| ukd204 |
 ukd204 Derestricted Danger
| Ichy |
 Ichy World Chat Champion
| Ichy |
| ukd204 |
| ukd204 |
 ..... Quote Me Happy
| -Savage- |
 -Savage- World Chat Champion
| ukd204 |
| ukd204 |
| Ichy |
| Kickstart |
 Kickstart The Oracle
| ukd204 |
| chris-red |
| ukd204 |
| Kickstart |
| chris-red |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:12 - 13 Feb 2012 Post subject: |
1/ May we presume english is not your first language?
This might be making the diagnosis of your fault & our questionable humor more difficult. Fault on our part; your English is far better than the few words of any second language I have ever managed!
2/ Where in the world are you located?
Chennai? Southern India? I guess your climate is quite different to ours, and cold to you is likely to have different references to ours here in the UK!
'smoke' on start up is entirely normal.
Bikes are generally started on 'choke' an enrichment circuit putting an excess of fuel into the engine to help it warm up. This makes 'some' extra smoke.
Some start up smoke will almost certainly be 'steam'. The fuel & air burn to produce a mixture of exhaust gasses, which significantly contain a fairly high proportion of Carbon-Di-Oxide and water.
One of the simplest fuels is Methane CH4, which burns in O2 entirely to CO2 + H2O. Petrol is a much more complicated Hydrocarbon fuel, and burning under much more extreme and less ideal conditions in an engine, so a greater proportion of Carbon-Monixide is produced, but the 'main' exhaust gasses are still CO2 & H2O.
On a cold engine, the water 'made' by burning fuel, will 'condense' on the cold metal walls of the exhaust, and many exhaust systems have small condensation vents in the lower portion of the pipe to drain any H2O that actually collects in the liquid state.
Much though will be expelled, as 'water vapour' small droplets of liquid water, held in suspension in the gas, as well as actual gaseouse 'steam'.
Water is also a 'usual' component of 'air' occurring as 'humidity' and water vapour suspensed in air, will also tend to 'mist' in clouds' when the air is 'warmed' by hot exhaust gasses, the same as your breath, on a cold day, in damp Englans, will cause a 'fog' infront of your face.
More 'smoke', even on a brand new engine, will be caused by lubricating engine oil being burned in the combustion chamber.
The engine needs some lubrication on the cylinder walls, and on the valve stems, and very small amounts of oil residue will get into the combustion chamber.
If the cylinder wall or the piston rings are excessively worn, or as suggested, the valve stem seals valve stems or valve guides are excessively worn, THEN an excessive amount of oil CAN contaminate the 'charge' and lead to a 'smokey' engine.
After a period of not running, oil left in the valve gear compartment of the engine above the combustion chamber, can drip down past the valve stem into the combustion chamber, and be quickly burned off in the first few moments of running the engine on start up.
More excessively worn engines will also burn oil left on the cylinder walls or forced past the piston rings during running.
Worn valve guides often give the symptom of smoking more heavily on 'over run' when the engine is decelerating, with teh throttle closed, as oil is sucked down the valve stem, under the higher inlet manifold vacuum.
Worn bores, will tend to give the symptom of smoking more heavily under hard acceleration, when the crank case pressure of the accelerating engine forces more oil past the piston rings.
All engines 'smoke'.
The colour of smoke, varies. When we talk about the colour of exhaust gasses:
'white' is normally associated with steam or water vapour.
'Blue' with burned engine oil
'Black' with excess fuel.
But this should not be talken litterally! The smoke is always going to be a sort of 'grey' colour; we are looking for 'tints' to that basic colour, and it can sometimes be difficult to distinguish exactly what the symptoms are from the colour alone.
You say that you can smell 'oil' in the smoke.
It was asked early; whether your bike was a two-stroke that would have a 'total-loss' lubrication system, 'light' oil being pumped into the engine to be burned with the charge after lubricating crank case bearings, or added directly to the fuel.
This may NOT be a dead end, having explained that your bike is a four-stroke; as you live in Southern India.
It has been a long time since I was there; BUT, when I was, apart from the inevitable Enfields, MOST motorbikes, were Indian built copies of Yamaha RSX100 or Honda H100 two strokes; and petrol stations, actually had people that put the petrol into your tank for you, unlike here in the UK, where we have to do it ourselves.
In some rural parts of the country I visited; the 'petrol station' was not like ours here in the UK, with bulk delivered fuel in containers and electric pumps to measure it into vehicles... it was delivered in 25gallon 'jerry-cans' and decanted from these into vehicles, outside the local 'General Store'.
How are you buying your petrol?
Could your fuel be contaminated?
Could an ignorant shop-keeper be filling your petrol tank with pre-mixed two-stroke petrol?
IS the fuel in your part of the world, mineral oil 'petrol', or is it locally blended, and pottentially containing a high proportion of vegatable derived alchohol distillate?
These things could all be effecting the 'smell' of the smoke.....
Other wise, 'best guess' is down to a worn valve stem seal; BUT, we do need to be clearer on the symptoms and to eliminate some possibilities before we can offer better suggestions. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Ichy |
 Posted: 17:00 - 13 Feb 2012 Post subject: |
way to go Mikey. That's how a pro kills a thread.
The fact that the clutch and 'self starter' needed changing after one year suggests that the OP either does very high mileage or the build quality was poor from the beginning. He also mentioned that the problem started after he serviced it. Maybe it has too much oil in it and a bit is blowing past the rings or travelling into the air filter through a breather? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| ukd204 |
 Posted: 18:02 - 13 Feb 2012 Post subject: |
It's called "height of knowledge sharing"..Anyway guys,being a mechanical engineer,I knew the basics about the engine operations,cycles and all that.After seeing the exhaust smoke,it's clearly understood that is not at all related with steam.During fitting the clutches,those mechanics did something wrong with the valves hence some engine oil leaks into the combustion chamber.If the piston rings,valves are worn out,problems could be seen earlier also.engine oil level is going down certainly but not drastically.
I am wondering about the expenses,if they suggest for valve/piston ring change.  |
| WannaBeDude |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
 WannaBeDude World Chat Champion
| _Iain_ |
 _Iain_ Banned
 Posted: 20:35 - 13 Feb 2012 Post subject: |
| Quote: | being a mechanical engineer,I knew the basics about the engine operations,cycles and all that |
[/quote]During fitting the clutches,those mechanics did something wrong with the valves | Quote: |
In which case, please explain to me what the fuck kind of engine has the valves removed, re adjusted or re set up to have someone change a clutch?
Assuming it was a four stroke, then the only reason i can see of the valves being interfered with would be either:
re timing the engine due to replacement of the cambelt/chain, removing the head or simmilar
Adjusting the valve clearances as part of a service/overhaul
Or possibly if they had the head off, & took the valves out to lap them back in or something simmilar.
Either way not related to the clutch
But then again, if you swear blind you know whats wrong with it then go fix it instead of telling everyone that they're wrong.
____________________ Please be aware that the above post may be full of complete nonsense.
| ukd204 |
| ukd204 |
 Posted: 04:47 - 14 Feb 2012 Post subject: |
| _Iain_ wrote: | | Quote: | being a mechanical engineer,I knew the basics about the engine operations,cycles and all that |
I am not an expert and not a dumb listener..I may have some thoughts and just sharing that...anyway thanks to all of u for ur valuable time and comments..let's drop the topic and kill this thread.
| [/quote] |
| Billing |
 Billing World Chat Champion
 Posted: 05:20 - 14 Feb 2012 Post subject: |
How though?
As said, the valves don't need to be touched at all to change the clutch, so they can't have done something with them when they change the clutch  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| chris-red |
The last post was made 13 years, 344 days ago. Instead of replying here, would creating a new thread be more useful? |
