keeping tropical fish
andyscooter
PostPosted: 18:07 - 26 Feb 2012    Post subject: keeping tropical fish Reply with quote
ive done it when i was younger i had an 8 foot long tank with all the trimmings lobsters shrimps loach angel fish ect ect
but i cant remember how to clean them out properly
i have always had a cold water tank but after introducing two fish i lost the lot so i have given up on them
my mate has always said tropical are easier to keep
i have always wanted a tropical tank again and so looked into getting heater and renewing gravel filter ect ect
turned out cheaper to have a new tank deal anyway (heater pump light tank gravel ) 54 quid
so i have a new 35 litre tank which i plan to put guppys tetras and mollys in so dont need massive and havent got space in my own house anyway
advise please
CaNsA
PostPosted: 18:47 - 26 Feb 2012    Post subject: Re: keeping tropical fish Reply with quote
andyscooter wrote:
advise please
I would but that is the most annoying way to end any post/email/txt message etc etc ever.
GTFO
Addition:-
And considering you posted Here you should know better!
andyscooter
PostPosted: 19:04 - 26 Feb 2012    Post subject: Reply with quote
i asked for advice so advice please was correct
and it didnt show on the spell check
and i have had 6 pints
oops sorry Embarassed
can i have some help please Embarassed Embarassed
RPM
PostPosted: 22:31 - 26 Feb 2012    Post subject: Reply with quote
By the time you add gravel, decor etc, 35 litres is not really big enough to sustain Guppy's (If male & female, you'll probably end up with too many),
Tetra's (depends on which)
Molly's (potentially too big/not enough room).
If you go with Guppys (all male) or Endlers Guppy's
Tetra's (much more choice, but can end up being bland)
You might be able to do a few Guppy's and a couple of Pygmy Gourami's or.....
Tetra's and a female fighting fish or short finned (Plakat) male fighting fish.
All the above cope well with a PH of approx 7 and usual trop temp range of 74 to 80 degrees farenheit
The above is only my suggestions. Ultimately, it's your tank......your choice Thumbs Up Thumbs Up
Mike
Recluso
PostPosted: 23:39 - 26 Feb 2012    Post subject: Reply with quote
*Wall of text warning*
One thing that hasn't been mentioned is water testing. Yes, tropical fish are often pegged as being easier than cold water but there is still a certain amount of science involved in establishing the correct environment required. If your tank is exceptionally long, you will want to consider a heater at either end to ensure a proper temperature gradient as well as dual filtration to ensure proper water circulation.
Some tropical species such as guppies, platies and mollies (the live bearers basically) are generally quite hardy. It will depend entirely on what you want to keep in the tank. Tetras are also generally quite hardy but you will however need at LEAST 12 as they are shoaling fish. If however you start going down more unusual species such as gourami, betta fish (also known as fighting fish), cichlids, discus and the likes, then the survival of your community will depend on the water conditions more and more.
As previously mentioned, if you go down the guppy route, you will need to make sure they're all male. Otherwise you'll be swamped within weeks.
Cleaning CAN be time consuming but it can also be rewarding. I used to set an hour or so a week aside. You WILL need to monitor the water for both pH and nitrate levels. The optimal pH is around 7.6 on average. But again, it depends entirely on what you're keeping. Nitrates, so your fish wastes can easily wipe out a tank if you allow it to become too high. The easiest way to combat this is to do a 20% water change about couple of weeks. If your water is particularly acidic or alkaloid, you may want to consider buying in water. This is usually available from your nearest aquatics store and is usually fairly cheap.
Make sure your tank isn't placed in direct sunlight as this will encourage algae growth. Expect a little bit of build up however, this is naturally. I used to use a glass scraper to remove mine and a small algae pad to get into the corners. Use a small beaker of water from the tank and use that to rinse off anything you use to scrub the glass.
Your filter will need cleaning, usually weekly. The sponge will need to be cleaned using water from the tank. This is because this water is effectively safe having passed through the already mentioned 'friendly bacteria' in the filter. Cleaning the sponge under a running tap can kill that bacteria, putting your community at risk.
What I strongly advise is to NOT try and overtly change your water. You're better off finding fish that would naturally thrive in your water. The more you try and tamper with the water to make it 'perfect' the more delicate your environment is and susceptible to unpredictable fluctuation. I would suggest to get the tank up and running (which you will need to allow to run empty for at least a month to allow the 'friendly bacteria' to develop on your filter's carbon filters) and then run a series of water tests. Take the results into your aquatics store and see what species they might suggest.
Remember also that the addition of live plants can help balance your water and will also naturally oxygenate the water. Maintainance of plants is very simple although they will require fluorescent lighting and need the occasional trim to stop them running wild.
Consider your community carefully. You have three levels of feeders, all of which can be identified by the position of their mouths. Gourami for example are 'top feeders' (their mouth tips up). Loaches, Corydoras and the like are 'bottom feeders' (their mouths face the ground). You won't want all top feeders, just like you won't want all bottom or middle feeders as each serve their purpose in a balanced community. Bottom feeders or scavengers will often get the food that is missed by top and middle feeders.
Be careful that the fish you add are compatible with each other. Loaches for example can cause problems in small tanks. Not only do they grow quite large, but can also terrorise other tank occupants by feeding on the natural 'slime' that protects your fish's scales. Angel fish, whilst pretty are notorious fin nippers and as such fish with trailing fins such as betta fish and guppies can end up injured and with ragged fins.
Don't just plonk fish in wily-nily, consider your community's needs. A peaceful community is beautiful to watch. A stressed one can drop like flies or mean months of illness and injuries.
Have fun reading. Don't give up half way through Razz
'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900
bikertomm
PostPosted: 00:52 - 27 Feb 2012    Post subject: Reply with quote
Take note of the temperature to start with.
Then take about 1/5 / 1/4 of the tanks water out by syphening it out into a bucket. (Don't really know, I took 10 litres out, think it must have been about a 50 litre tank.)
Clean the filter in that water.
Pour bucket away.
Fill up bucket 90% with cold water from tap.
Get the kettle on.
While it's boiling clean the glass, put the filter back in, get the shit out ect.
Pour boiling water into bucket with thermometer in and match the temperature as to what the tank was originally.
Put in aquasafe or whatever.
Water back in tank
Happy days Razz
Alpha-9
PostPosted: 10:05 - 27 Feb 2012    Post subject: Reply with quote
I don't know why people bother...
I knew this couple who kept koi karp (or something like that)
They cost them thousands and they got eaten by seagulls Thumbs Up
Fzr-600 1999
growler
PostPosted: 17:45 - 27 Feb 2012    Post subject: Reply with quote
I have a 35 ltr tank with 1 male fighter, 6 micro rasboras, 4 snails and a butterfly loach which is about 4 to 5 inches of fish which is about the maximum for that tank
the loach may be coming out of that tank though as although the shop staff told us the "Butterfly catfish" would do well in this tank on getting home and checking it out found it is a loach not a catfish and likes fast flowing water with a high oxygen rate Rolling Eyes
DILLIGAF
Ariel Badger
PostPosted: 18:34 - 27 Feb 2012    Post subject: Reply with quote
Red cherry shrimp Thumbs Up
andyscooter
PostPosted: 19:19 - 27 Feb 2012    Post subject: Reply with quote
will only have male guppys as i made that mistake before
what i aim to have is a tank with colour so guppys and blue/red tetras will be great
the one i had before was 8 foot long by two foot high and had lobsters shrimps and also red tailed sharks ect ect
i wont put angel fish in as i know they are a pain
also barbs are nippers
it was more the amount of water to change at a time i was concerned with
the cold water i have just got rid of was 50 litre and the two fish that were 5 years old died because i added two new fish from somwere that had finrot and even with a 5 day course it didnt stop it wiping out the intire tank
The last post was made 14 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 71.27 Kb
