General advice appreciated
newtoriding
PostPosted: 02:11 - 26 Feb 2012    Post subject: General advice appreciated Reply with quote
Hi all,
Recently passed my CBT on a automatic scooter. Got a bit of practice on a manual and it seemed like what I wanted so I bought a CBR 125.
Been riding it at night time only to get some confidence and I feel okay in general. I just wanted advice on which gears people use for corners and does everyone downshift all the way to gear one?
Any tips you have for me would be appreciated.
Thanks
Teflon-Mike
tl;dr
PostPosted: 02:39 - 26 Feb 2012    Post subject: Re: General advice appreciated Reply with quote
Err, rather depends on how fast I am going; and how fast I can go round the corner... you know quite often I dont ACTUALLY change gear JUST to go round one, and I might be in TOP gear!
What are you doing?
I suspect like a kid with a new toy, you are pottering around a 30mph housing estate, clogging up and down the box, becouse suddenly you have something to play with... when you probably could ride every where in 1st or 2nd!
Engine has a rev range; makes power from tick-over to maybe 11,000 rpm on a CBR125...
First gear that translates probably to 0 - 28mph.... so if you aren't going over 25mph, you dont need to be in another gear.
Second gear; you could probably pull away from a stand still in; might take a little clutch slip to get off the line, but gearing ought to allow something like 2mph - 40mph.
Engine will make 'optimum' power between something like 6000rpm & 9000rpm.
So first gear will be working 'best' between 12mph & 25.
Second from 20mph to about 35
3rd from probably 25mph to 50
4th from about 40 to 65
5th from about 50 to 'indicated 80
6th will be an 'over drive' and basically let you hold whatever speed you are at when you engage it.
Engine PROBABLY has enough low down 'oomph' at lower revs, that as long as you aren't accelerating, you can click two of maybe even three gears up, and knock the revs back, and it wont 'bog'... wont accelerate well in the higher gears from such low rpm... but will pull them.
So if you are trying to hold say 50mph on a country road, no need to let the engine scream in 3rd, you can snick 4th or 5th, maybe even top.... though you will probably want to clogg down one or tow cogs to get the engine spinning in the sweet-zone if you have to roll off for a tighter corner....
BUT, most faster roads, if you can see 'through' it.... ie its not so tight you cant see much road beyond the corner.... you probably dont need to even roll off the throttle, let alone change gear!
Round town; where you have junctions and hazards; you probably ought to let the motor rev in the sweet spot and hold the lower gears.
No point clunking up three cogs to clump back down them again 30 yards later becouse of a junction.
Engine on a light load, reved out, WILL sound tortured, BUT... the engine is DESIGNED to 'rev' pulling 30mph in second gear, with maybe 9000rpm on the tacho and the throttle half open, will NOT kill it!
And that gives you the 'response' IF some tit pulls out on you, you to change speed on the throttle, WITHOUT worrying about the gearbox; destabilising the bike stamping feet around, or dissengaging drive hauling in the clutch to make changes.
You have six gears, they cover a range of engine speeds, you DONT have to try and use ALL of them, straight away, OR get into as high a gear as you can as quickly as possible; nor make work for yourselfr playing tunes with the ruddy lever!
Relax... dont make work for yourself.
Learn to use the REVS before you use the gears!
WannaBeDude
PostPosted: 02:58 - 26 Feb 2012    Post subject: Reply with quote
Give it a rest Mike ffs !!!! Rolling Eyes
pendulum
PostPosted: 03:15 - 26 Feb 2012    Post subject: Reply with quote
Thanks Mike, as a newbie I find your posts very helpful
Going
PostPosted: 06:30 - 26 Feb 2012    Post subject: Reply with quote
Gearing depends on speed and corner, you'll learn.
On the CBR125
1st gear. Only used for moving off, walking place.
2nd gear. Used for slow corners, filtering. Good to about 30mph (high revs). Mainly used in heavy traffic.
3rd gear. Most of my town riding is done in this gear.
This is how I use it:)
Bike is good for around 70mph, depending on surface, wind and your size.
TheSmiler
PostPosted: 07:04 - 26 Feb 2012    Post subject: Reply with quote
Agree with mike here, on my bike CB125 I mainly use the gears as followed;
1st Gear: Only for moving away or walking place
2nd Gear: This is what I use for most of my riding if I'm in a 30zone. Take slow corners in this and never 1st was the advice I was given, taking slow corners in 1st can be dangerous.
(On my cbt I actually almost come off on the road experience due to slowing down and dropping into 1st to take the corner, it was a gravel road with a small incline causing me to lock the bike up.)
The rest of the gears are for when I'm going any higher, before I used to be in 3rd/4th for 30mph as I didn't like how the bike sounded using all the revs (was only using 8k instead of the full 12k). However now I've gotten used to it and know it won't hurt the bike I use them to the potential.
J.M.
PostPosted: 11:27 - 26 Feb 2012    Post subject: Reply with quote
I've got the CBR125 (2004) and Mike's post is spot on Thumbs Up
As for down-shifting all the way to gear one, do you mean in a corner? On my CBR I find it very rare that I should have to use gear one for anything except except moving off from a standstill and being stuck in slow moving traffic if I can't filter for some reason.
Most corners (even the 90 degree ones) can be happily taken in 2nd gear (at around 15-20mph) so long as your view is good enough for that speed.
But when I'm in the country lanes I may be taking corners in 4th or 5th (I rarely use 6th on mine).
2004 R1 & 2018 XSR900
RIDINGforKICK...
PostPosted: 11:50 - 26 Feb 2012    Post subject: Reply with quote
If you passed your CBT on an automatic bike you are not licensed for a manual bike.
Crazy, I know, but that's how the stupid system works!
PostPosted: 12:00 - 26 Feb 2012    Post subject: Reply with quote
Not true. At 16 you can do a CBT on a ped and at 17 you can ride on a geared 125 happily.
.Chris.
PostPosted: 12:04 - 26 Feb 2012    Post subject: Reply with quote
I'm fairly sure that's not correct. CBT does not have 'automatic' and 'manual' categories like a licence (since it's not a licence).
Chris
1985 Kawasaki Z550F
Recluso
PostPosted: 12:33 - 26 Feb 2012    Post subject: Reply with quote
There's no categorisation on CBTs.
I renewed my CBT on an automatic, 2 months later I switched to a manual after an hour's training session.
The only important things about a CBT is a. that you have one and b. when it expires.
'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900
RIDINGforKICK... This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
PostPosted: 12:58 - 26 Feb 2012    Post subject: Reply with quote
Take your DL196 out and have a look at it
Half way down you will see a box "category restrictions".
If the person who filled in the form put a restriction it will be in this box. If there is no restriction, you are OK, if he put "automatic" you are restricted to an auto.
He may have "forgot", but he should have restricted you.
And if you look it clearly states see notes 3 and 6. Now turn that CBT cert over and read out notes 3 and 6.
note 3 wrote:
This certificate is valid in respect of all mopeds and motor bicycles unless a restriction is recorded overleaf by the instructor. The restriction that may be recorded is when a course was completed on a motor bicycle and side car combination or on a moped with more than two wheels. In these cases the provisional entitlement is restricted to such machines. (Additional classes of restriction may be introduced in the future, but these will not be applied retrospectively to certificates already issued).
So in English that means if you do your CBT on a 3 or 4 wheeled vehicle, I.e a trike or a quad, then you are restricted to only those types of vehicles.
Note 6 says pretty much the same thing. Nowhere does is state that if you sit your CBT on a moped or automatic then you have to stay on one.
You can sit your cbt at the age of 17 on a 50CC ped and you can then get onto a geared 125CC bike to practice on. You are not restricted to the style of bike you done your CBT on and you do not have to do another CBT unless your current one runs out.
All you are doing is causing confusion. You have based your claim on assumption without actually reading what the restriction part of the certificate actually means.
Alpha-9
PostPosted: 13:07 - 26 Feb 2012    Post subject: Reply with quote
You're wrong.
HTH Thumbs Up
Fzr-600 1999
RIDINGforKICK...
PostPosted: 13:16 - 26 Feb 2012    Post subject: Reply with quote
When I did my CBT (last February) the instructor made a big fuss about this, he had two CG125 and two scooters, there were three of us doing the course. He said that if we took the CBT on an auto, he would restrict the CBT holder to an auto ONLY.
He was most insistent that there was a issue, and I watched him fill one of the trainee's form out with AUTOMATIC in big scary print!
He may have been wrong, I dunno, I've given up trying to figure out the Brussels gobbledygook.
Anyway, if the OP has nothing written in the box on the DL196, then he's OK.
PostPosted: 13:33 - 26 Feb 2012    Post subject: Reply with quote
He is wrong.
Q - If I do my C.B.T on an automatic, can I ride a geared bike?
A - Yes, C.B.T is a blanket cover - It will cover a rider for all types of moped/bike up to 125cc.
Many places will put you onto a ped if they do not think you can manage the gears well enough to go out on the road and you will be free to practice on your own bike at your own leisure.
Any place that tells otherwise is wrong and possibly trying to cream another £100 out of you.
RIDINGforKICK...
PostPosted: 13:57 - 26 Feb 2012    Post subject: Reply with quote
Well this is EXACTLY the problem, I paid 105 great British pounds for a *compulsory* basic training, and the INSTRUCTOR didn't even understand the rules!
I can remember last year, searching in the net for information about the bike tests/licence, as I just have now, and a huge amount of the information has changed! There WAS a lot of debate about Geared/Auto licences last year, but that seems to have disappeared completely now.
This is because NO ONE can figure out what the ACTUAL laws, written in indecipherable Belgian legaleses, MEAN.
My apologies to the OP, I WAS WRONG, as was my very expensive instructor, now what value was my CBT again?
PostPosted: 14:33 - 26 Feb 2012    Post subject: Reply with quote
In truth. No value at all. All a CBT is, is a legal requirement to show that you have had enough teaching to ensure you are "safe" on the roads of our fair nation and nothing more. The clue is in the name, Basic Training. It is nothing more than a forced motorised equivalent of the cycling proficiency test from when you were at primary school.
PostPosted: 14:49 - 26 Feb 2012    Post subject: Reply with quote
I'm having trouble finding the actual statutory basis for the CBT and DL196. Bearing in mind that the DVLA and DSA have a track record of just inventing rules and then coming to believe that they're legally binding, I wouldn't read too much into what it says or doesn't say on the certificate.
If it convinces Plod, insurers and DSA testers, then job done.
PostPosted: 15:03 - 26 Feb 2012    Post subject: Reply with quote
If you are suffering from insomnia the basic stuff is here:-
https://www.legislation.gov.uk/uksi/1990/2334/made
PostPosted: 17:15 - 26 Feb 2012    Post subject: Reply with quote
Hmm, can't see anything in there about automatic / manual, just about A and P.
sidewinder
PostPosted: 17:22 - 26 Feb 2012    Post subject: Reply with quote
Can you explain this a bit more to me please Very Happy .The only reason i can think of is the back end coming out if you open the throttle to quick.Being basically new to all this i am finding this thread really interesting Thumbs Up
sw
RIDINGforKICK...
PostPosted: 17:34 - 26 Feb 2012    Post subject: Reply with quote
I accept that I was wrong about the CBT and that currently you can apparently do your CBT on either auto or manual bikes.
But what I said the instructor told my is true, and a lot of the sites said the same (incorrect) thing at the time.
https://sites4bikes.co.uk/CBT_motorbikes.htm
"What do you want to take your CBT test for?
If the answer to that is just to be able to ride a scooter and you have no intention of progressing to obtain your full motorbike licence then a scooter is probably sufficient and is easier to ride, since there are less controls. A scooter is far more nimble than a motorbike in traffic and around towns. They are cheaper to buy and run and ideal for shorter distance commuting as they generally offer more protection from the elements than a standard unfaired motorbike. However you cannot ride a geared motorbike if you take your CBT on an automatic as your license will be restricted."
This site hasn't been updated, clearly, but many I looked at last February said the same stuff, but have since amended their site.
The whole thing is constantly in flux, like the tests themselves.
When I did my Mod 1, It bore little resemblance to the videos on Utube or the DSA website.
There was no - ride up to the clip board, then at walking pace behind it-, no, she told me to ride slowly toward the U turn section (?) when did that change?
No one bothered to tell the poor punters, did they!
PostPosted: 18:06 - 26 Feb 2012    Post subject: Reply with quote
CBT as far as auto and manual hasn't changed. Possibly all that has changed is that those unofficial sites giving the wrong info have been corrected.
The last post was made 14 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 141.42 Kb
