Script to map drives
Colin Edwards
PostPosted: 13:28 - 08 Feb 2012    Post subject: Script to map drives Reply with quote
I have a requirement for some home user machines to be able to connect to our network via VPN and map network drives. I can get all the drives mapped apart from the home directory
I have tried using the %username% variable but this doesn't work (e.g. \\server\server\%username%). It uses the account name the user has logged in with and this can be anything as its a home PC
I need some sort of script that will prompt for user name and password and then map a home directory n the username
Any suggestions?
CE
el_oso
PostPosted: 14:14 - 08 Feb 2012    Post subject: Reply with quote
think you find that you may need to mess about with the security settings. i'm sure that by default windows blocks sharing of home directories. so you need to change that setting first.
sorry, but i'm too tired to really understand what is fully going on. hope this helps somewhat though.
Duke 390
Car: Jeep Wrangler 4.0L
Colin Edwards
PostPosted: 14:16 - 08 Feb 2012    Post subject: Reply with quote
All settings are fine and dealt with
Just need someway to get the script to prompt for a user name and then use the username as the variable
CE
Colin Edwards
PostPosted: 15:33 - 08 Feb 2012    Post subject: Reply with quote
Got it:
echo "Enter Username"
set /p UserName=
echo "Password"
set /p PassWord=
net use m: "\\server\share\%USERNAME%" /User:domain\%username% %password% /PERSISTENT:NO
net use n: "\\server\share" /User:icr\%username% %password% /PERSISTENT:NO
CE
The last post was made 14 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 40.05 Kb
