| johnsmith222 |
 johnsmith222 World Chat Champion
 Posted: 13:20 - 14 Feb 2012 Post subject: Checking Power Supply for Line 6 Podxt Live. |
Hi guys.
My podxt live died years ago. I have tried replacing the fuse with no luck. I have a multimeter but I'm only used to using it on bikes for checking continuity, battery voltage, checking fuses etc.
How do I check if this is working?
https://www.long-mcquade.com/files/4141/lg_PX2.jpg
It is the UK power supply so has a uk plug on the end.
Thank you for any help! |
| Hobes |
 Hobes Crazy Courier
 Posted: 21:06 - 14 Feb 2012 Post subject: |
Not a massive help here I appreciate, but you can buy replacement power supplies for an XT Live off ebay for about £10. Not a massive loss if it doesn't sort the problem. ____________________ Current: Suzuki DRZ400sm (07) https://fbc.spruz.com
XBL: Matt Hoban
PSN: MattHoban |
| herulach |
 herulach World Chat Champion
| Hobes |
 Hobes Crazy Courier
 Posted: 21:22 - 14 Feb 2012 Post subject: |
Pretty sure they're just a 9v output. ____________________ Current: Suzuki DRZ400sm (07) https://fbc.spruz.com
XBL: Matt Hoban
PSN: MattHoban |
| mistergixer |
 mistergixer World Chat Champion
 Posted: 21:24 - 14 Feb 2012 Post subject: |
Shouldn't be a problem to use your multimeter to check that the PSU is working.
Basically, plug the PSU in, switch the multimeter on and set to the DC power range - I've no idea what the output of the PSU is, but I'd hazard a guess it's in the 9 - 24VDC range, so set your meter to whatever is appropriate.
Stick one of the probes down the middle of the output plug, stick the other on the metal outside of the plug. If the probe won't fit down the centre, use a piece of wire, solder etc to connect from the probe to the plug.
If the PSU is working, you should see the voltage displayed on the meter (if it shows as a minus voltage, then you've got the probes the wrong way round - centre live vs centre ground).
If it's dead, replace it, if it's not.....the problem lies within the Pod XT thingy.
 ____________________ Space Monkey #7
Mistergixer's videos on YouTube |
| Ariel Badger |
 Ariel Badger Super Spammer
The last post was made 14 years, 279 days ago. Instead of replying here, would creating a new thread be more useful? |
