| Lynxx |
 Lynxx Scooby Slapper
| bikenut |
 bikenut World Chat Champion
 Posted: 18:00 - 03 Feb 2012 Post subject: |
Bikenut's right the slop will be in the selector fork. The fork wears a lot faster because of the small contact area compared to the whole circumference of the slot in the gear, plus the gears are usually harder.
Could be any number of reasons why the gear is worn one side But most likely is plain old wear and tear. Dave Silvers might do you a new shift fork, if not you could effect a repair by welding up and filing/grinding back to shape. ____________________ a.k.a 'Geri'
| Lynxx |
| Lynxx |
 Posted: 19:19 - 03 Feb 2012 Post subject: Pics |
| Lynxx |
 Posted: 20:33 - 03 Feb 2012 Post subject: |
That is no easy question to answer without some metallurgical knowledge and knowing what they are made of. Bit beyond my scope of knowledge but as I see it there are several options:
Find out what material they are lkely to be made from would be my first choice. I would think, some high-nickel steel alloy is likely, but that is only a guess.
You might weld them up with normal welding filler, mill and grind back to shape and use them as-is. Or do the same as above and case-harden. The more heat you use the higher the risk of distorting the hole that the fork rod fits with a sliding fit.
You could weld them with a hardfacing rod or some other high-nickel rod and grind back to shape.
You might try asking on a welding forum such as mig-welding.co.uk as to the best chance of successful welding without wrecking the fork itself. What do you have to lose, they are knackered anyway? ____________________ a.k.a 'Geri'
| Lynxx |
 Posted: 21:03 - 03 Feb 2012 Post subject: |
Don't assume that because there is 6mm of dog to engage it will use all of that 6mm. Very often I have seen dogs that only just caught on the edge (like Binge's CRF). Look at the wear on the dogs to judge how much engagement you've been getting. also allow for a bit of flex and endfloat in the assembly under load. ____________________ a.k.a 'Geri'
| Lynxx |
| Lynxx |
 Posted: 17:56 - 05 Feb 2012 Post subject: |
If the dogs and slots were rounded that suggests minimal engagement. What I would do is take one of the other worn out shift forks and build it up with TIG and re-shape it, then fit that the next time I have cause to take the engine down. ____________________ a.k.a 'Geri'
| Lynxx |
| Lynxx |
| steven_191 |
 steven_191 Nearly there...
| Lynxx |
 Posted: 13:11 - 06 Feb 2012 Post subject: |
Yep poor engagement on the dogs. They aren't terrible to be honest but clearly enough to let it jump out. ____________________ a.k.a 'Geri'
| Lynxx |
 Posted: 22:59 - 06 Feb 2012 Post subject: |
I agree they would be steel or some alloy of it. A quick touch on the grinder would tell. I wouldn't weld it more than the original size.
If you have more than one spare, why not experiment with some hardfacing rod. That would last a very long time. ____________________ a.k.a 'Geri'
| Lynxx |
| gwernybwch |
 gwernybwch Nova Slayer
| Lynxx |
The last post was made 13 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
