| BLOFLY 636 |
 BLOFLY 636 Brolly Dolly
 Posted: 07:11 - 21 Sep 2004 Post subject: clutchless upshifting? |
hey I have been reading some tips on doing wheelies and have noticed several articles that say by using clutchless upshifts, pulling and holding a wheelie is more easily achieved. I am concerned as to what damage my bike would sustain if I were to use this technique (besides looping it ) is the gearbox on most bikes okay with such abuse or should I just try learning to use the clutch when shifting while mid-mono?  ____________________ Those bloody footpegs......they ought to do away with em! |
| Grubby |
 Grubby Spanner Monkey
 Posted: 08:15 - 21 Sep 2004 Post subject: |
What you do is to put pressure on the gear lever & close the throttle slightly & the next gear will drop in, then you open the throttle again. Obviously this is done whilst up on the balance point or else the front end will drop faster than an American hostage's head in Iraq.
Oh & no it won't fuck up ya gearbox.
Don't you use clutchless changes when you're racing your mates then?  |
| BLOFLY 636 |
 Posted: 08:59 - 21 Sep 2004 Post subject: |
actually I have never even tried to do a clutchless upshift I have always been scared I would break something in the box but I can remember a test done last year between the Ducati 749s and all the Japanese 600's and they (performance bikes magazine) said on the Ducati you can hold the throttle wide open and pre-load the gear lever with a small amount of pressure then when you hit the rev-limiter the next gear will be engaged in the blink of an eye! so I am guessing that one of those translogic gear shifter things cuts ignition and then selects the next gear before re-engaging the ignition is that what shutting the throttle, snicking the next gear then re-opening the throttle does in a way?? I should give it a go but I would really hate to hear a crunching noise that would break my heart  ____________________ Those bloody footpegs......they ought to do away with em! |
| G |
 G The Voice of Reason
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 09:30 - 21 Sep 2004 Post subject: |
Don't try changing gear in a wheely until your getting up near the balance point. In fact I wouldn't reccomend worrying about changing gear until you can go for a good distance and feel comfortable, but balance point is better.
To change gear in wheely you need to have the wheel relatively high as the bike will drop a bit when you let off the throttle to change gear, I've seen a few videos of people fucking up gear changes by giving it too much gas when changing and looping.
Getting up to the balance point and being smooth is a more important goal to begin with, in my opinion anyway. ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| G |
 Posted: 10:12 - 21 Sep 2004 Post subject: |
, forgot he was asking in relation to wheelies.
Initially I definitely /wouldn't/ change at the balance point. If you have enough power you can change fairly low and keep it up.
However, I would suggest that you initially try and learn to keep it up in one gear; if you can do this well, then changing gears won't be a problem.
Admittedly I have twice fallen off the back after changing gears (I think that was the reason anyway); remember, when you knock it up a gear at the balance point, turning the throttle by the same amount will make you go twice as far as before. At the balance point the bike will move back/up very quickly. But then I still haven't sorted using the rear brake to control wheelies :'(.
I'd do it a little bit below the balance point. |
| Sparks! |
 Posted: 10:23 - 21 Sep 2004 Post subject: |
Yea sorry my post wasn't clear, I meant he should get comfortable with wheelying at the balance point for distance and generally be happy with the wheel up high and long etc before trying to change gear.
I haven't seen any wheelie pics from him but he sounds like a newbie to it (from reading up on guides etc.. I may be wrong?)
G, do you cover the rear brake?
I spent about an hour doing small wheelies forcing myself to cover the brake, I have improved a lot since doing this as I'm not nearly as scared as flipping any more... I nearly flipped going down my road but instinctively hit the rear brake....
Blofly, get happy with wheeling in general before learning to change gear... in general "goals" then getting up to the balance point and being "smooth" in general is best to learn before trying to change gear..
I'm no expert but have listened to a lot of advice from those that do it for a living and their general advice is be comfy with wheelying at balance point etc etc and being smooth, covering brake blah de blah and changing gear should be relatively simple when your comfortable and not just learning to wheely in general.. ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| BLOFLY 636 |
 Posted: 11:02 - 21 Sep 2004 Post subject: |
I tried to do a wheelie in 1st by just snapping the throttle open but it comes upp way too quickly and it is really hard for me to keep it at balance point should I try it in 2nd maybe? the reason I would prefer to try wheelis in 1st more is because it is a slower speed for me to attempt them at and I have a smaller chance of getting a head shake when I bring the front hoop back to earth it all happens too quick for me to grasp what I should be doing plus just trying to hold on to the bars without giving false intentions to the throttle is pretty hard too and I squeeze the tank so hard I get cramps in my hip muscles I need that wheelie school that I have seen advertised over there so many times! that would definately help!  ____________________ Those bloody footpegs......they ought to do away with em! |
| G |
| G |
| Sparks! |
 Posted: 11:17 - 21 Sep 2004 Post subject: |
| BLOFLY 636 wrote: | I tried to do a wheelie in 1st by just snapping the throttle open but it comes upp way too quickly and it is really hard for me to keep it at balance point should I try it in 2nd maybe? the reason I would prefer to try wheelis in 1st more is because it is a slower speed for me to attempt them at and I have a smaller chance of getting a head shake when I bring the front hoop back to earth it all happens too quick for me to grasp what I should be doing plus just trying to hold on to the bars without giving false intentions to the throttle is pretty hard too and I squeeze the tank so hard I get cramps in my hip muscles  I need that wheelie school that I have seen advertised over there so many times! that would definately help!  |
From that, don't think about changing gear at all...
Relax, you don't need to hold the bars any more than normal riding, it's not that difficult to take left hand off bar either so you shouldn't be holding on tight - loosen your grip, sit back a bit and RELAX.
1st is very choppy on sports bikes, I don't like using 1st at all, learn to clutch in second and downgear it a bit.
You want to go faster not slower to start with, as far as I know, it's harder to flip if your going faster.
If your worried about getting into tank slappers then fit a steering damper, I landed the WR last week with the wheel pointing to the right (was a nice wheely with wheel turned to right I just "forgot" to turn the bars back in time ) and the bike didn't go mad about it if your relaxed.
If your holding on as tight as you sound then that will make landings very shakey.
Wheely school is over-rated and over-priced, just find a nice quiet car park and ride up and down with a mate who knows what he's doing.. start in 1st relaxing and getting used to the wheel lifting etc. I went to fireblade wheely school to watch some mates, they enjoyed it but they aren't "into" stunting as such and the teaching methods were questionable! Wouldn't reccomend it to anyone who actually wants to wheely properly. If you just want a picture or two and a certificate to say "I survived the wheely school" then that's all you'll get from most of the wheely schools IMO.
G knows more than I do so will probably post some better advice in a bit for you... but seriously forget about balance point and changing gear , you don't need to consider it if your just doing small wheelies
Balance point is HIGH, I doubt you've got anywhere near it yet, got any pics of you trying at all?? always helpful are pictures, very helpful.
By the way, I'm not too sure on sportsbike stunting but this looks about the balance point, not completely sure but G will prolly provide better advice
https://home.swipnet.se/habs/Images/Wheelie%20R1.jpg
I won't show you the supermoto balance point picture, that'll just put you off  ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| r1_lad |
 r1_lad Spanner Monkey
 Posted: 11:51 - 21 Sep 2004 Post subject: |
Personally, i found when i started learning to wheelie on the r1 that 2nd gear clutch-ups was more daunting than the 1st gear powerups. The clutched up wheelies came up far too fast for my liking while the power wheelies were quite easy to control. When you first start getting the front wheel off the ground theres just too much adrenaline and too many things to try and co-ordinate/remember at once.
I started doing 1st gear wheelies off the power and getting used to the feel of the bike on the back wheel and once your used to that its easier to concentrate on remembering the little things and not panicing if things go a tad pearshaped but correcting it with either the throttle or the back brake.
I did find that when i first started wheelying and wasn't managing to keep up the front wheel for very long that i'd get quite a few tankslappers, maybe there was just too much going on in my head at the time and didnt have time to straighten the front wheel. Now i am keeping it up for longer i very rarely get any headshake/tankslappers.
Now i've pretty much mastered the 1st gear wheelies and can easily keep it up till the end of the gear i've started going back to clutched up 2nd gear wheelies and i find them much easier now and less daunting than before but they still come up much faster than the power wheelies in my opinion. So much more fun though, picking up the front wheel at about 35mph and keeping it up till about 110 (the end of 2nd gear on my bike).
I've only tried changing gear in a wheelie twice and both times it just brought the front wheel back down. I'm going to practise it a bit more when I've got the hang of 2nd gear clutchups more, that and standups are next on my list  ____________________ RS50 -> RS125 -> GSXR600 SRAD -> 02 R1 -> Speed Triple 1050 -> Ducati Streetfighter 1099 -> DRZ400 Superetard |
| Zimma |
 Zimma Wheelie Junkie
 Posted: 12:12 - 21 Sep 2004 Post subject: |
www.zimmah.co.uk/wheelie.wmv Clutchless shifts.
Hadn't had my storm all that long when that was taken. ____________________ -Zimma |
| Zimma |
| r1_lad |
| hustler |
 hustler Crazy Courier
 Posted: 12:31 - 21 Sep 2004 Post subject: |
I so want to do that  ____________________ As I said to that guy with the crutches and full camouflage gear, you can hide but you can't run. |
| G |
 Posted: 12:35 - 21 Sep 2004 Post subject: |
As yams said, relax. Holding on tight is also the worst thing you can do in a tank slapper.
However I have landed some wheelies quite crossed up and never really had a problem. Not got nearly as bad tank slappers as I've had on the road; and a lot, lot less bad than I've seen others have on the road.
When you bring it down, you want to make sure you keep the power on, if you are intentionally bringing it down and it's not that it's running out of power, you should just dip the power, then bring it back on to the same point you were at.. as the bike lost a bit of ehight, the same power shouldn't be enough to keep it up. Bringing it down slowly should give you plenty of time to get the front straight.
Personally, I think that mx style bikes have a lower balance point relative to the rider for the same speed wheely. However sportsbikes tend to have a lower balance point because they go faster.
The air resitance holds the bike up to some degree at higher speeds... so a 130mph wheely is getting a lot of air pressure pushing up underneath it's bodywork, so needs less power to hold it 'balanced'.
r1 lad:
In a power wheely...
As you pull on the throttle, initially the engine has to do a lot of work to lift the front, however as the angle increases, it needs proportionaly less power to get another 10degrees higher. This means that doing a power wheely will start off slow and get 'faster'.
It's good to learn how wheelies 'feel' for the novice as it starts slowly.
In a clutched wheely...
The initial, say 30degrees happen pretty quickly, but as the engine speed matches the rearwheel speed it slows down and then it's up to the rider to pull on the throttle as they see fit. I* try to clutch it up to a little bit below the 'range' I want to be in, I then pull the throttle on to fine tune the rest.
*well, not like I've done any wheelies for age, but when I did :'(.
So:
Power wheely=Slow, then fast.
Clutch wheely=Fast, then slow.
Blofly:
Not sure what stage you're at, but, something to try practicing.
Get the front up in first under power, don't get it as high as you can, but keep it up level using the throttle at a not too high height.
Get used to the way you can modulate the throttle to keep the bike at the same attitude.
When you start to run out of revs bring it down smoothly.
This should give you a bit more confidence.
Then try doing the same, but with a small clutched wheely to start; not so that it hits you in the face, but so that it comes up a few foot on the clutch, then practice keeping it just above this point as you were doing with the power. |
| Zimma |
 Posted: 12:45 - 21 Sep 2004 Post subject: |
R1_lad.... It's an R1, clutch it up in 3rd... That's what I did.  ____________________ -Zimma |
| Zimma |
 Posted: 12:48 - 21 Sep 2004 Post subject: |
| Hustler wrote: |
I so want to do that  |
Had Susi on the back one time down some big ass dual carriageway, started a clutched up 2nd gear wheelie and cruised along for a good 1/3 mile going all the way up to the top of 4th gear and clicked into 5th just before we came to a corner.  ____________________ -Zimma |
| Sparks! |
 Posted: 13:09 - 21 Sep 2004 Post subject: |
The attached picture is the balance point of supermoto, he's doing about 70mph and wheelied for just over 3 miles non stop down a closed dual carriageway with bends etc... pretty fooking class! But thats the balance point on supermoto's I've heard numerous people say motards are harder to balance than sports bikes and I also think that the balance point for MX bikes is lower than supermoto. Not sure to be honest.
Me personally, I'm still trying to get to balance point, I think, judging by pictures, that I'm not far off It's just having the guts to go even further back
What all the supermoto lot say in reply to wheely questions is.....
Practice Practice Practice ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| Andy99 |
 Andy99 Spanner Monkey
| Reevo8 |
 Reevo8 World Chat Champion
| r1_lad |
| Reevo8 |
| r1_lad |
The last post was made 22 years, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
