| HD |
 HD World Chat Champion
 Posted: 22:40 - 13 Feb 2012 Post subject: Am I just being stupid? (Nut/Bolt Sizes) |
Basically I have bought a set of nuts for the bike. I ordered m12 nuts and they arrived. I tried to fit them and wondered why they didn't fit. Measured the inside and they are 10mm.
Now I'm not 100% and the seller is a business seller so surely they know their stuff but they said that I need nuts the size of the bolt. So I measured it and sure as shit the bolt was 12mm. Now they are saying that I need a nut that is 10mm smaller to fit.
Now I know that it needs to be a bit smaller otherwise it will slide over but I am talking a fraction of a millimetre, not two full mil?
Can someone confirm this before I do return then buy some more nuts please.
Just to clear up, the nut I had measured 12mm internally, the bolt measures 12mm externally. I ordered m12 nuts and they are 10mm internally.
Cheers  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| WannaBeDude |
 WannaBeDude World Chat Champion
 Posted: 22:44 - 13 Feb 2012 Post subject: |
M 12 bolts need ..........................................................................................................................
M 12 Nuts.  ____________________ Jogging on, destination living. |
| HD |
 Posted: 22:48 - 13 Feb 2012 Post subject: |
My bolts are 12mm so surely they need 12mm nuts? Isn't M12 the same as 12mm? I thought it was metric classification?  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| Nexus Icon |
 Nexus Icon World Chat Champion
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 22:53 - 13 Feb 2012 Post subject: Re: Am I just being stupid? (Nut/Bolt Sizes) |
The M12 bolt is almost 12mm wide at the tips of the thread (see pic below, major diameter) , the hole in the M12 nut will be smaller because some of it will sit inside the thread of the bolt (if that makes sense, i.e. the minor diameter of the bolt). If the hole was also 12mm the bolt would just slide in and out without screwing in.
If they don't fit, you are sure the bolts are M12 and sure the nuts are M12 then i would suspect that it is the thread pitch that isn't right.
If the pitch is out then you might get it to thread on a tiny amount then get stuck.
Thread pitch is the distance between the threads:
https://www.jjjtrain.com/vms/Media/glossary_m/minor_diameter.gif
To measure the bolt pitch, measure the distance across 10 threads with a ruler, divide by 10 and that will be your pitch ( I say 10 because measuring one is tricky without a vernier caliper).
Then you would get nuts in M12 x pitch in mm - i.e. M12 x 1.5, M12 x 1.75 etc.
If it is rear sprocket bolts you are after then IME they tend to be M12 fine (M12 x 1.25). |
| HD |
 Posted: 23:13 - 13 Feb 2012 Post subject: |
No, its a nut to go on the back of my peg hanger.
If anything, it measures slightly under 12mm with my verniers. They were only cheap though so not sure of the accuracy. The old nut has stripped threads inside thats why I need a new one.
What shall I do?  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| DrDonnyBrago |
| HD |
 Posted: 23:26 - 13 Feb 2012 Post subject: |
Think I may just do that then as I only need one and atm I am getting 5
I have to get lifts everywhere atm though :/
Verniers and the peg hanger are both down the garage so I'll have a look tomorrow.
| Raffles |
 Raffles World Chat Champion
| HD |
 Posted: 23:32 - 13 Feb 2012 Post subject: |
| Rob W |
 Rob W World Chat Champion
| DrDonnyBrago |
 Posted: 23:37 - 13 Feb 2012 Post subject: |
I have no idea.
Only real way to tell is to take one off and measure the bolt that is poking out in the way detailed above. Of the few bikes that I have ordered new nuts for, all have been M12 x 1.25 and I have used some of my stock of nylock nuts (a blue ring of nylon that stops them coming undone).
If you are struggling with measuring pitch then a metric thread pitch gauge can be had for a few quid and is REALLY useful to have around:
https://www.ebay.co.uk/sch/i.html?_nkw=metric+thread+pitch+gauges&_frs=1&_trksid=p3286.c0.m359
It is just a comb like metal blade that fits onto the threads, if it lines up properly that is your pitch. |
| Polarbear |
 Polarbear Super Spammer
| Rob W |
| HD |
| wilz1234 |
 wilz1234 Trackday Trickster
| wilz1234 |
The last post was made 14 years, 251 days ago. Instead of replying here, would creating a new thread be more useful? |
