How do you build a bridge on water?
Dischord
PostPosted: 21:35 - 05 Feb 2012    Post subject: How do you build a bridge on water? Reply with quote
I've always wondered this and have searched online about the construction of 2 local bridges but haven't found anything that really answers my questions.
How do you build the foundation for bridge 'towers' or supports over deep, moving water?
The bridges in question are Menai and Britannia over the Menai Straits in North Wales?
2012 KTM EXC 250
Hetzer
PostPosted: 21:56 - 05 Feb 2012    Post subject: Reply with quote
Put big tubes in the water, pump out the water, fill with concrete.
Suntan Sid
PostPosted: 21:57 - 05 Feb 2012    Post subject: Reply with quote
Piles!
Put simply, modern structures, built on unstable material are more often than not supported by concrete piles.
Drilling rigs bore out cores and inject concrete into them, to form a stable base for the foundations, the depth and number of piles depends on the loads and the ground conditions involved.
I remember seeing a program on Discovery about one of the old New York bridges where they tunneled down underneath the river, to build the foundations, the water was kept out of the tunnel using compressed air. Unfortunately they didn't know about the "Bends" at the time!
I'm currently working on a new "marina" project, all the structures, offshore, are supported by piles!
Start watching Discovery Science, sooner or later they repeat everything and you'll find out everything you need to know! Thumbs Up
Suntan Sid
PostPosted: 22:00 - 05 Feb 2012    Post subject: Reply with quote
Here's some info on the Brooklyn bridge, I mentioned.
https://www.eyewitnesstohistory.com/brooklynbridge.htm
fatpies
PostPosted: 22:12 - 05 Feb 2012    Post subject: Reply with quote
You could always divert the water during construction as well.
They did this for the Hoover dam and the massive dam in China.
Paulington
PostPosted: 03:07 - 06 Feb 2012    Post subject: Reply with quote
As Hetzer said, put huge steel/some kind of material tubes in the ground through the water, drive piles down into the ground at the bottom and then fill it with reinforced concrete of some type.
As Fatpies said, a few dams in America they diverted all the running water around the construction site and then when they'd finished they blocked up the diversion so it flowed through it's normal old route.
Take a look at Discovery/Discovery Science/Turbo some time and try to catch "Extreme Engineering", "Megastructures" or something similar. A lot of bridges on these programmes that show you exactly how they are done.
Where there's a will, there's a way! Thumbs Up!
Frost
PostPosted: 03:12 - 06 Feb 2012    Post subject: Reply with quote
The Clifton suspension bridge looks like it was built by some men in a boat taking a thin line across, then that being used to pull a thicker one across before eventually the final iron chains. But that bridge is so high up that supports in the middle would have been impossible.
Generally rivers can either be done in a single span, diverted or pylons put in. Sea bridges are a bit harder as you've got to work with the tide, and build it strong enough not to get destroyed by it.
Pie-Roe
PostPosted: 01:46 - 07 Feb 2012    Post subject: Reply with quote
Check out the King Fahd causeway. It's pretty cool. Cool
R6 Wilson
PostPosted: 19:05 - 07 Feb 2012    Post subject: Reply with quote
Same way you would go about building Oil thingy's
♥ YZF-R6 '05 ♥
Time is money so I stay late
Dischord
PostPosted: 23:45 - 07 Feb 2012    Post subject: Reply with quote
Would these techniques have been used in the 1820's?
Cheers for the info so far guys, very useful!
2012 KTM EXC 250
fatpies
PostPosted: 23:54 - 07 Feb 2012    Post subject: Reply with quote
The method Hetzer mentions was used by Brunel in 1854.
https://en.wikipedia.org/wiki/Royal_Albert_Bridge
The last post was made 14 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 69.97 Kb
