Quick mod 2 question
Tomzo47
PostPosted: 00:05 - 27 Feb 2012    Post subject: Quick mod 2 question Reply with quote
Hi guys,
on your module 2 test do you have to select neutral when waiting at lights? or is it ok to leave it in gear with clutch in?
thanks Smile
Ybr 125 > Bandit 650SA > GSXR 600 > Triumph Sprint St1050 > CB1300 > Z1000SX + FJ1200 (written off) > VFR750 >FJ1200
Kingstondavo
PostPosted: 00:28 - 27 Feb 2012    Post subject: Reply with quote
No, you can leave it in gear, I did all the time as the bike I did my test on was well worn and finding neutral could take a while...
Current Ride - 2010 Hornet 600
Taught2BCauti...
PostPosted: 00:32 - 27 Feb 2012    Post subject: Reply with quote
Might be different when you come to a 'Stop' sign - you must at least come to a dead stop an put a foot down, even if you can see that it's clear to go.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
J.M.
PostPosted: 01:12 - 27 Feb 2012    Post subject: Reply with quote
The only time my bike ever sees neutral is when it's parked. On test I left it in gear one with the clutch pulled in. Right foot pressing the rear-brake and the left foot on the floor.
Occasionally check your mirrors whilst waiting - can't do any harm. Remember your mirror checks/shoulder checks before moving off from the lights. Smile
I did the same on my driving test.
2004 R1 & 2018 XSR900
Llama-Farmer
PostPosted: 01:42 - 27 Feb 2012    Post subject: Reply with quote
Can't see any harm in it. I'd be surprised if the examiner would be able to tell whether it was in neutral or not anyway, unless you were waving your left hand in the air
Bomberman
PostPosted: 01:52 - 27 Feb 2012    Post subject: Reply with quote
I wouldn't. While you're messing around changing gear you aren't covering your rear brake and you're hopping from foot to foot. A tight examiner may think you're not in proper control. Should be left foot down, right foot on brake.
Also, what if it won't go back into first easily? You get to panic, then remember to let the clutch out a bit and try again and hopefully you won't have stalled letting the clutch go a bit and hopefully it'll go that time - but it might not - and then you're not making progress and affecting other road users.
I wouldn't bother mate Thumbs Up
PostPosted: 01:55 - 27 Feb 2012    Post subject: Reply with quote
Is the correct answer. Thumbs Up
PostPosted: 12:28 - 27 Feb 2012    Post subject: Reply with quote
I heard that in the Before Time, in the Long Long Ago, that because Plod riders were taught to do the neutral jig that DSA examiner (all wannabe coppers, amirite?) expected it too.
But that may have been apocryphal and it's not the Before Time any more. I passed with leaving it in 1st much of the time, although I think I did put it in neutral a couple of times and then ostentatiously used my left hand to wipe the sleet off of my visor or take a swig from my hip flask just to cover my bases.
anthony_r6
PostPosted: 14:15 - 27 Feb 2012    Post subject: Reply with quote
I was told no neutral as you should be prepared to get yourself out of danger should it arise while you were at a set of lights. I definitely didn't go into neutral on my tests and it was never mentioned.
QM
PostPosted: 14:20 - 27 Feb 2012    Post subject: Reply with quote
That's what my instructor told me prior to my test as well
05 Honda CG125 now 03 Honda CB600F Hornet
The last post was made 14 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 66.55 Kb
