Fuel Taps
Skudd
PostPosted: 07:53 - 14 Feb 2012    Post subject: Fuel Taps Reply with quote
This isn't for a bike but my generator so I hope you lot don't mind. I have an Aldi special generator, it does what I need it to do. The problem with it is it's fuel tap. It leaks, poor quality is the main reason. It drips through the tap and rubber gasket.
I was wondering, if I was to put a bike tap on it would it matter what size the tap was? It is gravity fed and I was going to use the fuel pipe it came with if I could. It is only to start stop the fuel flow. At the moment I can't leave fuel in the tank of the unit as it leaks out.
fatjames
PostPosted: 09:32 - 14 Feb 2012    Post subject: Reply with quote
If the flow rate is the same, it should work. I can't see why not?
Skudd
PostPosted: 12:13 - 14 Feb 2012    Post subject: Re: Fuel Taps Reply with quote
Obviously covdude does mind and rated as such. Silly little boy.
P.
PostPosted: 12:30 - 14 Feb 2012    Post subject: Reply with quote
Using a bike one should be fine.
You could possibly use a pretty beefy one from something else if you are worried about flow rate.
Skudd
PostPosted: 12:42 - 14 Feb 2012    Post subject: Reply with quote
I was thinking that having a greater flow wouldn't harm things and it would be the carb that sorted it all out.
The last post was made 13 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 3.67 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 43.65 Kb
