Carb Problems
dungbug
PostPosted: 12:38 - 14 Feb 2012    Post subject: Carb Problems Reply with quote
I've had some issues with my bike, which is a 1999 Suzuki GN125. She starts ok, rev's are little hesitant every now and then. She'll get up to 45+ without any trouble but will then lose power, almost feels like a bit of a misfire. I've replaced the spark plug with the correct model (NGK brand), replaced the cap (NGK) and replaced the HT lead. The plug suggests that the mixture is lean as the plug colouring is white(ish), however the spark itself is orangey in colour & I'd expected a blue spark. There's plenty of sparking going on but the colour seems wrong to what it should be.
I'm suspecting the coil is on it's way out but I'm looking for any other suggestions people may have/have seen the same before. I checked all the electrical connections a couple of weekends ago, they were all clean and firm as they should be.
I'm building a new carb for this bike as the carb that's currently fitted has a buggered mixture screw so no adjustments can be made with the mixture. I think the mixture is part of the problem but I can't ignore this orangey spark, it doesn't seem right......Or am I worrying about nothing? The engine itself feels strong and sounds healthy, no smoke, knocks or rattles and doesn't use/lose oil.
Any advice would be great, thank you. Thumbs Up
cb1rocket
PostPosted: 13:26 - 14 Feb 2012    Post subject: Reply with quote
yes as you thought the spark should be a nice blue, so give the coil a go, seeing as you have replaced the other bits.
Is this a CDI ignition or contact breaker? I assume its the first anyway.
dungbug
PostPosted: 13:29 - 14 Feb 2012    Post subject: Reply with quote
CDI ignition on this, I hadn't thought that it might be the CDI. Confused
cb1rocket
PostPosted: 13:33 - 14 Feb 2012    Post subject: Reply with quote
well you def know its something until its blue.
Also did you fit the right cap? Some have resistors in em!
Try your old plug as well to check its not a duff new plug
dungbug
PostPosted: 15:16 - 14 Feb 2012    Post subject: Reply with quote
I did try the old plug, same result with the orangey spark. The cap was ordered from Wemoto who I've always found to be spot on in sending the right bits. The old cap literally fell apart and it had (what I thought at the time) a resistor inside, would this have been right? Thanks for your help by the way. Thumbs Up
PostPosted: 16:41 - 14 Feb 2012    Post subject: Reply with quote
More likely the coil than the CDI no?
dungbug
PostPosted: 16:43 - 14 Feb 2012    Post subject: Reply with quote
Hoping it is the coil, CDI costs more. Mr. Green
steven_191
PostPosted: 17:06 - 14 Feb 2012    Post subject: Reply with quote
Doesn't the CDI tell it when to spark and the coil supplies the strength of the spark?
Possibly coil not supplying enough umph anymore.
dungbug
PostPosted: 17:53 - 14 Feb 2012    Post subject: Reply with quote
That's what I was suspecting, I've found it's helpful to get other peoples take on things. I've only had a bike for 6 months so still learning my way around them. Thumbs Up
PostPosted: 18:01 - 14 Feb 2012    Post subject: Reply with quote
If it starts well from cold then stop worrying about the colour of the spark.
If you suspect a lean condition have you checked that you have an air filter fitted? If so you might want to give the carb a quick service and check the float height.
dungbug
PostPosted: 20:44 - 14 Feb 2012    Post subject: Reply with quote
Hi Pete, starts without any real trouble, used her during the recent ice & snow. It has the factory fitted air filter and I replaced the foam element about 4 months ago.
I've just picked up another carb, pretty gummed up inside which I've almost finished cleaning. Will hopefully have it ready to fit by the weekend so I'll see if that fixes/helps.
Thanks for your reply chap. Thumbs Up
pepperami
PostPosted: 21:18 - 14 Feb 2012    Post subject: Reply with quote
Have you thought about the battery?
An old battery and a cold snap = battery not performing as it should.
dungbug
PostPosted: 22:09 - 14 Feb 2012    Post subject: Reply with quote
Not considered the battery as she's always started on the electric start, I'll grab a volt meter at work tomorrow and see what the output is. Cheers, good call. Thumbs Up
Robby
Dirty Old Man
PostPosted: 22:19 - 14 Feb 2012    Post subject: Reply with quote
If the mixture adjustment screw is chewed up, then you know that someone has been at it in the past. Someone that didn't know what they were doing, who managed to mangle a screw.
Get the spare carb cleaned up and set to factory settings, it sounds like your problem is going to be in there.
cb1rocket
PostPosted: 22:35 - 14 Feb 2012    Post subject: Reply with quote
pretty much right there!
edit: the cdi stores the electrical current to which is then passed to the coil.
The pulsor coil which is off the flywheel in most case is what triggers the cdi to release the current to allow it to spark
dungbug
PostPosted: 23:31 - 14 Feb 2012    Post subject: Reply with quote
The mixture screw is mangled, there's a slight bit of purchase with a screw driver but it's stuck solid. Tried generous amounts of WD40, leaving it to soak, adding more and still won't shift. I took the old carb apart a few weekends ago to clean it inside and found what I presume was loctite on a few of the screws (which were a pig to remove). I don't know why this had been done as the threads were fine and tightened down. Question
This is (what's left) of the mixture screw;
https://i16.photobucket.com/albums/b29/dungbug/DSCN5865.jpg
Rolling Eyes
New (2nd hand) carb being stripped & cleaned;
https://i16.photobucket.com/albums/b29/dungbug/DSCN5916.jpg
The mess inside the float bowl was pretty much the same throughout.
https://i16.photobucket.com/albums/b29/dungbug/DSCN5914.jpg
I'm getting there, still a few bits of grime that I want to get shifted, also need to get some more compressed air at the weekend so I can hopefully get it finished & fitted.
Again thanks for all the replies, very much appreciated. Thumbs Up
PostPosted: 23:42 - 14 Feb 2012    Post subject: Reply with quote
That round brass thing in the middle is the emultion tube. Push it out upwards and make sure the cross-drillings are not blocked. You might need to screw a small bolt into it to tap against.
Where the mixture screw is mangled it looks like there is some remnants of copaslip around the hole. Using copaslip on brass screws in an alloy housing can cause galvanic corrosion and seize the screws solid within a week. Never use copper grease on brass carb parts.
Robby
Dirty Old Man
PostPosted: 07:08 - 15 Feb 2012    Post subject: Reply with quote
When a mixture screw has been mangled like that on a 125 it's often down to an owner thinking that it will alter the mixture across the whole range of operation. This is incorrect, the mixture screw only affects the mix at idle.
Generally the sort of people who do this also think that more fuel = faster, so cock up the rest of the settings - the needle height may be wrong, or the main jet may be the wrong size. They also may have tried to clean the carb by poking steel wire or a pin through the jets. This is a bad idea, the brass is easily scratched and a small scratch can make a big difference in the fuelling.
The new carb looks pretty good, the shit in the float bowl will clean up. Be sure to fully remove the mixture screw and squirt carb cleaner or compressed air (I prefer carb cleaner for this job) into the recess. Use the plastic straw and poke it well into the hole, then keep your eyes well out of the way. It terminates in a very small hole that is easily blocked, and will lead to a weak idle and popping on the overrun.
Fit an inline fuel filter when you reassemble it, preferably a paper element type. They capture any debris from the tank, but more importantly they get stained by said debris. Provides a good indication of how dirty it is inside the tank.
Don't chase electrical phantoms until you have eliminated the carb being a problem. If it starts ok, and runs ok up to a point, an electrical problem is less likely, particularly inside a sealed component. A corroded earth is more likely if you start chasing electrical problems.
As for thoughts about the coil being dodgy, knackered coils, which are fairly uncommon - I have plenty of 30 year old ones doing fine - tend to break down due to heat, not load. The test would be to start the bike up, right straight off, and try to get up to speed. If the problem occurs, the coil is unlikely. If the performance gradually drops off as you ride and the coil gets hotter, then the coil could be suspicious. Always clean the earth points, paying particular attention to the coil mounting points, before replacing the part.
Tl;dr electric components are tough and rarely give trouble. Corrosion or a previous owner's bodges are far more likely causes for electrical trouble.
dungbug
PostPosted: 11:59 - 15 Feb 2012    Post subject: Reply with quote
Thanks Pete, so the emulsion tube comes out towards the top of the carb (?) I was looking at the pin on the left handside & wondering how to remove it.....Presumably I'm not meant to. Very Happy
dungbug
PostPosted: 12:11 - 15 Feb 2012    Post subject: Reply with quote
Thanks Robby, I did try to fit an inline filter (used to use them on my old VW's) but the distance between the tap and the carb is very short & I found I couldn't get a filter in place without the pipe kinking or there being a big downwards loop in the pipe between the tap & said filter. I wasn't sure if fuel would struggle to get to the carb like this as there's no fuel pump pulling the fuel through, I might be way off the mark with that, it just didn't 'look' right when I did it.
It does struggle to get up to speed first thing so as you say the carb is probably the suspect more than the coil, I've never been able to get the bike to use the choke happily from cold. A small amount of choke makes no difference and more choke makes it very laboured when pulling away, it'll hunt for a bit and will only clear if I pull the clutch in and give it some revs (over fuelling maybe?).
The problem has got worse since the diaphragm was replaced, prior to this the top end was around 50mph which would then drop down to about 45mph(ish). Now the running is generally poor, it'll get up to 50mph then hunt a bit (almost like a misfire) upto 55mph. The engine note then changes to a 'flat' sound and the speed drops away. If I close the throttle completely, give it a few seconds and open it back up the engine note sounds like it should and the bike will pull very well.........Until it does it again further down the road.
I think I'll get the new carb indoors tonight and finish cleaning it up (no lights in the shed), hopefully I can have it ready to fit this weekend.........Just need to remember where my Haynes went as it hasn't been seen since I cleaned the shed up the other week, I just need the factory settings from it so I can set the carb as it should be. Thumbs Up
dungbug
PostPosted: 21:29 - 15 Feb 2012    Post subject: Reply with quote
Emulsion tube is now out, didn't take much to get it out but it was pretty grubby. Sprayed some carb cleaner through it and quite a few bits of dirt came flying out, float bowl now cleaned up so it's pretty much ready to be put back together now. Just want to check the float height before its fitted to the bike, any idea what the height for the float should be? Couldn't find the Haynes in the shed. Rolling Eyes
PostPosted: 06:14 - 16 Feb 2012    Post subject: Reply with quote
A quick search online suggests the GS125 (same engine) should be 24.5mm.
Turn the carb upside down with the float and needle properly installed and measure the distance from the gasket sealing face to the 'highest' part of the float.
dungbug
PostPosted: 08:08 - 16 Feb 2012    Post subject: Reply with quote
Cheers Pete. Thumbs Up
Robby
Dirty Old Man
PostPosted: 07:00 - 17 Feb 2012    Post subject: Reply with quote
I don't think you mentioned the diaphragm change before.
2 things are likely:
1. The new diagphragm isn't any good. Hold it up to the light and look for holes, the tiniest pinhole will stop it from working.
2. It was fitted properly and wasn't sealing all the way around. It may have a tiny tab somewhere that locates into a little slot, make sure this lines up.
I despise carbs with diaphragms.
dungbug
PostPosted: 07:16 - 17 Feb 2012    Post subject: Reply with quote
The diaphragm was a new genuine Suzuki part, a friend works for Suzuki so he was able to get it at a discounted price (sort of). There is a small 'half moon' tab on the diaphragm and a corrsponding notch on the carb body, both are lined up together and the diaphragm is seated in the groove.
You're not thr first person to tell me that diaphragm carbs are a PITA. Rolling Eyes
The last post was made 13 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 136.14 Kb
