| la_lucha |
 la_lucha Scooby Slapper
| MarkJ |
 MarkJ World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:50 - 21 Feb 2012 Post subject: |
Check the plug colour, condition and gap. Re-gap or replace as required. Oil change. Clean the float bowl and jets, do some plug chops and change the needle position and/or jets accordingly. Fit a fuel filter. Check the strength of the spark, and the condition of the wiring on the ignition circuit and engine earth. Check the valve clearances. Check the ignition timing.
After you've done all that, you'd have been better off buying a newer bike.
hondacg125.awardspace.com is a handy resource. ____________________ Biking is 1/20th as dangerous as horse riding.
| la_lucha |
| hazza |
 hazza World Chat Champion
 Posted: 16:24 - 21 Feb 2012 Post subject: |
https://www.mediafire.com/?6824i9hx6zzdmd2
there you go. ____________________ 3 Honda NC50's(Sold)-->'72 Puch Maxi S (Sold, want it back!)--> '90 Yamaha RXS 100 (Stolen)--> '87 Honda Cub 90(Sold) --> '95 Kawasaki Eliminator (Sold) --> '98 Bandit 600 (Sold) -->'07 SV650S (Current) |
| la_lucha |
| hazza |
| Walloper |
 Walloper Super Spammer
 Posted: 17:32 - 21 Feb 2012 Post subject: |
They DO under-perform...
It is a One Hundred and Twenty Five cubic centimetre engine (Spelling it out makes it seem bigger than it is.)
You should be able to just about touch 68MPH (when tucked in behind the Speedo, on a level straight, 0-5mph headwind). Confirmed by writer using GPS.
It will seem slower to accelerate than most cars but with practiced conservation of energy techniques you can fly through town using inertia and forward planning, full use of available throttle, economic use of the brakes and the power of prayer.
https://hondacg125.awardspace.com/
They are brill for town though. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| la_lucha |
| Shinigami |
 Shinigami World Chat Champion
| la_lucha |
| tomh |
 tomh Scooby Slapper
| la_lucha |
| janner_10 |
 janner_10 World Chat Champion
| la_lucha |
| Robby |
 Robby Dirty Old Man
 Posted: 15:05 - 22 Feb 2012 Post subject: |
Fix the problems you know about before trying to find new ones.
So, if the front sprocket is too small, fit one the right size.
Service it. A dirty air filter makes a big difference, and they don't even need to be all that dirty. Washable foam filters in particular, I have thought they look ok until I soaked them in petrol. So much crap and grit gets caught up in the foam. Remember to re-oil with engine oil before refitting.
Make sure the brakes aren't dragging or binding. Quite common on drums brakes that haven't been serviced, or disc brake calipers that have sat and started binding due to corrosion building up behind the seals.
After servicing, take it out for a very hard ride to clean out all the crap and get it really hot. An Italian tune-up still works wonders on most vehicles.
Tyre pressures too.
In short, get the haynes, give it a really comprehensive service, check that the sprocket sizes are correct, then see how it performs. |
| la_lucha |
| Hobgoblin |
 Hobgoblin Trackday Trickster
| numpty2 |
 numpty2 Trackday Trickster
 Posted: 23:20 - 22 Feb 2012 Post subject: |
I had a CG125 for many years and I loved it, but I never managed more than 60mph with the wind behind me. I bottled out at this point because of the drum brakes. A lot depends on your size & weight - I was the equivalent of Jeff Capes riding a Shetland pony. They are really slow, but wonderful. Have pity on the old girl and just enjoy how cheap they are to run. I'd still have one now, but my commute is too far. An old bloke called Simon Gandolfi rode one from Mexico to the bottom of South America and then back again - 46000 miles I think. I sold mine as a runner with 44000 miles on the clock.
Another good source of info is: https://hondacg125.awardspace.com/
You might find something useful here. There are different spark plugs discussed, and the author reckons a windscreen can make a big difference.
If you want something a bit quicker, but just as basic, you could go for a Yamaha YBR125. These are just as easy to work on, lots of spares, and they are quite cheap for the carb models. On balance, I'd probably go for the YBR now over the CG125. Just for little things like better headlight, tubeless tyres etc. |
| Walloper |
| la_lucha |
| Walloper |
| Sako |
 Sako World Chat Champion
| Walloper |
 Posted: 16:44 - 24 Feb 2012 Post subject: |
There is a gap of 214 days between these two posts... |
| amaro12 |
 amaro12 L Plate Warrior
The last post was made 13 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
