Brakes
1cyl
PostPosted: 09:14 - 29 Feb 2012    Post subject: Brakes Reply with quote
Had a bit of an issue last night with the rear brake lever travel stop bolt working itself loose and winding itself out a bit more every time i hit the brake, to the point where it was on all the time, resulting in me grinding to a holt and getting off to witness the rear disk glowing vibrant bright orange and the pads looking pretty unhealthy.
I bet if i was wearing trainers instead of boots i'd have felt this much sooner:evil:
What would you replace after such an event? anything?
Disk is still true, although a different shade to the front now.
pads work but look suspect, bubble effect paint.
Dread to think about the state of the calipers bellows, no leaks tho.
Haven't checked to see whether i've stretched the chain yet.
Anything else i should look for?
I've gotta head to work but lookforward to any advice later.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Fizzer Thou
PostPosted: 23:04 - 29 Feb 2012    Post subject: Reply with quote
Bleed the brakes as soon as possible.It will have boiled the brake fluid and not done its braking abilities much good.
Always have a 'Plan B'
Ariel Badger
PostPosted: 23:26 - 29 Feb 2012    Post subject: Reply with quote
sounds like a lucky escape, bleed the brakes and change your underpants.
andym
PostPosted: 23:51 - 29 Feb 2012    Post subject: Reply with quote
Just a thought, depending on how long the problem has been there with overheating brakes (you might not have noticed it before), it might be worth checking the brake hoses too, if there is a lot of heat in the brakes (as Fizzer Thou has mentioned), it can cause the hose to collapse internally...
... just a thought
st3v3
PostPosted: 22:08 - 01 Mar 2012    Post subject: Reply with quote
Got any pictures of the pads?
I'm curious about this bubbling effect.
1cyl
PostPosted: 18:56 - 08 Mar 2012    Post subject: Reply with quote
Sorry for late response but thanks for all advice.
I've blead it through and changed the pads which has worked a treat, not sure its quite as good as it was before, but once again i can lock the back wheel up with a good stomp if i wish.
Might change the disk in the future.
Haven't got round to photo pads, but it just looks like the coating has got hot and started to bubble. The actual meat of the pads now has a very smooth finish, compared to the rougher nature of the new ones.
No change in chain tension Thumbs Up .
Now checking pedal return bolt regularly.
The last post was made 13 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 49.67 Kb
