| GeePeeZed |
 GeePeeZed Derestricted Danger
 Posted: 20:25 - 27 Feb 2012 Post subject: GPZ600R Rear Shock, HELP! :) |
Hello everybody.
I have recently purchased a good example of a GPZ 600R (1987!)
I am trying to adjust the rear shock plunger, to number '4' setting.
It is currently reading No. 2.
It appears to be stuck.
Any advice would be much appreciated.
I can upload photographs if it would help, though anybody with a GPZ will probably know how to do it
Thanks in advance,
Regards. ____________________ GPZ Head. |
| andym |
 andym World Chat Champion
| GeePeeZed |
| andym |
| GeePeeZed |
| GeePeeZed |
| andym |
| andym |
| GeePeeZed |
| GeePeeZed |
 Posted: 18:40 - 04 Mar 2012 Post subject: |
Bump  ____________________ GPZ Head. |
| andym |
| GeePeeZed |
| GeePeeZed |
| andym |
 Posted: 21:42 - 04 Mar 2012 Post subject: |
Just been reading a bit more on the fork pressure, it seems the ideal pressure is 8.5 psi for the front. If it is still soft then maybe check the oil level.
Check this site for some figures for the bike.
https://www.motorbikespecs.net/index.dyn?flag=2&model_id=1914540&make=Kawasaki
Also for the adjusters at the bottom of the forks, I wouldn't take the button turning as doing anything inside the anti dive unit, with mine one seemed quite stiff the other moved freely, it turns out both of them had snapped inside so if I want to adjust them I will need to use a screwdriver to turn them.
If you get the adjuster back out for the rear suspension (after another good coat of WD40), keep spraying and moving it back and forward, if it doesn't loosen up then it could be a problem with the whole shock. |
| GeePeeZed |
| andym |
| GeePeeZed |
| GeePeeZed |
The last post was made 13 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
