How often do you pump your tyres?
EazyDuz
PostPosted: 17:19 - 30 Jan 2012    Post subject: How often do you pump your tyres? Reply with quote
Just curious because i checked mine yesterday, and they were both surprisingly low by about 8psi each.
To be honest i never checked them after the new tyres were fitted, i just rode it from the garage after he fitted and pumped them so im not sure how much air (if any) had escaped since. That was around October time, and the bike had been left in the garage for about 2 months before i rode it yesterday and checked the tyres.
Pumped now to haynes manual specifications. So how often should i check and pump them?
Thanks
PostPosted: 17:24 - 30 Jan 2012    Post subject: Reply with quote
Depends how often you ride it. I tend to check mine every half a dozen or so rides, or if it's been sat for a while.
Mikey3
PostPosted: 17:33 - 30 Jan 2012    Post subject: Reply with quote
Every week, and before long rides. Even if the bike's been sitting they'll still lose pressure slowly.
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
J4mes
PostPosted: 17:35 - 30 Jan 2012    Post subject: Reply with quote
Check em every week, probably need to put a few psi in each month.
LordShaftesbu...
PostPosted: 17:38 - 30 Jan 2012    Post subject: Reply with quote
Not as often as I pump yer ma!
PostPosted: 17:44 - 30 Jan 2012    Post subject: Reply with quote
Visual-Squeeze-Ride. (That's when my OCD isn't present) Otherwise it can be Hmmm. 32-36 range in the front. I'm taking a pillion...Hmm..It's cold and raining..Hmm 34 psi it is.
Like Big_Ham said. Depends how often you ride the bike. Also I wouldn't always trust a tyre fitter to use the correct pressure.
Halfucks sell a digi pressure gauge for £5. Rated well in tests.
Tomzo47
PostPosted: 17:57 - 30 Jan 2012    Post subject: Reply with quote
I usually just do it when I fill up, or when checking the oil/chain etc
Ybr 125 > Bandit 650SA > GSXR 600 > Triumph Sprint St1050 > CB1300 > Z1000SX + FJ1200 (written off) > VFR750 >FJ1200
Redoko
PostPosted: 18:22 - 30 Jan 2012    Post subject: Reply with quote
Thanks for the reminder. Thumbs Up
Eddie Hitler
PostPosted: 18:23 - 30 Jan 2012    Post subject: Reply with quote
Every month for me, give both a squeeze before each ride though. (My bike..... hahaha funny. Rolling Eyes )
salty21
PostPosted: 18:27 - 30 Jan 2012    Post subject: Reply with quote
about once a month or whenever they feel squirmy
Louise
PostPosted: 18:31 - 30 Jan 2012    Post subject: Reply with quote
Very Rarely if im honest Embarassed
Back tyre been known to go down to 13psi once Shocked
EazyDuz
PostPosted: 18:32 - 30 Jan 2012    Post subject: Reply with quote
was i quite dangerous riding when the tyres were low then?
I think they were both at around 16-18psi, i rode the bike, then the next day checked the pressure lol
Mikey3
PostPosted: 18:33 - 30 Jan 2012    Post subject: Reply with quote
How good didn't that feel? Laughing
Mike
'04 Yamaha WR450F
salty21
PostPosted: 18:43 - 30 Jan 2012    Post subject: Reply with quote
i've ridden mr.kris's bike from his house to mine with 6 psi in the front and 10 in the rear, was the longest, most scary 10 miles of my life, dont think i went above 50 the whole way Laughing
Louise
PostPosted: 19:01 - 30 Jan 2012    Post subject: Reply with quote
Mike
Well......... Once they were corrected I did almost loose the bike on a roundabout as it dipped in on the corner Shocked One mistake I wont be doing again Laughing
Taught2BCauti...
PostPosted: 19:08 - 30 Jan 2012    Post subject: Reply with quote
I check mine every time I ride - I have Indicator Caps fitted to the valves, so it's easy to see if they need air.
If you get some, get the one's that have a tiny grub screw to lock them in place, or some tow rag will nick 'em.
iooi
PostPosted: 19:22 - 30 Jan 2012    Post subject: Reply with quote
Not as often as I should....
In fact can't remember the last time I did. Embarassed But I soon know when they are low as steering is very slugish.
Although if bike is laid up for a while Laughing then they would be checked, as no use seems to mean loss of pressure.
whitedevil
PostPosted: 19:26 - 30 Jan 2012    Post subject: Reply with quote
I kick my tyres before every ride but i do have a digital gauge i use every week or two.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
stonesie
PostPosted: 19:28 - 30 Jan 2012    Post subject: Reply with quote
Usually before any weekend rideout, they tend to be 200 mile + or once a week. Thumbs Up
Ayrton
PostPosted: 19:41 - 30 Jan 2012    Post subject: Reply with quote
Usually whenever the bike has been sat for longer than a week. Otherwise whenever i notice the bike is getting hard to push.
Cheeseybeaner
PostPosted: 19:45 - 30 Jan 2012    Post subject: Re: How often do you pump your tyres? Reply with quote
Thanks
Every week or 500 miles at least I'd say, its surprising how much difference 5psi makes to the way a bike handles. You can go from a wallowing imprecise machine to something which feels sharp and tight handling.
PostPosted: 19:58 - 30 Jan 2012    Post subject: Reply with quote
I'd picked up a puncture (flat) about 5 miles away from home. Front was an old Avon and did a good job of staying on the rim as I rode it home perched on the pillion seat. Above 20mph downhill bend. Thinking Probably not my best decision but got the old bike home.
GrantT
PostPosted: 20:01 - 30 Jan 2012    Post subject: Reply with quote
Hahahahaha exactly the same happened to me.
My bike had been sat for a while (whilst I failed some Mod 2s Embarassed ) and when I eventually got round to riding it I never thought to check the pressures. Had to stand it up in a corner and then a little while later stand it up and bump up onto the pavement because it was going straight on Shocked
Checked pressures and front was 7psi! Embarassed Put in the required 36 and nearly laid the thing on its side on the first roundabout out of Asda! I blame the eagerness to get out on it after owning the thing for 3 months and having it sat in the garage staring at me Laughing
PostPosted: 20:25 - 30 Jan 2012    Post subject: Reply with quote
Not as often as I should, even with my nerd OCD. I've only recently realised that they don't bulge visibly as much as car tyres, so they do need checking more often. Mine were *cough* PSI, I'd assumed that the difficulty in pushing it was the brakes binding a bit: the hot rubber smell eventually clued me in. Embarassed
Dean-J
PostPosted: 20:49 - 30 Jan 2012    Post subject: Reply with quote
Once a week for me.
rather be over cautious than under prepared!
The last post was made 14 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.99 - MySQL Queries: 13 - Page Size: 128.11 Kb
