobs off, then came to draining the oil..
https://i1178.photobucket.com/albums/x362/jgrizzla/badoil.jpg
Not nice, considering that was fresh and gold only 2 weeks ago.
Then took the head off
https://i1178.photobucket.com/albums/x362/jgrizzla/barrel.jpg
Seems fine, gave it a little clean up and it come up really nice, no damage to the piston or barrel from the looks of it.
Also tested for any damage/warping on the head and gave it a once over with some of this very fine polish cloth stuff my dad had.
so, as for the problem?
https://i1178.photobucket.com/albums/x362/jgrizzla/headgas2.jpg
https://i1178.photobucket.com/albums/x362/jgrizzla/headgas.jpg
gone Razz
as for the job as a whole, wasn't hard at all, just fiddley reassembling the camshafts and sorting out the timing, but managed to do it without much hassle whit the help of a friend and my dad.
Will rebuild it fully during the week hopefully and let you know how the end result goes
Smile
Mikey3
PostPosted: 19:42 - 30 Jan 2012    Post subject: Reply with quote
Kudos for fantastic photography skills with oily hands please Thumbs Up
'04 Yamaha WR450F
jimmyRS
PostPosted: 15:49 - 05 Feb 2012    Post subject: Reply with quote
just to update those who helped me with this problem
all is well!
finished the rebuild this saturday morning and after a few kicks, she fired up and idled nicely.
took her for a quick spin and, after clearing out the left over crap in the exhaust, she no longer smoked, or overheated!
thanks for peoples suggestions, and for now all that seemed wrong was fixed by a new gasket Smile
ta everyone! Thumbs Up
The last post was made 13 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.88 - MySQL Queries: 15 - Page Size: 86.18 Kb
