Trousers.
WannaBeDude
PostPosted: 02:01 - 26 Jan 2012    Post subject: Trousers. Reply with quote
I have textile with hip and knee and kevlar with same.
Don't do leathers.
Some bloke on ane on the tv decided to wear jeans on his R6 / 1 ... instead of his leathers, whilst on a ride out with 20 others.
Now if i'm going on a ride out with others, i'll wear my best stuff.
Weather seemed mild aswell.
Bike or wife, he's sold bike.
His leg / shin was smashed to bits, nearly lost leg, clever surgeon and plastic fixed him to a degree.
Would leather trousers or even textile or kevlar jeans lesson that injury ? Confused
And finally, anyone know some good textile type trousers that incorporate shin and even thigh protection ?
It does not help that i also don't do long legged boot.
So an interesting ' gear ' thread, for many bikers afaik stick some jeans on and think their ok - ish ..
Confused Shocked Question Thumbs Up Karma
junglejim This post is not being displayed because the poster is banned. Unhide this post / all posts.
DrDonnyBrago
PostPosted: 10:30 - 26 Jan 2012    Post subject: Re: Trousers. Reply with quote
We aren't really protected against impact injuries, we mostly wear gear to minimise impact injuries in low speed crashes and give us some abrasion resistance in high speed crashes. If you go at high speed into hard obstacles your gear doesn't do a lot.
By the sounds of it his injuries would have been bad regardless of what he was wearing. Armour panels spread the force of the impact out over a bigger area - like getting punched by someone with boxing gloves on, it hurts less because the area of the fist is bigger and the rate of deceleration of the other guys hand is slower as it compresses the padding in the glove.
If the injury was caused by hitting a hard corner i.e. on the curb then armour could possibly help a bit, although not a lot if it was at high speed. If it was a crush injury caused by having his leg squashed between car and bike then it wouldn't help much. The armour in our kit is rather overrated too, I'm sure someone on here (stinkwheel?) said a cheese sandwich passed the same safety tests as motorcycle armour inserts.
More important would be to consider why he crashed in the first place.
angryjonny
PostPosted: 10:49 - 26 Jan 2012    Post subject: Reply with quote
On a race-track leathers are the obvious choice because if you come off, 90% of the time you're simply going to be skidding along the tarmac and that's what leathers cope with best.
Real-world riding, however, in anything other than optimal weather conditions leathers are hot and sweaty or cold and draughty and not waterproof. A decent set of textiles will keep you warmer, drier, more comfortable and therefore less distracted, potentially helping prevent rider-error accidents.
Leathers are better in certain crashes. As has been said above though, they won't save you if you hit a tree or go under a van. Textiles, arguably, may help prevent you getting into a crash in the first place. That is more difficult to quantify though.
doggone
PostPosted: 11:03 - 26 Jan 2012    Post subject: Reply with quote
Even a break is going to be worse if the broken bits wear along the road more than they might in leathers or good textiles.
If you can afford gear buy it, if you have gear wear it whenever practical. It won't do you any good hung up at home.
What's hard about that.
Ride in jeans and trainers and you might be lucky or you might not.
DrDonnyBrago
PostPosted: 11:06 - 26 Jan 2012    Post subject: Reply with quote
There is also risk compensation to consider. In short - feel safer and you ride like more of a dick. I doubt many people are killed because they are wearing textiles rather than leathers during a crash but I know I ride differently (faster, more of a dick) wearing leathers and I am sure many others do too.
PostPosted: 11:33 - 26 Jan 2012    Post subject: Reply with quote
Your post is confusing.
Abrasion resistance will help skin being torn up etc.
Leathers have the best abrasion resistance generally.
Armour can make lower impacts irrelevant and may help reduce the severity of larger impacts - though they could also act to make the damage worse in some ways too.
Good fitting trousers will help "keep it all in", which can make a big difference to recovery. They can act like a splint to some degree too.
A good fit also means armour stays where it is, protects what it should and is less likely to injure other parts.
Leathers offer the best chance of good fitting clothing.
It's much rarer to see jeans or textiles that offer a tight fit.
A colleague of mine crashed wearing jeans and trainers.
Luckily/ironically enough it was outside a hospital. A car flash another car leaving the hospital out as he was passing.
His leg got dragged down the road, wearing away at the bone for a couple of inches.
A very painful recovery, then having to deal with an opiate addiction after that.
Had he been wearing leathers and boots, he probably would have broken his leg in a similar fashion. But I suspect his recovery would have been much quicker with much less of his leg cheese-gratered on the road.
I broke my leg later that year, though landing from some height racing. I was only in hospital for two nights.
Sure, it was a different break, but I suspect he'd have overall been in much better shape with boots and leathers/textiles (or even some proper kevlar jeans, to be fair - but having everything 'held together' would have been best I reckon).
Paris2
PostPosted: 11:41 - 26 Jan 2012    Post subject: Re: Trousers. Reply with quote
I agree with G, your post is confusing, I had to read it twice.
The only piece of gear that I own which I consider will help stop a brake (ankle) is my boots, they are very sturdy and give considerable shin protection.
The rest of my textiles will help with abrasion as others have said.
But in general, no. There isn't much that will stop a brake other than "solid" armour which will keep your limbs from bending the wrong way.
Current Ride: Daytona 600
Taught2BCauti...
PostPosted: 12:26 - 26 Jan 2012    Post subject: Reply with quote
I can recommend the Philip Island range of clothing from 'Bikers Gear' https://stores.ebay.co.uk/Biker-Gear-UK?_trksid=p4340.l2563 - good value and excellent service.
I think it's important not to let safety gear give you a false sense of security that would affect your riding style.
WannaBeDude
PostPosted: 15:07 - 26 Jan 2012    Post subject: Reply with quote
I should clarify further.
The chaps leg had a hole the size of a mans hand, and the shin bones were shattered, so much so that they found a 4 inch piece on the road.
I lol'd at one of the ambulance crew, who said, oh look, weve just found a piece of bone on the floor. I would of thought she should of kept that quite, the biker said, WHAT !
The jeans were normal ones and seemed not very thick either, it seems to of been an impact injury, but proper gear would of seen it held together more as stated above.
It took a while for them to ' brace it ' etc.
My boots are HG tricky and have ankle protection, i was meant to refer to not liking sidis etc.
It seems that the legs have little protection, bar knees and hip inserts. This is my summer jacket, i thought, great protection, why can't they do some trousers like this jacket, with the hard plastic prominent on the shins and thighs.
As for bikers crash, and the cause, it was not stated, although they sa he was on a rideout with about 20 bikers, and he was new to biking, he had an R6 - maybe R1.
I'd say, ride to your ability, esp when out with better riders.
https://i37.photobucket.com/albums/e53/covdude/20062010003.jpg
https://i37.photobucket.com/albums/e53/covdude/20062010.jpg
PostPosted: 16:24 - 26 Jan 2012    Post subject: Reply with quote
I don't like short boots and it seems to be 'asking for trouble' in cases like my friend, as described above. If there's not a good connection between the two in a place like that, I want a good overlap.
Because it's purely a styling exercise and that style isn't that popular?
WannaBeDude
PostPosted: 20:13 - 26 Jan 2012    Post subject: Reply with quote
Can't beleive there appear to be no tight fitting textiles with more leg plates .. Rolling Eyes Thumbs Down
motoman
PostPosted: 20:54 - 26 Jan 2012    Post subject: Reply with quote
I have a pair of Rukka trousers which are a neat fit. They are also using latest technology on their products ...
https://www.rukka.com/mxl-fashion/rukkawww.nsf/pages/en_mc_defence.html
but not cheap.
WannaBeDude
PostPosted: 21:06 - 26 Jan 2012    Post subject: Reply with quote
Nice, which ones have shin and thigh armour then, they all look the same ? Confused Question
1cyl
PostPosted: 21:12 - 26 Jan 2012    Post subject: Reply with quote
I feel safe when i'm snapping up the clips on my boots, pulling on my gauntlets and zipping up jacket. But by the time i get on the bike my goggles have steamed up and i'm struggling to change up through the boots, i feel like i'm attempting operate the bike through a zorb for the first 5 minutes!
I wear safety clothing for obvious reasons but i feel its a hinderence to my control/awareness, i often wonder what the probability of me having an accident would be if i rode around in a t shirt and Jeans with no lid.
Also, i love my big off roady boots but what happens if it gets caught up and twisted round, backwards, thats gonna be my leg!
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
iooi
PostPosted: 21:52 - 26 Jan 2012    Post subject: Reply with quote
But textiles are designed to be worm over other cloths. So tight fitting is not really a option.
Also on the point of like shin armor. The danger of that is, if forced up it could take the knee cap off.
Same thing with thigh plates. Could easily be shoved into body/pelvic area and do more damage than it might save.
Sometimes less is more.
The main protection I desire from my textiles is to keep water and cold out Thumbs Up
WannaBeDude
PostPosted: 22:19 - 26 Jan 2012    Post subject: Reply with quote
Same thing is said about crash bungs ... Rolling Eyes Idea
PostPosted: 01:12 - 27 Jan 2012    Post subject: Reply with quote
If we're talking R&G, yes I've often seen them do more damage than they have saved.
Decent ones, less so. Smile
Robby
Dirty Old Man
PostPosted: 14:09 - 27 Jan 2012    Post subject: Reply with quote
The solution is not to ride at silly speeds in an area where you can hit something solid at high speed. The guy you're talking about broke his shin, maybe carbon fibre leg armour would have stopped that happening. Wouldn't have helped if he hit something with his back or ribs though.
I don't wear armour, its uncomfortable and distracting, therefore more likely to cause a crash of some description. My leather jacket and kevlar jeans give me abrasion protecting and a small amount of impact absorbtion. For major impacts I accept that I'll break bones and walk with a limp. One of the risks of riding.
WannaBeDude
PostPosted: 15:53 - 27 Jan 2012    Post subject: Reply with quote
If there is motorbike pants out there with carbon bits on them, then i fucking want some !! Cool Very Happy
iooi
PostPosted: 20:39 - 27 Jan 2012    Post subject: Reply with quote
The guy you're talking about broke his shin, maybe carbon fibre leg armour would have stopped that happening. .
Top point spot on Thumbs Up
2nd point. All that energy of the object hitting leg, has to go somehere. True having a shin protector will spread the energy over a wider area. But just what damage would it have done to a larger area ?
Also it would need some softer meterial behind it, to help absord the impact, making it a lot more bulky
Handsome
PostPosted: 21:13 - 27 Jan 2012    Post subject: Reply with quote
If it's pissing down then I wear either leathers or textiles and boots ( Walking boots )...
If the weather's fine then I wear jeans and boots/trainers...
If it's motorway journeys ( i:e Rally ) then I'll wear leathers nine times out of ten...
WannaBeDude
PostPosted: 22:21 - 27 Jan 2012    Post subject: Reply with quote
Good for you, now do you know of any gay looking carbon covered pants ? if not, your no use in this thread !!! Idea Very Happy
Handsome
PostPosted: 22:34 - 27 Jan 2012    Post subject: Reply with quote
Cov if your main concern is your shins, purchase the shin guards that are sewn into a ' sock ', pull them over your foot and they stay where they are, failing that wear proper bike style boots that have all the protection that you need...
If there are trousers out there with all this that and the other type of protection in them, they aren't going to be budget mate...
The last post was made 14 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 136.53 Kb
