| Lupine Lacuna |
 Lupine Lacuna Scooby Slapper
| Alpha-9 |
 Alpha-9 Super Spammer
 Posted: 11:59 - 31 Jan 2012 Post subject: |
Remove your brakes
This should stop any accidental braking incidents
No thanks needed  |
| DrDonnyBrago |
 Posted: 12:13 - 31 Jan 2012 Post subject: Re: Checking the bike over (how often and what?) |
I'd agree with most of this:
https://www.motorcycle.co.uk/Articles/Maintenance/Easy-scheduled-maintenance.aspx
Some of it is bullshit though. You don't need to check your spark plug gaps monthly on a modern 4 stroke. Checking for leaks and holes in your tyres is enough, I do it when taking locks etc off - quick look for for fluid leaks, nails, obviously flat tyre, bolts hanging out, chain hanging off etc.
Lights I check weekly along with fluid levels, tyre pressure, chain tension and lube, chafing of cables etc. |
| Mikey3 |
 Mikey3 World Chat Champion
| Minty |
 Minty World Chat Champion
| arry |
 arry Super Spammer
 Posted: 13:47 - 31 Jan 2012 Post subject: |
I shamefully neglected my CBR for a bit and when I finally got round to checking it over, I found the chain was mega loose, the tyres were 10psi+ down on what they should be and the front brake light microswitch wasn't operating properly
I'm only really a weekend rider, so I check mine over at least once a month for condition. |
| weasley |
 weasley World Chat Champion
| P.addy |
 P.addy Red Rocket
| DrDonnyBrago |
| P.addy |
 P.addy Red Rocket
| Tenko |
 Tenko Could Be A Chat Bot
| T.C |
 T.C World Chat Champion
 Posted: 15:24 - 31 Jan 2012 Post subject: |
Two simple acronyms which I used to teach learners and even now still teach at advanced level, BOLTS & POWDER
B - Brakes
O - Oil
L - Lights
T - Tyres
S - Suspension
This is usually a pre ride check before your first ride of every day, bearing in mind that bulbs can blow and tyres can pick up nails and cause a problem the following day, and usually only takes a couple of minutes when you are into the routine.
The more detailed check is POWDER -
P - Petrol, do you have sufficient fuel for your journey
O- Oil and lubricants including checking brake fluid levels
W - Water, on watercooled bikes obviously
D - Damage, are there any bits hanging off the bike or broken?
E - Electrics, covers the whole system including emergency stop.
R - Rubber, which not only includes tyres, but bar grips and footrest rubbers.
This check takes a little longer and I tend to do it once a week
Two simple words to remember, and it does work. ____________________ It is better to arrive 30 seconds late in this world, than 30 years early in the next |
| stonesie |
 stonesie World Chat Champion
| jimbothe |
 jimbothe World Chat Champion
 Posted: 19:03 - 31 Jan 2012 Post subject: |
I always check that the bike is not on it's side and I'm not on the floor. If it is then I have crashed.
Visuals - tyres, chain, fuel and lights - particularly brake light as mine seems to vibrate to the point it loses connection.
Oh and fork seals because I is fat.
Once a week - Engine oil, mainly because it's an old smoker which probably, litre for litre uses more oil than petrol
Monthly - suspension and brake pads.
Thats just me though. ____________________ Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle |
| Lupine Lacuna |
The last post was made 14 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
