Yale lock swap ...
WannaBeDude
PostPosted: 20:06 - 18 Feb 2012    Post subject: Yale lock swap ... Reply with quote
I have no keys for lock in pic, how do i swap the lock without making a pigs ear of it, and is this lock the right replacement.
https://www.ebay.co.uk/itm/160736359257?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
https://i37.photobucket.com/albums/e53/covdude/2012/IMG_0155.jpg
https://i37.photobucket.com/albums/e53/covdude/2012/IMG_0156.jpg
angryjonny
PostPosted: 20:39 - 18 Feb 2012    Post subject: Reply with quote
Do you have access to the other side of the door by other means?
Marmalade
PostPosted: 20:48 - 18 Feb 2012    Post subject: Reply with quote
Piece of cake. Just remove the handle unit from inside then 2 screws will hold the yale lock part on that you will see once handle unit it removed.
Hardest bit will be cutting the screws to length or just use the old ones.
angryjonny
PostPosted: 21:04 - 18 Feb 2012    Post subject: Reply with quote
Yeah, on the assumption that you have access to the other side of the door, assembly is the opposite of removal. Can't remember the precise process but I did it once with just a screwdriver when I was about Covdude's age (which I estimate to be late-teens or twentyish).
The replacement barrel on Ebay should fit. You may need to use a dremel to cut the rod sticking out the new barrel to the right length, or a strong pair of pliers may do it. Basically, the rod from the barrel runs through the bolt mechanism into the handle on the inside of the door - aside from that the two halves are not connected.
WannaBeDude
PostPosted: 21:23 - 18 Feb 2012    Post subject: Reply with quote
No access, gona buy a yale lock and get bro to do it. Rolling Eyes
Im-STiG
PostPosted: 21:54 - 18 Feb 2012    Post subject: Reply with quote
Are you able to 'persuade' a flat screwdriver gently under the bottom of the plate and manipulate the lock around?
Marmalade
PostPosted: 21:57 - 18 Feb 2012    Post subject: Reply with quote
Drill it out. Straight into the key hole.
You can't go too far unless you go at it like a total numpty.
Raffles
PostPosted: 22:46 - 18 Feb 2012    Post subject: Reply with quote
I don't know who's property you are planning to steal but this short clip may aid you:-
https://www.youtube.com/watch?v=JZJe23UD8wU&feature=related
WannaBeDude
PostPosted: 22:54 - 18 Feb 2012    Post subject: Reply with quote
Sorry, my locks not wooden and i don't live in Egypt. Smile
Ariel Badger
PostPosted: 00:13 - 19 Feb 2012    Post subject: Reply with quote
Picking locks is not hard, do you have legal access to this premises? If you can not get in smash a window.
DrDonnyBrago
PostPosted: 01:43 - 19 Feb 2012    Post subject: Reply with quote
Just thought I'd add - I have that ladder.
That is all.
WannaBeDude
PostPosted: 02:04 - 19 Feb 2012    Post subject: Reply with quote
I've just checked the hallway, it's defo still there. Shocked
The Disapproving Brit
PostPosted: 10:47 - 19 Feb 2012    Post subject: Reply with quote
If you have an old Yale key, you might get lucky using the bump method - stick the key in most of the way, then bang it full in while simultaneously applying turning pressure. If you're lucky, it will knock the pins up to the right point, which will allow the key to turn.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
Cunnington
PostPosted: 11:01 - 19 Feb 2012    Post subject: Reply with quote
Search bump+yale on youtube. If you can file down an old key it is a piece of piss - if not google it and buy one.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
Im-STiG
PostPosted: 13:10 - 19 Feb 2012    Post subject: Reply with quote
Can I just ask, for clarity, since you're already indoors I presume you do have legal access, but where's the actual key, and why can't you get it?
I love the motivation get in 'without proper means'. Laughing
WannaBeDude
PostPosted: 13:55 - 19 Feb 2012    Post subject: Reply with quote
For clarity, it's all above board and perfectly A OK.
The key for it, is on my keyrack in my living room, i'd just thought it would be better to break in. Smile
Dr. DaveJPS
PostPosted: 17:11 - 19 Feb 2012    Post subject: Reply with quote
if you can't drill it, use a chisel and snap that outer ring (the thing that looks like a key guard) insert screwdriver and apply force until bolts snap.
www.davejps.com
Speed
PostPosted: 10:30 - 20 Feb 2012    Post subject: Reply with quote
If you have an anti-bump cylinder then it’s a no go. One way to get in is to use a sheet of plastic and slide it down the gap between the door and the frame (I’ve used a margarine lid in the past. BTW I’m not a criminal, just been in the trade for a fair few years lol). This should hopefully slide across the latch and get you in. If that isn’t possible then the other method to get into that rim cylinder is drill a hole in between the plug and outer face plate (in-between the Yale branding and the where you place your key into, on that line) This will run along the shear line and remove all of the pins. Give the hole a good clean out to make sure there’s no pins/springs in there and turn with a flat head screw driver. When you replace the rim cylinder, cut the tail piece down to the length of the old one and just double check the lock works perfectly before you shut the door Laughing Thumbs Up
WannaBeDude
PostPosted: 16:39 - 20 Feb 2012    Post subject: Reply with quote
Thumbs Up i maintain his laptop, he can do the door .. Cool
Ariel Badger
PostPosted: 21:55 - 20 Feb 2012    Post subject: Reply with quote
Am I being thick? You have the key in your living room so why not take it off the keyrack and use it?
WannaBeDude
PostPosted: 22:02 - 20 Feb 2012    Post subject: Reply with quote
Was answering this bright sparks ?? on where the key is, and even worse - if lost - where is it ! Idea
The last post was made 14 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 113.04 Kb
