Restriction Confusion
vertabrate
PostPosted: 19:09 - 19 Feb 2012    Post subject: Restriction Confusion Reply with quote
Hey, I have recently decided that in May (when I'm finally 17) I'm going to go get my full license (I hope). I'm just confused about the restriction after I get my license. I know it has to be restricted to 33BHP but is there also other restrictions such as engine size? Thanks for help Smile
J.M.
PostPosted: 19:14 - 19 Feb 2012    Post subject: Reply with quote
You have a power to weight ratio that you must adhere to, but there is no restriction on engine size.
You could ride a 1300cc bike the day you pass your test so long as it conformed with this power to weight ratio.
The restriction is 33BHP (25kw) and I think the power to weight ratio is 0.16kW per kg.
2004 R1 & 2018 XSR900
Just has to be under 25kW (which is roughly 33hp) and there is a power to weight ratio limit as well.
No limit on capacity. You could have a 25kW 'busa legally.
andyeden
PostPosted: 19:22 - 19 Feb 2012    Post subject: Reply with quote
hi all
i have just bought a gs500e 95 model and is restricted to 33bhp
i am 33 yrs old and i have been told i can just take a 125 cc test and im still legal to ride this bike on that as long as i retake the test after two years is this right Very Happy
PostPosted: 19:27 - 19 Feb 2012    Post subject: Reply with quote
Might not be able to have a Busa, power to weight of 0.16kW per kilo limit or something silly?
Might be OK once down to 33hp, but I think my GSXR just scrapes by?
Scrap that, just looked up specs. With a 2001 Busa at 175hp and 215kg its 0.8~
With it at 33hp, which will be absolutely fucking stupid Laughing it comes out at 0.1534 so just under.
Christ, can't imagine how bad that would be Laughing
PostPosted: 19:33 - 19 Feb 2012    Post subject: Reply with quote
More complicated than that.
You can do a test to get a "full" licence in 3 different ways.
Light motorcycle test - you can do this on a bike of under 120cc and it gives you a full licence for bikes up to 125cc / 11kW, but nothing for anything bigger than that.
Restricted licence test - done on a bike of between 120 and 125cc (also min top speed). This gives you a licence for a bike of up to 25kW. After 2 years the 25kW limit is removed, so you have a licence for a bike any amount of power.
Direct access - test done on a large bike (from memory has to be done on a bike of at least 35kW). You can only do this test is you are 21 or more. This gives you a licence for any capacity / power bike.
There is also direct access. This is a test to upgrade a restriced licence to a full licence. Normally for people who have taken the restricted licence test and reach 21 before the 2 year wait is up.
PostPosted: 19:37 - 19 Feb 2012    Post subject: Reply with quote
Oi! You're mixing up metric and imperial. 175hp is 129kW which would be 0.6kW/kg.
PostPosted: 19:44 - 19 Feb 2012    Post subject: Reply with quote
My apologies, its appears nitromors in the house is bad for your brain Laughing
hedgehugger
PostPosted: 20:26 - 19 Feb 2012    Post subject: Reply with quote
andyeden wrote:
hi all
No
You can take your test on a 125 (A2) and be restricted for 2 years, then you can de-restrict the bike.
A CBT runs out after 2 years (allows you to ride 125cc)
If you take the 125 test. You can only ride 125cc or less
Teflon-Mike
tl;dr
PostPosted: 20:54 - 19 Feb 2012    Post subject: Re: Restriction Confusion Reply with quote
At 17 you can obtain a provisional licence with motorcycle entitlement.
You MUST complete a course of Compulsary Basic Training - CBT and obtain certificate of completion to 'validate' the PROVISIONAL entitlement of your provisional licence.
The CBT Certificate has a two year validity, and allows you to ride a 'Learner Legal' motorcycle up to 125cc and 14.5bhp, on L-Plates, without supervision, provided you do not carry a pillion passenger or use motorways.
If you elect to take the motorcycle tests under 'Standard Bike' rules; you must use a bike between 120 & 125cc, capable of 62mph and no more than 14.5bhp.
Passing tests under 'standard bike rules' currently is awarded with a full A-Group motorcycle entitlement, with two year probationary power limit at 33bhp.
You may ride any motorcycle of any capacity you like, but you must ensure that it makes no more than 33bhp, either by design or after market 'restriction'.
Upon expiry of the 2 year restriction, you may ride any bike, of any power. You do not need to take any further tests. (under CURRENT licencing rules!)
If you are over 21 the rules are exactly the same. on the provisional entitlement offered by either a provisional licence or full car licence, you may, on completion of a CBT course and gaining the certificate ride a 125cc/14.5bhp machine on L-Plates for the validity of the CBT Cert.
YOU MAY NOT ride a 33bhp motorcycle, or any other over 125cc or 14.5bhp on L-Plates, WITHOUT the radio-supervision of a qualified, card carrying DAS instructor.
The only rules that are different are that under the Direct Access Scheme (DAS) you MAY ride ANY power/capacity of bike, if under radio supervision of a qualified instructor. AND you may elect to test under the 'DAS' or 'Big-Bike' rules that allow, IF you are over 21 years old to test on a machine OVER 33bhp, and be awarded a full A-Group licence without restriction.
As from January 2013, this is all set to change, under 3rd Directive Legislation. Hence stressing 'Currently'.
vertabrate
PostPosted: 21:24 - 19 Feb 2012    Post subject: Reply with quote
Still confused by all the different answers. So at the moment I have my CBT, when I become 17 I take my theory and practical and once I have both mod one and two I can then go along to ride any bike with the 33BHP and 16KW/KG? So after I complete mod two I would be okay to ride a 250cc if it complies with the restrictions? Cheers guys
GrumpyGuts
PostPosted: 21:32 - 19 Feb 2012    Post subject: Reply with quote
Essentially, yes. If it is 33BHP or LESS, then you can ride it, providing you pass your mod 2 practical. You can get a 400cc bike that is around 50 bhp and restrict it, however insurance companies are twats.
PostPosted: 21:34 - 19 Feb 2012    Post subject: Reply with quote
Yes, pass on a 125 and you'll get an "A <= 25k" license. You can ride anything that generates 25kW or less (and not more than .16kW/kg although that's probably less likely to be an issue).
That means most 250s, Bros 400, many offroad stylees up to 400cc (but watch the power-to-weight on them), or any bigger or more powerful bike, so long as it's restricted to 25kW.
The means of restriction doesn't matter, all that the law requires is that at the time when you're stopped that it not be generating more than 25kW.
Under the current rules, there's no need to sit another test after you've passed on a 'standard' aka 'A2' 125cc bike (121-125cc, no more than 11kW, capable of at least 100kph). You're simply limited to 25kW and 0.16kW/kg for 2 years (no limit on engine size or the original power of the bike[1]), then it automatically upgrades to full A.
However, after it upgrades, the next time you get a new copy of your license, the DVLA will reset the 'From' date to 2 years after your pass date, essentially stealing 2 years of experience off of you.
So since you already have a GS500[2], then why not just pass on a 'large' aka 'DAS' bike, get your full unrestricted license straight away, and take the restrictors out (pretty simple job)?
If you don't have a 125 of your own then it sounds like you'll be going via a training school anyway, and training and testing on a DAS bike will cost you only marginally more than on a 125.
[1] For future reference, under the new rules coming in next January, the new A2 35kW license class does require that a restricted bike didn't generate more than 70kW as standard. Expect Plod to nob this up and think that it also applies to the current "A <= 25kW" licenses that will overlap the new ones by 2 years.
[2] Hilariously, the directgov site shows a GS500F as an example of a generating the required 35kW for sitting a 'large' / 'DAS' test. It actually claims 34.6kW. Doh!
PostPosted: 21:58 - 19 Feb 2012    Post subject: Reply with quote
Depends on the 250, but with the current wheezing examples yes. However the older 2 stroke 250s will produce far more than 25kW / 33hp.
Oh, and it is 0.16kW/kg. 16kW/kg would be a seriously impressive output for anything.
bhinso
PostPosted: 23:37 - 19 Feb 2012    Post subject: Reply with quote
definitely worth getting it out the way. do you have a 50cc on the road by the way, that will help a lot i think with the basic road knowledge (especially if it's geared)
Alpha-9
PostPosted: 09:49 - 20 Feb 2012    Post subject: Reply with quote
andyeden wrote:
hi all
The CBT only lets you ride up to 14.6BHP afaik.
Fzr-600 1999
The last post was made 14 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 96.71 Kb
