| Suffolk |
 Suffolk Derestricted Danger
| pinkyfloyd |
 pinkyfloyd Super Spammer
 Posted: 10:30 - 19 Feb 2012 Post subject: |
Oddly enough changing gears seems like a nightmare until you actually get used to it and before long it will become second nature. When I was not on the bike I would "practice" while on the bus, in a car, what ever, Sure I may have looked a pillock but at least when I got onto the bike it was easier to replicate the actions.
You already know the basics of how to do it, all it takes is practice so sit and practice while sitting on the computer reading this. Release your throttle, pull your clutch in, shift up and then release the clutch and throttle on gently. You would be surprised at how easy it all becomes after a few days on the bike.
Changing down is the same. When on the bike listen to the engine, it will tell you when you need to change down. Release the throttle, listen to the engine, when the pitch gets very low, clutch in, change down, gently feed the clutch out. Some blip the throttle to match the revs to the gearing. Thats just a little twist of the throttle just before you release the clutch but focus on the basics first.
Practice everywhere, watching the bikes on TV. Car, taxi, etc. All will help make the motions second nature. After that you wont even think about it. ____________________ illuminateTHEmind wrote: I am just more evolved than most of you guys... this allows me to pick of things quickly which would have normally taken the common man years to master
Teflon-Mike:I think I agree with just about all Pinky has said. |
| grant965 |
 grant965 Brolly Dolly
| superleeds76 |
 superleeds76 Renault 5 Driver
| AlexW |
 AlexW Spanner Monkey
| _Iain_ |
 _Iain_ Banned
 Posted: 13:52 - 19 Feb 2012 Post subject: |
And no points whatsoever for trying to catch the boy racer infront & pressing the pedal down instead of up...  ____________________ Please be aware that the above post may be full of complete nonsense.
| Alpha-9 |
 Alpha-9 Super Spammer
 Posted: 09:45 - 20 Feb 2012 Post subject: |
Gears were something I worried about the most before I rode a bike
Now i'm riding gears are the last thing I think about
don't sweat it, you'll get used to it in no time  ____________________ Fzr-600 1999 |
| arry |
 arry Super Spammer
| Alpha-9 |
| J.M. |
 J.M. World Chat Champion
 Posted: 14:24 - 20 Feb 2012 Post subject: |
| _Iain_ wrote: | And no points whatsoever for trying to catch the boy racer infront & pressing the pedal down instead of up...  |
That's helpful actually! If you're sitting in a higher gear you may want to kick down one or two so you have the acceleration there that you need.
Gear changing is easy really, and it becomes second nature very fast.
First of all get the bike in to first gear. Your gears are like below on a standard bike:
1
N
2
3
4
5
6
Neutral is actually half a click between 1 and 2. Whilst riding it is difficult to get in to neutral and you only need to click it up once to get in to second gear.
First of all sit on the bike in first gear, slowly let out the clutch until the bike starts to creep forward and then hold it there. Do this a few times as it will help you to get used to the biting point of the bike. As you start to feel a little bit more confident, get the biting point and then add a little bit of throttle. Not too much, just gently, and keep adding it gradually whilst letting out the clutch until you are fully off of the clutch. You are now riding in first gear.
So you're on a 125. You hit 15-20mph and you want to change up to second gear.
Pull in the clutch and roll off the throttle in one movement. When the clutch is fully pressed in you want to kick it up in to second gear. You should hear/feel a reassuring click. Slowly and gradually let the clutch back out whilst you slowly and gradually roll back on to the throttle.
You are now in second gear. You can usually take this gear to 30mph, but you should probably change up to 3rd.
Pull in the clutch and roll off the throttle in one movement. When the clutch is fully pressed in you want to kick it up in to third gear. You should hear/feel a reassuring click. Slowly and gradually let the clutch back out whilst you slowly and gradually roll back on to the throttle.
You're now in 3rd gear.
You start slowing down and the bike feels a bit slugish and you're at a low RPM. You now want to change down a gear.
Pull in the clutch and roll off the throttle in one movement. Kick down a gear in to second, you should hear/feel the reassuring click again. You're now in second gear. Do the same as what you did earlier. Slowly and gradually release the clutch and roll on the throttle at the same time.
You want to slow down further, or stop, so you're going to need 1st gear.
Pull in the clutch and roll off the throttle in one movement. Kick down a gear in to first, you should hear/feel the reassuring click again. You're now in first gear. Do the same as what you did earlier. Slowly and gradually release the clutch and roll on the throttle at the same time.
You're now in first gear. If you're stopping remember to fully pull in the clutch so that the bike doesn't stall.
Let's imagine that you're home now, you want to get off the bike, so you want to use neutral. From first gear, pull in the clutch fully and really lightly press up the gear lever until you feel a much lighter click. This should now be in neutral. To test it gradually let out the clutch to the biting point. If your bike moves forwards then you're still in gear and try again. If the bike doesn't move and the clutch is fully out then you are in neutral. You can now turn off the engine and get off the bike
That's as basic as I can explain it. But you will figure it out for yourself and you will get the hang of it very quickly. ____________________ 2004 R1 & 2018 XSR900 |
| Alpha-9 |
 Posted: 15:00 - 20 Feb 2012 Post subject: |
| J.M. wrote: | | _Iain_ wrote: | And no points whatsoever for trying to catch the boy racer infront & pressing the pedal down instead of up...  |
1
N
2
3
4
5
6
Is there a reason why I might find it 'easier'?
Like 4 times now i've been swithicng to 2 and suddenly REEEEEOWWWW NEUTRAL TIME
Whyyy?
Yet sometimes i'll stop like k parkup time, neutral here we go, nope, nope, nope, second, nope, first, nope, stall, fuck it, i'll start with the clutch down.
Y U SO RANDOM ____________________ Fzr-600 1999 |
| J.M. |
 Posted: 16:07 - 20 Feb 2012 Post subject: |
| Alpha-9 wrote: | Is there a reason why I might find it 'easier'?
Whyyy?
Y U SO RANDOM |
Try kicking it up harder, don't just tap it. With gears 2->6 tapping it up seems to work okay, but with 1->2 you want to be sure to give it a firm kick up.
I don't know as I have never tried it, but I think that some people have said if you are moving the bike forwards gently it can be easier to get it in to neutral? I'm not sure as I've never really tried it. I'm not sure how you would go about it either really unless you chose neutral whilst coasting to a stop.
Now, I'm definitely not a mechanical guy - but from what I've read it could be in need of an oil change? Again, not sure on that so hopefully someone with more knowledge will come along and help you.  ____________________ 2004 R1 & 2018 XSR900 |
| Alpha-9 |
 Posted: 16:18 - 20 Feb 2012 Post subject: |
| J.M. wrote: | | Alpha-9 wrote: | Is there a reason why I might find it 'easier'?
Whyyy?
Y U SO RANDOM |
Now, I'm definitely not a mechanical guy - but from what I've read it could be in need of an oil change? Again, not sure on that so hopefully someone with more knowledge will come along and help you.  |
Hmm I think you're right actually, usually have to finger the clutch a bit to get into neutral when still else, I suppose because it's still sort off changing gear and needs da force
Yeah maybe I just need to be less pussy footed
hopefully it doesnt need new oil! I found the oil thing the other day and had a looky at the little dip stick thing, seemed nice and oily without being nasty
https://s17.postimage.org/veagznfbz/2005_Yamaha_YBR_125_1.jpg
I know that's the 2005 model and mines 2009, but same place
In fact that older model looks like its got better tyres  ____________________ Fzr-600 1999 |
| Sako |
 Sako World Chat Champion
| Alpha-9 |
| Scythe |
 Scythe Crazy Courier
| Taught2BCauti... |
 Posted: 18:55 - 20 Feb 2012 Post subject: |
I have always found it easier to get into Neutral from 1st gear, than from 2nd, but it takes the same amount of upward movement to go from 1st to 2nd as it does to go from 2nd to 3rd, etc.
When accelerating and changing up, pull the clutch and wait for the revs to drop before shifting.
Shifting down, pull the clutch and increase the revs a bit before shifting. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| arry |
 arry Super Spammer
 Posted: 19:18 - 20 Feb 2012 Post subject: |
| Alpha-9 wrote: |
Shift, WITHOUT THE CLUTCH?
BLACK MAGIC!
I actually did that once or twice without meaning to i think o.O
but i jsut figured i jsut caught the clutch or it only needed a tiny pull  |
Nah, you can shift up no bother without the clutch; it's actually smoother than with the clutch if done right, hence I do it a lot if I'm carrying pillion |
| Suffolk |
 Posted: 19:45 - 20 Feb 2012 Post subject: |
1
N
2
3
4
5
6
That's as basic as I can explain it. But you will figure it out for yourself and you will get the hang of it very quickly. |
Thanks for this, really helpful  |
| swampy |
 swampy World Chat Champion
 Posted: 20:51 - 20 Feb 2012 Post subject: |
I guess form your nick that you have some ties to Pompey, only if you're around here, I'm quite happy to go out to a carpark (or rideout) with ya to see if I can offer some tips in the real world.  ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
| Teflon-Mike |
 Posted: 21:56 - 20 Feb 2012 Post subject: |
ON CBT you will have practiced finding the clutch 'bite point' but with the bike stationary.
On the move, the loadings on the clutch can make the actual bite point move about a bit.
At a stand still, it takes quit a lot of force to get the mass of bike and rider initially moving; whereas once it IS moving takes less force to just keep it moving.
Its the 'sliding the washing machine under the counter' principle.... takes a bit of a shove to get it to slide, but once going slides pretty easy.
Same thing during gear changes.
When you pull the clutch 'in', when rolling, it will actually take more lever movement to make the plates disengage drive, than when the bike is stationary, and when you release it again, it will start to transmit force before it is as far back out.
Next; Little bikes will not flatter clumsy gear changes.
The little engine, making perhaps a 1/4 the power at peak of relatively tame 500, will be geared lower to get the same 'force' to get you moving, so it will run out of revs and demand an upshift at a much lower speed than a big bike.
Typically, something like an EN or YBR will be maxed out in first at possibly less than 20mph... max out a GS500 in first and you are possibly pushing 40 or more. So your first gear change comes up sooner....
'Momentum', wot keeps you moving when there is nothing to positively shove you along, is Mass x Velocity.
So your little 125, weighing 120Kg instead of 200Kg, and needing a gear change at maybe 15mph instead of 30, does NOT have very much of the stuff!
And if you take too long, with the clutch hauled in and no drive, you wont coast as far, and you will loose more precious speed, before you get the drive back on.
You Dont want to 'Rush' or 'Snatch' the change, just be aware, that your little bike, will not flatter you... and let you know in no uncertain terms when you are making a muff of it!
This is good! If you can make nice smooth changes on a tiddler.... you can do them on ANY-BLUDY-THING!
Now; clutch control is important, but TIMING is all.
Boot the box, before you have the clutch in, bike will lurch. Haul clutch before you're off the gas, bike will scream and dive.
Its all about the co-ordination.
And to get that, PRACTICE - PRACTICE - PRACTICE, there is no substitute!
Find a quiet estate and practice. Take your time getting the co-ordination, and practicing getting the shift nice and smooth, and unhurried.
DONT worry, if at first, slow changes mean that the bike labours as you get the clutch out in the higher gear, having let it roll too long and lost a bit too much speed... just work on the smoothness and precision and getting that clutch and throttle timing, balancing the speeds.
Important thing is the throttle.
As you let the clutch in to change gear, unless you roll off, the engine revs will rise.
So natural tendancy is to let the throttle RIGHT off, to stop it screaming;
but then as you start to let the clutch back out, the load will make the revs 'drop', and you have to get the throttle open again, or you will have engine braking from the closed throttle,
and you will be doing the 'Learner Lurch' after the shift as the bike dips under engine braking as the clutch goes out, and then have to accelerate to get the thing back to speed.
So take your time, and practice getting that 'feel' for both the clutch and the throttle, thats not just governing the engine speed, but the load as well.
TIP: dont be too timid and try practicing from a walking pace, going between 1st and second, you NEED some speed in order to have reason to change gear, as well as to give you the momentum to coast through the time you have no drive with the clutch in.
YBR will be comfy enough on 20-30mph roads doing 20mph in 2nd or third, so to keep speed, and momentum up, try practicing 2nd to 3rd shifts and 3rd to 2nd down shifts, to build confidence.
Also avoids the hazard of the unintended 'Neutral' going through from 1st to 2nd.
As far as shifts to Neutral are concerned... I find that its more reliable to bang all the way down the box to 1st, to be sure where I am, then snick the half shift into N.
And TIP: when trying to snick N; it can help if you have a LITTLE drag on the shafts for it to actually latch into the slot. So hold the bike back on the brake, and just let he clutch drag a TINY bit to put some tension on the cogs as you snick it into the middle position.
Now, a lot to ponder, but dont sweat it too much. Probably wont make so much sense until you go do.
So Stop Thinking - Start Riding,
and go practice 2nd to 3rd, and 3rd down to 2nd.... get the road speed up, and the 'rush' to make the change down!
Have FUN! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| karoshi |
 karoshi Brolly Dolly
 Posted: 21:57 - 20 Feb 2012 Post subject: |
| J.M. wrote: | Whilst riding it is difficult to get in to neutral and you only need to click it up once to get in to second gear. |
You Sir, do not ride a Kawasaki do you?
Whyyy? |
false neutrals, when you're going for 2nd you are passing through neutral, if your gearchange doesn't fully click 2nd gear in it can bounce out (and into neutral) as the pressure/torque from the drivetrain comes back in.. gets more common the older your oil is, or as your gearbox components wear in
| Alpha-9 wrote: | Shift, WITHOUT THE CLUTCH?
BLACK MAGIC!
On my bike i'll usually go through 2>3>4>5>6 without using the clutch but 1st up to 2nd and when coming back down the box i'll usually use the clutch because i'm not pushing myself fast enough to need to change that precisely. ____________________ Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd |
| J.M. |
 Posted: 22:02 - 20 Feb 2012 Post subject: |
| pinkyfloyd |
| Baisemontchou |
 Baisemontchou Scooby Slapper
The last post was made 14 years, 270 days ago. Instead of replying here, would creating a new thread be more useful? |
