Honda ns125r 1992 problems need help!
racerboy888
PostPosted: 08:55 - 11 Feb 2012    Post subject: Honda ns125r 1992 problems need help! Reply with quote
hello, i have a honda ns125r 1992...... the problem is that it will turn over but wont start (kick start type)
I have replaced the spark plug, replaced the sparkplug ht lead and coil, checked the fuel line, replaced the battery, etc and still wont start!
I have checked for a spark but there is a strong spark generated, after so long of turning it over (dead leg by then) it makes a hell of a bang (backfires).
it all happened when i broke down on it not long ago and had it recovered. where i was riding and just lost power and the engine just stopped (gawked).
i just cant get it going what do i do????? please help!!!
dungbug
PostPosted: 09:13 - 11 Feb 2012    Post subject: Reply with quote
Have you done a compression test? If you spark is good & you've got fuel getting through it should start provided it has compression. What condition was the plug in that you removed, might give an indication to the condition of the engine prior to it breaking down.
racerboy888
PostPosted: 09:25 - 11 Feb 2012    Post subject: Reply with quote
.[/quote]
i have not yet done a compression test but i had the old spark plug out it worked with a weak spark (was the coil though) and it was barely fouled and barely worn as it was new a week prior to the break down i was told it was the cdi but changed that no difference. also i did notice something... around the head it was damp on the seal and i found that after a few cranks seemed flooded (about 2 cranks i think)[quote]Have you done a compression test? If you spark is good & you've got fuel getting through it should start provided it has compression. What condition was the plug in that you removed, might give an indication to the condition of the engine prior to it breaking down.
racerboy888
PostPosted: 15:57 - 13 Feb 2012    Post subject: Reply with quote
found the problem Smile head gasket seal failure Smile
dungbug
PostPosted: 21:35 - 13 Feb 2012    Post subject: Reply with quote
Good that you've found the cause, well done. Thumbs Up
st3v3
PostPosted: 03:42 - 14 Feb 2012    Post subject: Reply with quote
Post a couple pics of it?
Also, how full is the radiator?
The last post was made 13 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 46.69 Kb
