End cans on a restricted bike..
Rncv
PostPosted: 11:20 - 19 Feb 2012    Post subject: End cans on a restricted bike.. Reply with quote
Hi guys,
Yesterday night i was driving home and was pulled over by the police. Apparently there was a different bike messing about and they thought it was me, fair enough.
Anyways, they did all the paperwork checks and inspected the vehicle and said to me that my end can was illegal. I have a viper end can, it has no markings on it apart from the normal "viper" so i get a 30 quid fine...
Also the guy said to me that it affects the restriction?... and that the bike could well be over 33BHP..
I just spent over 600 quid getting the bike sorted out, which included fitting the down pipes and end can (i gave them both the viper and a standard can) and they said nothing to me about the viper can effecting the restriction...
So can anyone help here? if they know anything about it.
All the best,
Rob.
Current: 01' Bandit 600, 92' Goose 350
Previous: Lots!
grant965
PostPosted: 11:25 - 19 Feb 2012    Post subject: Reply with quote
I think that is complete BS, for an end can to be illegal in the UK it has to be stamped 'race use only' or 'not for road use'. They no longer have to be stamped with standards, BSAU or something similar ???
Also, am i right in thinking that your bike could actually been down on power if its a straight swap because you may need to adjust the mixture? Either way Id ask for proof.
Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
Rncv
PostPosted: 11:33 - 19 Feb 2012    Post subject: Reply with quote
I thought the same, that all race cans are marked. Although I'm unsure about having a BSAU stamp.
Even if its restricted it shouldn't make a difference? there restriction is in the carbs so will only allow 33bhp regardless of the end can?
it was a black road traffic car, so couldn't they have seized the bike if they thought it wasn't restricted to 33bhp and thought it was slightly more?
Rob.
Previous: Lots!
lihp
PostPosted: 11:52 - 19 Feb 2012    Post subject: Reply with quote
It is possible that the new system could give you a couple of bhp. And if the restriction was done on a dyno to 33 then you changed system. Especially the manifold then it could be 1 or 2 over.
This is unlikely but is possible.
As for the end can, I believe it does need the bs number stamped on it, I'd contact viper and ask if its a road legal exhaust. If they say it us, then contest the fine.
Rncv
PostPosted: 11:57 - 19 Feb 2012    Post subject: Reply with quote
The restriction was done by a garage, hasn't been on a dyno.
the down pipes are also stainless ones, whether that makes a difference too?
I'll see if i can find out where the nearest dyno center is and get it booked in.
Previous: Lots!
PostPosted: 11:59 - 19 Feb 2012    Post subject: Reply with quote
Managed to get friends GSXR750WN restricted to 33hp, had it dyno'd...was well about 33hp. Had full stainless D&D exhaust and a different filter, so it could be over Laughing
Unlikely though, what is it?
Rncv
PostPosted: 12:03 - 19 Feb 2012    Post subject: Reply with quote
Sorry, was it under or over 33bhp with those mods?
Its a FZR600.
Rob.
Previous: Lots!
PostPosted: 12:30 - 19 Feb 2012    Post subject: Reply with quote
Sorry, VCA reckon that C&U requires a "e" or "E" mark, BS AU mark or "equivalent international standard marking".
An unscrupulous owner might just stamp "e13" or similar on a race exhaust, since the mark is what matters. It was on there when I bought the bike, officer. Whistle
About the restriction, it's up to them to prove that it's over 25kW, not for you to prove that it's not.
Pay for a dyno run if you want, but all that will give you is an estimate of crank power. If Plod do make an issue of it (sounds like they didn't really care) then their estimate may be wildly different anyway.
All that said, WTF are you doing spending money pimping a restricted bike? Have you told your insurer about your "go louder" exhaust?
Amreet
PostPosted: 12:38 - 19 Feb 2012    Post subject: Reply with quote
Yes an aftermarket exhaust kit could well lean out the engine a bit giving a couple more BHP and that is actually a reasonable assumption of the officer,
Did the garage do the pipe and the restriction at the same time? were they the same people?
If it was different people/different time then in fairness it is your responsibility to check otherwise, if you've still got the bike I would do something now,
If the garage did both jobs with the same people at the same time get back there and check they took the exhaust into consideration,
It may be worth getting it dynoed, doesn't cost the earth and it's peace of mind PLUS something to tell the police to bugger off with,
If it is over 33bhp then you could either look at up-jetting to bring the power down or put the original exhaust system back on for the rest of the restriction period, keeping your new system nice and fresh in the garage and then treat yourself to a derestriced AND nicer sounding bike when the time is up
PostPosted: 12:55 - 19 Feb 2012    Post subject: Reply with quote
Sorry, spastic moment.
Was ABOVE 33hp...by a considerable amount. 8hp at the wheel Laughing
Rncv
PostPosted: 13:05 - 19 Feb 2012    Post subject: Reply with quote
Fair enough.
The garage did the restriction and fitting of the exhaust system at the same time yes.
I'm going to look in to getting a dyno run sorted out, if not every time i see a police car I'm going to be worrying about everything.
I'm thinking of spending a few hundred quid and getting a bros 400 and riding that around for 2 years and just sell the FZR as it is causing more hassle than its worth.
I will talk to the bike garage and see what they say about it.
I'm not pimping it, i brought the bike for 175 and it needed some work doing to it.
It had a GSXR 750 end can on it before, and the down pipes were chopped/ re-welded in so many places it required new pipes. I got the pipes for 50 quid inc postage and the end can was free from my uncle.
And yes its declared, including stainless brake lines.
i will probably end up putting an original silencer back on, just for peace of mind.
Previous: Lots!
PostPosted: 13:16 - 19 Feb 2012    Post subject: Reply with quote
I really have no idea why owners trusts that a "restrictor" does actually bring the power down to 25kW.
FI International in particular demonstrably employ a bunch of unscrupulous... persons. If they're prepared to be so generous with the truth when selling their products, why believe that their products even do what they claim?
But then again, a dyno run just estimates the power. The whole thing is a huge mess, no wonder so many people don't even bother getting their bikes restricted to the legal limit - whether they realise it or not.
PostPosted: 16:16 - 19 Feb 2012    Post subject: Reply with quote
It was a genuine FI kit costing £149 and £99 for installation Laughing It came out soon after it was dyno'd.
It got my bike at a shade over 114 at the wheel...so its roughly right I guess Laughing
Rncv
PostPosted: 18:33 - 19 Feb 2012    Post subject: Reply with quote
So all in all,
Restricting a bike is more hassle than its worth.
its better to get a sub 33bhp standard plod along, Which is still a big step up from your average 125.
Rob.
Previous: Lots!
rac3r
PostPosted: 21:37 - 19 Feb 2012    Post subject: Reply with quote
My Monster 620 was restricted and had 'race use only' Termi's on it
Chequered Flag
PostPosted: 21:49 - 19 Feb 2012    Post subject: Reply with quote
That's the route I went, but many people get through their 2 year purgatory without any hassle on restricted or 'restricted' bikes, there's really very little chance of it being an issue.
PostPosted: 21:55 - 19 Feb 2012    Post subject: Reply with quote
Possible that the can and / or down pipes could result in the bike putting out more power than it is meant to when restricted. Also possible it is putting out less power (some down pipes are pretty poor).
However a good chance the difference will be small. And given that the restriction law likely means a 25kW limit at the crank and that a typical dyno is only going to give a rear wheel figure it is fairly likely that the difference is within the margin of error of guessing the crank power from the rear wheel figure.
No, you are confusing legality with the MOT rules. MOT rules are far slacker. Strictly speaking it is an offence to make the exhaust louder than standard even if it is still within the legal limit.
PostPosted: 09:29 - 20 Feb 2012    Post subject: Reply with quote
Mmm. RTA 1988 Section 42 "Breach of other construction and use requirements".
C&U 54 Silencers
VCA motorcycle regulations specify the required e, E or BS markings.
Whether that tangled web weaves enough for a conviction or not is anyone's guess. But if you don't fight the law, then the law wins by default.
PostPosted: 10:05 - 20 Feb 2012    Post subject: Reply with quote
All well and good until you find the previous owner has put aftermarket pipes on and it now makes more than 33hp.
I wonder if a near-figure road side dyno has ever been contested.
It's an incredibly vague 'science'. Many tuning places will inflate the figures on their own dynos to make people feel better generally.
PostPosted: 11:39 - 20 Feb 2012    Post subject: Reply with quote
Given that nothing on there allows anything for a normal reasonably new bike (ie, excluding self builds) which is noisier than standard or which doesn't have the relevant stamps it would seem there is plenty for a conviction.
sickpup
Old Timer
PostPosted: 12:29 - 20 Feb 2012    Post subject: Reply with quote
Another Steve Farrell story plagiarised from the pages of BCF. Thumbs Up
Moxey
PostPosted: 12:51 - 20 Feb 2012    Post subject: Reply with quote
*In a dodgy foreign accent* Very Interesting......... Thinking
I assume there is some greater penatly for falsely re-branding an exhaust I presume? Or just feign ignorance ' had the mark and looked very much like an exhaust to me, officer'?
PostPosted: 13:00 - 20 Feb 2012    Post subject: Reply with quote
If you were silly enough to admit it and they were feeling nasty then probably be treated as attempting to pervert the course of justice.
And either way still falls foul of:-
Silencers54.—
(1) Every vehicle propelled by an internal combustion engine shall be fitted with an exhaust system including a silencer and the exhaust gases from the engine shall not escape into the atmosphere without first passing through the silencer.
(2) Every exhaust system and silencer shall be maintained in good and efficient working order and shall not be altered so as to increase the noise made by the escape of exhaust gases.
If the exhaust system includes the exhaust valves and ports then the exhaust pipe and silencer is just part of that system, hence changing it so it is noisier falls foul of that.
Moxey
PostPosted: 19:10 - 20 Feb 2012    Post subject: Reply with quote
^Damn Sad
though I am left curious about this, shall not be altered so as to increase the noise made by the escape of exhaust gases.
Is this noise increased from the levels produced by the original OEM system? (do the police have a database containing the required DB level of the original by which to measure an aftermarket system?)
Guessing the onus is on the manufacturer of an aftermarket system or end can to be quieter than the OEM exhaust system which is the measure of such.
PostPosted: 19:17 - 20 Feb 2012    Post subject: Reply with quote
Very much doubt the police have such a database. And never heard of them pursuing anyone on a bike under that rule (they have tried it for cars, trying to prosecute people for using the standard exhaust from a sportier model of the same car).
Given noise tests are complicated to do properly it would probably get messy.
The last post was made 14 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 141.31 Kb
