| TUG |
 TUG World Chat Champion
 Posted: 02:07 - 21 Feb 2012 Post subject: Quickshifters, how do they work? |
I've had a quick look on teh youtube as i'm more of a visual learner, is there any vids out there that go into great detail on how them tings done work?  ____________________ Haz ER-5, innit! |
| lihp |
 lihp World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
| Blau Zedong |
 Blau Zedong Banned
| lihp |
| Paulington |
 Paulington World Chat Champion
 Posted: 13:15 - 21 Feb 2012 Post subject: |
Depends on which type you have.
Some have a pneumatic actuator which pushes the gear into place whilst cutting the ignition out whilst others just have a switch so when you move the gear lever it cuts out the ignition.
Basically, when the switch is actuated, it causes the ignition system to cut out which means the spark plugs don't spark. This takes most of the load off of the drive train as it is just spinning due to it's inertia and then the gear is either pneumatically actuated or you click it in as normal.
The principle is that when the ignition is cut so the spark plugs aren't sparking there is next to no load going through the transmission and that is what prevents clutchless shifting.
Think about on your bike, try shifting gear at full throttle and then try shutting off the throttle completely and shifting gear without a clutch. It's likely it will just 'snick' in quite neatly. A quickshifter is the same thing. It cuts the ignition (like turning off the throttle) but does it for around 100 milliseconds to keep loss of power to a minimum.
Cheers! ! ____________________ "Four wheels move the body, two wheels move the soul."
CBT: 27/08/08. Theory: 04/09/09. Module 1: 16/09/09. Module 2: 01/10/09. |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 15:17 - 21 Feb 2012 Post subject: |
What people have described so far is partially correct.
In short, you keep the throttle wide open, hit the gear lever which cuts the fuel or spark to the engine, which is effectively the same as closing the throttle allowing the new gear to locate without damage.
In simple terms ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| Polarbear |
 Polarbear Super Spammer
| Walloper |
 Walloper Super Spammer
| TUG |
| lihp |
| Walloper |
| TheSmiler |
 TheSmiler World Chat Champion
 Posted: 07:24 - 22 Feb 2012 Post subject: |
Why do you need a gadget to do something easily yourself. You are riding along see red light clutch brake slowly clutch in drop gear, carry on braking drop drop drop.. drop as many gears as needs be and simples you have quick shifted.
That was taught on CBT easiest thing to do, easier than finding the biting point on a newer bike. ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
| Damon |
 Damon World Chat Champion
| Sako |
 Sako World Chat Champion
| Blau Zedong |
 Blau Zedong Banned
| TheSmiler |
| Blau Zedong |
 Blau Zedong Banned
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| TheSmiler |
| Blau Zedong |
 Blau Zedong Banned
| TheSmiler |
| Walloper |
| lllN30lll |
 lllN30lll World Chat Champion
 Posted: 18:36 - 22 Feb 2012 Post subject: |
I've got the full Bazazz system on mine, FM, TC, and QS.
Once you've had a go of a sportsbike with a quickshifter you'll want one yourself.
https://www.youtube.com/watch?v=EhRZX9DitcU
Watch how quick the gear changes are, saving you seconds per lap on trackdays, also allows for very smooth gear changes when taking large roundabouts/Corners at speed. ( Not only that but they sound awesome ) |
| Walloper |
The last post was made 14 years, 238 days ago. Instead of replying here, would creating a new thread be more useful? |
