| Tom_N |
 Tom_N Scooby Slapper
 Posted: 22:16 - 31 Jan 2012 Post subject: 2005 RS125 cutting out! |
Hi all,
Been so long since I've posted on here. Cringed when I logged in with my user name
Anyway bought myself a 2005 Aprilia Rs125 today which was VERY cheap. Too cheap to miss, problem is that it will run fine for ten or so minutes but then cut out. There looks to be an RS250 pipe modified to fit it and a stupid looking open air filter. Just thought I'd check on here incase it was a common problem. It will save me tearing it down into bits.
Cheers
Tam |
| Timmeh |
 Timmeh World Chat Champion
| bikenut |
 bikenut World Chat Champion
| Skudd |
 Skudd Super Spammer
| Tom_N |
| Timmeh |
| Tom_N |
| jimmyRS |
 jimmyRS Scooby Slapper
| Tom_N |
| jimmyRS |
 Posted: 22:27 - 02 Feb 2012 Post subject: |
right now a compression check seems the best way to go about it after all,
hopefully its just the rings if anything at all  |
| jimmyRS |
 Posted: 22:29 - 02 Feb 2012 Post subject: |
btw jus looked at the picture, its unlikely thats a rs250 pipe unless they've bodged it as rs250 pipes both come out on the right hand side of the bike, not the left.
And as for the open air filter, get rid and stick a stock box back on there. If it hasn't been upjetted by 8-10 it'll be running lean as hell, plus them things aren't great when it comes to damp/wet weather. Talking from personal experience  |
| Tom_N |
| Tom_N |
| bikenut |
| jimmyRS |
 Posted: 11:27 - 04 Feb 2012 Post subject: |
them things should be pushing 110psi if fully perfect, but 100 isn't bad at all, definitely shouldn't be the problem making it not fire.
looking more down the lines of fuel starvation than compression, tried popping some fuel down the plug hole then firing up? if it fires, more than likely its a fuelling problem, if it doesn't fire its back to compression/spark
not to doubt you, but are you sure the spark is strong? With my RS50 i was at a loose end like you when trying to fault find, turned out my stator was kicking out enough to spark nicely when outside the barrel, but inside with the compression and fuel it couldn't.
hope you sort it out soon mate  |
| Tom_N |
 Posted: 13:52 - 04 Feb 2012 Post subject: |
If it is failing to start then likely the main jet and needle are irrelevant.
Does it start and run for 10 minutes, and when it dies refuse to restart for a bit, and when it does restart run for far less time?
If so my main guess would be that the fuel filter is blocked, the fuel pipe is kinked (both unlikely given you have already changed the tap, and it dribbles from the pipe) or that the fuel tank breather hose is blocked (in which case running it with the fuel cap open will fix it).
But your compression readings are also low so probably needs new rings as well.
| Tom_N |
| jimmyRS |
 Posted: 16:35 - 04 Feb 2012 Post subject: |
if you've only recently fitted the air filter, then possibly. It might be starving of fuel and/or running lean due to too much air for the air filter and the worn manifold you said earlier.
Unlikely to be the reeds either unless you've done more engine mods, in which case you would need thicker (stiffer) reeds to stop them opening up too much too early and loosing power.
Screw the battery, ask a friend and try and bump start it, them things are generally easy enough to bump, n it'd allow you to see if holding the revs open/closed helps with starting.
n remember, do it in second gear, not first  |
| Tom_N |
| jamesrs250 |
 jamesrs250 Nova Slayer
| hadden |
 hadden Trackday Trickster
 Posted: 20:07 - 04 Feb 2012 Post subject: |
daft i know but are you sure the coke is in the right position.wont be the cause of the problem but if it ran fine for 10 minutes and then not,i would check that.easily done,my symbols had rubbed off and it took me ages to realise i had left the choke on  ____________________ red bull gives you wing sting!!!
current:aprilia rs 125
previous:honda c90,honda cm 125,yamaha xt 550,2004 suzuki drz 400.(all used for off road back in the day)and a piagio zip 50cc..oooossssshhhh |
| Kris_taylor1988 |
 Kris_taylor1988 L Plate Warrior
The last post was made 13 years, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
