Connect to an Ethernet network without plugs and sockets
steven_191
PostPosted: 09:55 - 30 Jan 2012    Post subject: Connect to an Ethernet network without plugs and sockets Reply with quote
I want to connect to a network without any sockets. As far as I'm aware the network is a data bus line of transmit and receive meaning its not a loop network. Please correct that if it's wrong.
Basically I need to remote desktop to a computer 30 floors down and up here there are no sockets. The network wires straight into the controller.
What I hope it to be able to temporarily connect, possibly with crocodile clips for easier use, to the bus line with an Ethernet plug on the end, into a wireless router. Then I can Rome the floor with my laptop and control the computer downstairs.
I believe the network is 10baseT but can't confirm that. But is there anything wrong with this idea? I would need a fixed ip for the router. Is that possible? Would I need an access point instead (I think some routers can do both) then it won't need an ip?? I think.
Can any see flaws in this?
UrbanRacer
PostPosted: 10:13 - 30 Jan 2012    Post subject: Re: Connect to an Ethernet network without plugs and sockets Reply with quote
Yes
steven_191
PostPosted: 10:15 - 30 Jan 2012    Post subject: Reply with quote
A bit more investigation shows there MAY be an Ethernet socket on the board. If so, I should able to plug this into a wireless router, plug the router back into the board and have the router set an as access point. This should then allow the network and ip addressing to continue as normal (fixed ips) and then I can wifi to the network and remote desktop the computer.
Riiiight??? I think I'm on the right track thinking the router should be a wireless acces point as it doesn't require any ip addressing. At least I have set up a home network like this before and the primary router still dished out the ip addresses with DHCP and the access point only related them. So with this set up the access was only another point to connect to. Otherwise an invisible member of the network. At least that's what I think
Seb
PostPosted: 10:25 - 30 Jan 2012    Post subject: Reply with quote
I could be wrong but I'm pretty sure you can't simply take a feed off of that cable, your bet is to split and plug the cable, dunk your own hub in there when you need a line, stick a female to female cable extender in when you don't.
Ps your access point won't be invisible and neither will the hub, you are risking a ton of grief by doing this.
2010 Triumph 1050 Sprint ST
steven_191
PostPosted: 10:32 - 30 Jan 2012    Post subject: Reply with quote
Well that sounds shit. If there is a plug though I could connect a hub and then go out to a wireless router and connect to the network from there.
The trouble is there are no hubs, the are no points to connect to the network, there are 30 floors each with 3 plant rooms and this is a secure building so it's difficult to get through any door. Once I'm through a door however I'll be fine. Hence the wifi idea.
The hubs are normally used with another type of network we use but this building is a bit different with a different manufacturer and different design for the plant. So I have to make do.
herulach
PostPosted: 20:44 - 30 Jan 2012    Post subject: Reply with quote
Is this you?
https://www.imdb.com/media/rm3241706752/tt0113243
If you can legitimately RDP to the desktop just put a wireless ap on one end? To be honest if you have legitimate access why can you just tunnel it through somewhere?
If you don't have legit access then why the hell are you asking on a public bike forum?
YBR 125>FZS600
steven_191
PostPosted: 23:34 - 30 Jan 2012    Post subject: Reply with quote
Is this you?
im working in the building but they wont give us an electronic pass for the doors. If i were from the cast of hackers dont you think i wouldve made my own electronic key and caused some havoc on the internet by now??
and by tunneling through somewhere do you mean get a connection to the network like im already trying to do?
the point of this thread was to see if i can get a connection into the network, plug in a wireless router, go through one of the doors i cant get through and then work on the floor without having to go back through the door everytime i want to change some settings from the computer downstairs. The RDP is because the computer is downstairs and im potentionally more than 30 floors away. your welcome to come try all the walking and waiting for a lift and doors you cant use because you dont have a pass Wink
herulach
PostPosted: 00:22 - 31 Jan 2012    Post subject: Reply with quote
Surely if you got a use for it they'll just give you a pass?
Tunnelling as in ssh. Presumably the other machine has the internet? And you have some form of physical access to at least one other machine on that network?
YBR 125>FZS600
Kingstondavo
PostPosted: 23:48 - 31 Jan 2012    Post subject: Reply with quote
This is the only feasible way, you cannot "split" Ethernet, needs to go through a hub.
Current Ride - 2010 Hornet 600
Oz.
PostPosted: 23:28 - 20 Feb 2012    Post subject: Reply with quote
Unless its old coax thicknet cables then tapping in wont work. Also depends on how the network is setup, if its all static IP with no DHCP then you wont be able to use it.
The last post was made 14 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 67.73 Kb
