Replace HS1 bulbs with H4? - CBF125
Beez
PostPosted: 10:41 - 14 Feb 2012    Post subject: Replace HS1 bulbs with H4? - CBF125 Reply with quote
Is it possible to replace the crappy HS1 bulbs in my CBF125 with some nice Philips H4's? Apparently the connector is the same but the power required is different? Don't want to end up melting some wires Smile
Taught2BCauti...
PostPosted: 11:46 - 14 Feb 2012    Post subject: Reply with quote
https://en.wikipedia.org/wiki/User:KDS4444/HS1_bulb
Beez
PostPosted: 15:42 - 14 Feb 2012    Post subject: Reply with quote
Taught2BCautious wrote:
So it will fit yes, but it was the different wattage issue I was getting at. The CBF's HS1's use 35/35w while the set of H4's I'm looking at use 60/55w.
I guess it's less a question of "can I?" and more a question of "will these explode my battery?".
'02 ER-5
'09 CBF125
Dracon
PostPosted: 15:56 - 14 Feb 2012    Post subject: Reply with quote
They won't explode your battery, possibly melt your wiring (although I doubt it), but possibly melt your lens, especially as the Honda is an always-on.
Shinigami
PostPosted: 16:14 - 14 Feb 2012    Post subject: Reply with quote
don't do it, you'll cause damage to the plastics in the lens, might drain your battery much quicker also, I've found my clr125 doesn't really like anything additional hooked up to take power ie heated grips etc
Beez
PostPosted: 22:47 - 14 Feb 2012    Post subject: Reply with quote
Bah thought as much, cheers for the replies.
Seems a bit daft Honda would limit a bikes primary method of being seen to such a low wattage bulb, maybe because it's always on?
'02 ER-5
'09 CBF125
neil.
PostPosted: 07:04 - 15 Feb 2012    Post subject: Reply with quote
Also, the headlight is powered from the alternator on the CBF125 - so you may be overloading that rather than the battery. As in, there may not be enough juice left to charge the battery.
I guess it depends on what you're used to - I find the 35W bulb perfectly adequate even on unlit country roads at night. Just keep that lens clean, as the build-up of dirt really has an affect. As far as 125s go, I think the CBF has one of the better headlamp designs - decent reflectors scatter the light evenly across the road, much more so than bikes with the round shells, like the YBRs which project a useless spot.
PostPosted: 10:11 - 15 Feb 2012    Post subject: Reply with quote
A quick look on ebay shows you can get HS1 HID kits.
The one I looked at wasn't clear if it was 35w, but most are - you use a 35W to replace a 55W and it's still brighter than the standard by a good chunk.
Are other legal issues and a bit more hassle to fit, however.
Beez
PostPosted: 12:34 - 15 Feb 2012    Post subject: Reply with quote
True, and I guess this is my first proper bike so I probably just need to adjust to it.
'02 ER-5
'09 CBF125
Taught2BCauti...
PostPosted: 15:23 - 15 Feb 2012    Post subject: Reply with quote
I had the same problem with my 2008 Honda Varadero! I used to cuss the 'stoopid cagers' for pulling out of side-roads on me all the time, until I nearly did the same thing myself when I was out in the car one evening.
I was waiting to turn right out of a side road and almost failed to notice a bike similar to mine with it's dirty-yellow headlights, against a background of much brighter headlights on the following traffic.
Now some people will tell you it can't be done, or shouldn't be done, but I fitted 2 x 35W H4 HID Xenons in place of the 2 x 35W BA20D's (which are only good for map reading) and have had no trouble since.
They draw the same current as before, but run cooler - so no risk of damaging the wiring or plastics.
It took a bit of fettling to get the same beam pattern as the originals, but a mate of mine who is an ex biker-cop couldn't find anything wrong with them, and the bike recently passed it's first MOT.
PM me if you are interested in more info.
neil.
PostPosted: 15:40 - 15 Feb 2012    Post subject: Reply with quote
On the CBF, you will need to convert the headlight wiring to DC, having it run off the battery, if you want to run HID.
Shinigami
PostPosted: 15:43 - 15 Feb 2012    Post subject: Reply with quote
My bulb is a ba20d, the original in the bike when i got it was useless, couldn't see a thing, probably burning out though as no idea how long it had been in.
Replaced with a xenon ba20d bulb, same wattage (35w) and it's made a big ole difference and the white light is better, doesn't shine blue at all which is good to avoid the chavvy look
PostPosted: 15:44 - 15 Feb 2012    Post subject: Reply with quote
Ah and that being the case, you could then cause more problems as the reg/rec may not be able to keep.
Seems like best bet might just be to learn to live with it until you get a bigger bike!
Taught2BCauti...
PostPosted: 15:53 - 15 Feb 2012    Post subject: Reply with quote
Easy enough - just need to fit a 6Amp Bridge Rectifier to each ballast.
There is a gap of 2 years, 179 days between these two posts...
bigdyl69
PostPosted: 22:00 - 12 Aug 2014    Post subject: Reply with quote
How do you fit one of these bridge rectifiers?
The last post was made 11 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 84.67 Kb
