VBA for excel. Allow users to enter time with either . or :
Mira
PostPosted: 14:19 - 08 Feb 2012    Post subject: VBA for excel. Allow users to enter time with either . or : Reply with quote
Hi folks,
I did a search on a excel forum and found some code that does what i want (mostly) which is to allow users to enter a time in either 7.3 or 7:30 and have it display as 7:30. Except it doesn't work if some one enters a time less than 1 for expamle enters 0.3 (meaning 0:30) it shows 7:12
Code:
Private Sub Worksheet_Change(ByVal Target As Range)
Const WS_RANGE As String = "C4:V23"
On Error GoTo ws_exit:
Application.EnableEvents = False
If Not Intersect(Target, Me.Range(WS_RANGE)) Is Nothing Then
With Target
If IsNumeric(.Value) And .Value >= 1 Then
.Value = (Int(.Value) + (.Value - Int(.Value)) * 100 / 60) / 24
.NumberFormat = "[h]:mm"
End If
End With
End If
ws_exit:
Application.EnableEvents = TrueEnd Sub
I have tried changing the Part of the code
to
If IsNumeric(.Value) And .Value >= 0 Then
That fixes the 0.3 problem but now if you try and enter 1:00 it changes it to 0:04 instead of leaving it as 1:00
Any sugestions?
Thanks, Mira. Confused
I have heard there are troubles of more than one kind. Some come from ahead and some come from behind. But I've bought a big bat.  I'm all ready you see.
Now my troubles are going to have troubles with me! ~ Dr Seuss.
daemonoid
PostPosted: 16:10 - 08 Feb 2012    Post subject: Reply with quote
not a vba programmer, but as a rough guess you should use this test instead:
if instr(1, .Value, ".") Then
instr returns the position of the . also so you can use that for the replacement. You'll have to tidy up the syntax yourself, like I said, don't do vba.
current: ducati monster 750
Mira
PostPosted: 23:30 - 08 Feb 2012    Post subject: Reply with quote
Thanks Thumbs Up
I'm not a VBA programmer either but I'll have a play with what you suggested and see what happens Shifty Laughing
The last post was made 14 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 38 Kb
