Exhaust poping on deceleration...
mr.z
PostPosted: 01:48 - 23 Sep 2004    Post subject: Exhaust poping on deceleration... Reply with quote
allthough it sounds quite cool, like a muffled rally car...
when the bikes really got warm when going down a (very big) hill tonight i could hear the exhaust poping, allot, throttle closed in a reasonably high gear, not very loud but you could hear it allright, if i twist the throttle right back and let go it will pop....
I'm pritty sure there is a small hole in my exhaust, iv'e got some repair pasted i'm going to try at some point, also i suspect my air filter needs changeing, is that another likely culprit?
I was wondering, what is exactly causeing it? assumeing its the hole in the exhaust?
alains
PostPosted: 02:01 - 23 Sep 2004    Post subject: Reply with quote
which bike ?
PostPosted: 02:03 - 23 Sep 2004    Post subject: Reply with quote
Have you got a race can fitted?
PostPosted: 02:06 - 23 Sep 2004    Post subject: Reply with quote
Far as I know it is caused by small amounts unburned fuel in the exhaust system getting mixed with just the right amount of air to make it explode. Under normal circumstances it just burns-up in the hot exhaust, the hole gives extra air to make the mix explosive....of course I could be making that up, I have no definitive proof, just seems to make sense.
I'd check the tightness of the exhaust manifold studs too.
I suppose a choked air filter could cause it to run rich which would exascerbate the problem but I think there is probably a leak in the exhaust ststem too.
Scooby
Scrappy Doo
PostPosted: 02:07 - 23 Sep 2004    Post subject: Reply with quote
It's just the over-run. Don't worry about it.
PostPosted: 02:17 - 23 Sep 2004    Post subject: Reply with quote
You should get someone to follow you in the dark, you will probably find that each pop is accompanied by a fairly reasonable sized jet of flame coming out of the exhaust Cool .
If it is on your maggot I would get it seen to, I would worry about what it might do to the exhaust valves if it is happening a lot over a long period
mr.z
PostPosted: 02:44 - 23 Sep 2004    Post subject: Reply with quote
Ahhhhhhh that makes sense .. actually just found this https://ourworld.cs.com/moonmist115/popping.html
My next question was the exhaust valve thing, i remember reading extreme backfireing action can damage them, never mind, it sounds really cool Cool and lowering emissions! what more could you want Wink
I'll get onto it i think, being my only transport i dont want any unexpected supprises, i'm hopeing it just this 'ole, been an eventfull few weeks with the old dear, as long as i dont have to have the forks in bits all over my shed any time soon its not going to be as bad...
alains - which bike ?
a 20 year old cx500
Ste - Have you got a race can fitted?
see above Razz (disturbingly the thought had crossed my mind, pre 1985 bikes apparently have a bit more leway on noise emissions Very Happy )
PostPosted: 14:04 - 23 Sep 2004    Post subject: Reply with quote
As above, normally due to a leak in the exhaust system.
Finglonga
PostPosted: 22:07 - 24 Sep 2004    Post subject: Re: Exhaust poping on deceleration... Reply with quote
As already said the small hole will let air into the pipe and any fuel will mix and ignite. I hd the same with my Remus Titanium can where it joined the manifold sounded good and looked good with long blue flames at night but it did this...
https://www.ukgser.com/forums/attachment.php?s=&postid=222259
Took it to a local garage and had it welded free(end caps are s/steel) now it just pops not Bangs Crying or Very sad but at least I wont need a new can.
Oh yea... I wouldnt use the paste it will blow out in no time try to get it welded. (unless its Titanium as you need specialist gear)
Andy Sez....
F.Y.Y.F.F.
mr.z
PostPosted: 22:32 - 25 Sep 2004    Post subject: Reply with quote
ah excelent, yep i know a guy who used to weld main gas lines for a liveing, he is rather good... hopefully he still has some gear...
Thanks for the help all Thumbs Up
The last post was made 22 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.89 - MySQL Queries: 13 - Page Size: 68.85 Kb
