Clutchless shifting.
carlosthejack...
PostPosted: 19:34 - 01 Mar 2012    Post subject: Clutchless shifting. Reply with quote
I've just been in the bath trying (in vain) to shift this godawful virus, and I was reading the GSR750 review in Superbike magazine from a couple of months ago. One part of the review mentioned having to ride the bike "clutchless" and how the gearbox was so good, the reviewer changed both up and down for quite a long journey with no problems without the clutch being used.
Now I was always told that while it's acceptable to shift up on a bike without engaging the clutch (which I do do occasionally, but it takes some effort on the Hornet), downshifting is a big no-no as it will destroy your gearbox. Either way, I don't think it's something I'd like to try in case I break something.
Any thoughts? Is this just a "lovely Suzuki gearbox" thing or should I be taking this info with a pinch of sodium?
Mikey3
PostPosted: 19:39 - 01 Mar 2012    Post subject: Reply with quote
My SV shifts up quite nicely without the clutch but I've never tried the downshifting.
In an emergency, say if the cable snapped or something then you could do it with the normal throttle blip before downchanging but I wouldn't do it for any other reason than having no way of using the clutch - my dad had to do it once, but he told me its not really recommended unless in an emergency.
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
lihp
PostPosted: 19:45 - 01 Mar 2012    Post subject: Reply with quote
R6 drops dowb gears nicely below 4k, above that never tried tbh.
Though, it depends on how good you are, shouldn't cause any damage if you can do it right Wink
EXC-Rider
PostPosted: 19:58 - 01 Mar 2012    Post subject: Reply with quote
I used to down shift cluchless my CRF when I was racing at the mx track, gets the revs up quicker, never really had any problem with it tbh
owned bikes: DR50, Thumpsta 110 , Honda CR85, Speedfight 100, Yamaha XT125X, Honda CRF450, Honda Hornet '07
current bikes: KTM EXC525 AKA the wheelie machine
A friend in need is a friend indeed but a friend with weed is better!
HD
PostPosted: 20:37 - 01 Mar 2012    Post subject: Reply with quote
AFAIK all motocross bikes are made to be like that.
Poseidon
PostPosted: 20:45 - 01 Mar 2012    Post subject: Reply with quote
Like others have posted, clutchless up change is no problem on the triumph. Once I'm out of town and out of the 30mph zones, I never reach for the clutch when changing up. For fear of causing untold damage to the cogs, i've never tried a down shift though.
1977 Honda CG125
james1988
PostPosted: 21:27 - 01 Mar 2012    Post subject: Reply with quote
I can do it up and down quite smoothly on the firestorm. I've stopped clutchless down shifting though, it was more of an experiment to see if I could do it smoothly than a way of life.
James
PostPosted: 21:44 - 01 Mar 2012    Post subject: Reply with quote
You CAN do it going down as well, but it's a bit more tricky to master and I find using the clutch gives you more control.
If it's so great, why do racers (autoblippers on say the WSBK spec RSV4 excepted) still use the clutch?
Mikey3
PostPosted: 22:53 - 01 Mar 2012    Post subject: Reply with quote
Even GP stars use the clutch downshifting Thumbs Up
Mike
'04 Yamaha WR450F
AlexW
PostPosted: 23:24 - 01 Mar 2012    Post subject: Reply with quote
I did it a few times on my 125, then dropped it and broke the clutch lever, Rode it for a good few days downshifting without the clutch.
Sometimes it didnt work very well, Got me around though.
I try to not do it too offen as its not that smooth, having to give it a little throttle to get it down. I do clutchless shifts on most upshifts.
lihp
It's doen going up to save time, and keep on the power for longer, coming down the box it's not so critical to stay on the throttle since you're on the brakes, so it's easier to control, especially since hte bike is in an unstable state due to heavy braking anyway.
PostPosted: 23:28 - 01 Mar 2012    Post subject: Reply with quote
I seem to repeat this every time this type of thread pops up. It is fine to upshift from second up to 6th without a clutch. Not so good coming down the gears.
But.
My bike was fitted with a clutch to make gear changes easier therefore I never change gear without it.
Koltu
PostPosted: 23:51 - 01 Mar 2012    Post subject: Reply with quote
Having just passed and obviously this isn't covered in DAS, going up gears is it just a case of keeping throttle on??
CBT: DONE! Very Happy Theory : Passed, DAS - 12/13 Jan, Mod 1 Pass! Mod 2 Pass! Bike Honda Hornet 600
janner_10
PostPosted: 01:02 - 02 Mar 2012    Post subject: Reply with quote
I can see the point on the track ifs it like your job and stuff but why bother on the road?
lihp
PostPosted: 01:42 - 02 Mar 2012    Post subject: Reply with quote
No, while throttle is on, apply a light pressure to the gear selector. roll back off the throttle and the instant you feel the engine strain drop off, just lift it up into gear and that's it.
Pinky, can you please explain why it is not so good coming down the gears? It is no different going up or down gears, just that it is more difficult coming down
daesimps
PostPosted: 08:25 - 02 Mar 2012    Post subject: Reply with quote
Just by coincidence I'd been reading a thread about this said same thing on the California Superbike School forum.
Turns out their mechanic, who looks after the entire fleet of bikes, is an advocate of clutchless up and down and after inspecting the gearbox there's absolutely no damage whatsoever. The guys on the forum were of the opinion that the school teaches it, and the mechanic's hardly going to recommend it if it means he has a load of repairs across the entire fleet, so why not give it a go.
I always do clutchless upshifts above 2nd, so thought what the hell and gave it a go down as well - it's very smooth and surprisingly easy.
I personally find it much easier than getting the blip on downshift right. That's not to say I can't do the blip as I shift down, but it's definitely a lot easier and smoother doing it the clutchless way.
Just my 2p worth. At the end of the day it's each to their own and everyone does what they are most comfortable with.
Dae.
If it ain't broke, fix it till it is!
PostPosted: 10:26 - 02 Mar 2012    Post subject: Reply with quote
Mike
I know, hence I posted that they do. As of last year I don't believe any of the Moto GP bikes were running autoblippers.
Well aware of why it's done. The point I was trying to make is that if clutchless down changing is so amazing, as per the OP, then why do racers still use the clutch going down. Basically what I'm saying is clutchless down shifting is wank IMO. Wink
garth
PostPosted: 10:34 - 02 Mar 2012    Post subject: Reply with quote
I generally use the clutch, unless I'm going properly flat out on the road, which is rare.
Hairy Ben
PostPosted: 10:43 - 02 Mar 2012    Post subject: Reply with quote
When I did the Yamaha Off Road Experience on WR250's and 450's we were told not to bother with the clutch unless we were pulling away or stopping.
It was a very odd thing to get your head round after riding road bikes for so long. But it worked like a charm. Very Happy
...and thus true enlightenment is achieved.
I think, therefore I am... I ride a BMW, therefore I smell of wee...
Alpha-9
PostPosted: 11:00 - 02 Mar 2012    Post subject: Reply with quote
Can do it with my YBR, don't think it's healthy though, prefer the clutch control Thumbs Up
Fzr-600 1999
PostPosted: 12:43 - 02 Mar 2012    Post subject: Reply with quote
My life isn't so short that I have to claw back every 1/100th of a second I can get my hands on.
carlosthejack...
PostPosted: 16:49 - 02 Mar 2012    Post subject: Reply with quote
I never said it was amazing Question Confused
Personally, I wouldn't do it, it would mean me disengaging everything I've ever been taught. I was just wondering if what I was reading was right and something that was done by anyone else. S'all.
hmmmnz
PostPosted: 00:31 - 03 Mar 2012    Post subject: Reply with quote
clutchless shifting is just a waste of fucken time!!
if you were really good you might save 1/50th of a second,
woop woop, are any of you in that much of a hurry that you need 1/50th of a second??
the potential to fuck stuff up far exceeds the benefits,
its not big, clever, cool, or useful
the humans are dead
I kick arse for the lord
blurredman
PostPosted: 01:36 - 03 Mar 2012    Post subject: Reply with quote
hmmmnz wrote:
useful
Unless you find yourself without a clutch lever or cable?? Cool
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 52k.
hmmmnz
PostPosted: 08:22 - 03 Mar 2012    Post subject: Reply with quote
are you really going to be riding like a twat if you happen to break your clutch cable??
i can change gear in just about any vehicle with out a clutch, (car, bike truck) but it doesnt really serve any purpose, except just like what ive just done and be able to say you can, man im choice, i know you all want to be like me now, im so skilled and awesome and shit,
woohoo
Very Happy
the humans are dead
The last post was made 14 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 133.4 Kb
