oil pump alignment
stevo123
PostPosted: 20:46 - 20 Sep 2004    Post subject: oil pump alignment Reply with quote
After taking the casing off the clutch side of the engine for a good ole clean up inside i removed the oil pump gear cog. Is it neccessary to align it with anything. I don't think so as it just drives the pump and water pump. Am i right or talking bollox again?Worried now, have not rode the bike yet but is on my mind now. eek Rolling Eyes
loply
PostPosted: 21:02 - 20 Sep 2004    Post subject: Reply with quote
Dont trust me, but I dont see why it would need to be aligned.
mr jamez
PostPosted: 21:12 - 20 Sep 2004    Post subject: Reply with quote
As long as you put it back how it went in then it should be fine, I guess it is the same as the NSR, it is just a driven nylon cog that sits on a shaft which goes into the pump?
PostPosted: 00:34 - 21 Sep 2004    Post subject: Reply with quote
Probably worth disconnecting the oil pump from the casing before you put the case back in place. The oil pump drive goes in a slot under the casing, so easier to make sure it engages properly if you are just putting the oil pump in after reattaching the casing.
stevo123
PostPosted: 07:15 - 21 Sep 2004    Post subject: Reply with quote
Thanks fellas. Wink Karma
The last post was made 21 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 43.77 Kb
