The sounds of engines
Lupine Lacuna
PostPosted: 10:37 - 09 Feb 2012    Post subject: The sounds of engines Reply with quote
1. Why do two inline fours of the same capacity sound different?
2. Why do Suzuki's inline fours sound better than Honda's inline fours?
Presumably the things that affect engine sound is(excluding capacity and cylinders):
1. exhaust
2. valves
3. strokes
anything else
nowhere.elysium
The Pork Lord
PostPosted: 10:55 - 09 Feb 2012    Post subject: Reply with quote
What is this I don't even?
Seriously - how the hell can you claim that Suzukis sound better than Hondas? You've owned one bike, and live in a place where you can't even wind the engine out properly.
They can sound different for a massive range of reasons: valvetrain setup (gear-driven/chain-driven/pushrod*/hydraulic), whether or not the bike's water-cooled or air-cooled, cylinder dimensions, firing order, whether or not the fuel feeds are balanced properly... There's a whole shedload of other reasons, but I really can't be bothered to go into it. It's a bloody stupid question; asking to apply objective reasoning to a subjective viewpoint makes no sense.
*I hope to God that there's never been a pushrod four, but I am ready to be corrected on that one.
jjdugen
PostPosted: 11:01 - 09 Feb 2012    Post subject: Reply with quote
Ariel square four was pushrod....... Pretty sure the Hendersons were too... But, a silly thread non the less.
Lupine Lacuna
PostPosted: 11:16 - 09 Feb 2012    Post subject: Reply with quote
Dont get caught up in what I say about Hondas (though I thought it was common knowkledge they have a more subdued engine note), I am simply asking an open ended as to what determines the sound
PostPosted: 11:26 - 09 Feb 2012    Post subject: Reply with quote
Neutral Is this real life?
OP, lol
They sound different because they do.
They are made differently. My 600 XJ sounds miles different to my old Daytona 600. It just sounds different, it goes faster... stop being gay asking about noises and start twisting your throttle more. Wink Scared of a Bandit Laughing
D O G
PostPosted: 11:27 - 09 Feb 2012    Post subject: Reply with quote
OP is becoming more annoying than warped.
nowhere.elysium
The Pork Lord
PostPosted: 11:35 - 09 Feb 2012    Post subject: Reply with quote
Again with the prescriptive claim, from someone with minimal experience. It's not 'common knowledge', because it's not necessarily true.
Modern Honda engines have been liquid cooled for longer than Suzuki engines have (at least, the budget range has). Liquid cooling suppresses a lot of noise; if we find an air-cooled Honda four, and compare the sound to a liquid-cooled Honda four, it'll seem a lot noisier. Ergo, your statement is bollocks.
PostPosted: 11:41 - 09 Feb 2012    Post subject: Reply with quote
A hell of a lot of factors can change engine tone the sounds a bike makes.
Have a listen to the big bang R1s - actually sound more like a twin, which is what you'd expect as their firing order to some degree replicates the typical firing order of a twin.
Plenty of push rod 8s in 'mercan land - still often making loads of power too. Though think they are starting to move on a bit.
My lorry uses a push rod 6 I believe, though perhaps not quite the sort of engine you were thinking of either.
nowhere.elysium
The Pork Lord
PostPosted: 11:44 - 09 Feb 2012    Post subject: Reply with quote
I was thinking more in terms of motorcycles than cars; I know that the US never really moved on from pushrods.
daemonoid
PostPosted: 11:51 - 09 Feb 2012    Post subject: Reply with quote
Didn't think it was that bad a question.
As has been said earlier various factors affect the normal engine sound, however in use the exhaust affects it the most, listen to the sounds of these:
stock:
https://www.youtube.com/watch?v=RaOQmUPxPUU
poseur spec:
https://www.youtube.com/watch?v=zlNVelpT06A
current: ducati monster 750
PostPosted: 11:52 - 09 Feb 2012    Post subject: Reply with quote
Probably one of the most important factors is cam timing, along with any resulting valve overlap. Firing order is important (ie, as G mentions the R1 has an odd firing order, while many V twins will have an uneven firing order as combustion strokes are not evenly spread).
After that you get all the other things in the engine that make noise. Primary drive, whether it is chain or gear, and if gear whether then are straight cut. Intake noise (which is carefully tuned to sound good to some people). Clutch rattle. Etc.
PostPosted: 11:54 - 09 Feb 2012    Post subject: Reply with quote
the obvious thing is the exhaust, or silencer I should say.
My daughters CBR400 hasn't got one on at the moment and it sounds awesome Laughing
mistergixer
PostPosted: 11:58 - 09 Feb 2012    Post subject: Re: The sounds of engines Reply with quote
Because all Gixer engines are personally hand-assembled by the sweet baby Jeebus himself.
Space Monkey #7
Lupine Lacuna
PostPosted: 12:33 - 09 Feb 2012    Post subject: Reply with quote
I can see that. A gixxer always sounds better than a blade.
Alpha-9
PostPosted: 12:38 - 09 Feb 2012    Post subject: Reply with quote
Why do cats sound different to lions?
They're both cats right Question
mistergixer
PostPosted: 12:49 - 09 Feb 2012    Post subject: Reply with quote
I like you. You can come to my house and fuck my wife.
Space Monkey #7
Fisty
PostPosted: 13:02 - 09 Feb 2012    Post subject: Reply with quote
And a TL sounds better than a GSXR and blade Razz
Fatter and faster than Fret
PostPosted: 13:25 - 09 Feb 2012    Post subject: Reply with quote
Well yes - in opposite land!
https://hellogiggles.com/wp-content/uploads/2011/06/homer.gif
daemonoid
PostPosted: 13:48 - 09 Feb 2012    Post subject: Reply with quote
Primarily it's the size of the aperture (the throat) and the shape of the vocal chords of course. But there's also the fact that lions are unusual in the filidae family in that they hunt and live in prides and so need a greater 'vocabulary' for communication - for example the majority of cats, including house cats do not roar. Lions were thought to rely on fatty deposits in their vocal chords to produce their ultra deep roar but actually it is purely down to their unusual vocal chord shape.
Interestingly many house cats have learnt to 'speak' to their owners and produce a sound akin to a baby's cry mixed with a purr; which has been shown to be the most effective sound to get food quickly.
HTH
Alpha-9
PostPosted: 14:06 - 09 Feb 2012    Post subject: Reply with quote
HTH
Answer's OPs question perfectly, i'd say Thumbs Up
truslack
PostPosted: 15:39 - 09 Feb 2012    Post subject: Reply with quote
_Iain_ wrote:
Regarding the suzuki vs honda noise wise, go on youtube and search CBR250RR, or VFR400.
I'd definately prefer the sound of that 250 over a gixxer!!
What about a GSXR250 vs as CBR250 then?
PostPosted: 15:45 - 09 Feb 2012    Post subject: Reply with quote
Given the fact they aren't the same style of engine at all? IL4 vs V4 Wink
Moxey
PostPosted: 15:57 - 09 Feb 2012    Post subject: Reply with quote
https://27.media.tumblr.com/tumblr_libmf98wjt1qzqua1o1_400.jpg
And is this the same guy who asked why all bikes don't come fitted with that 'miracle cure to all crashes on motorcycles' that is ABS Rolling Eyes
PostPosted: 16:03 - 09 Feb 2012    Post subject: Reply with quote
It is in fact the one that is scared of non ABS bikes, even more scared of Bandits, that insane acceleration but they dont want to travel over 20mph Shocked
The last post was made 14 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 134.87 Kb
