bike chain tension
donniemateno
PostPosted: 15:45 - 02 Mar 2012    Post subject: bike chain tension Reply with quote
Just washing ym bike and i just wanted to check the tension on my chain as i had the chian and sprocket changed about 2 months ago. i went back after 2 weeks of it being fitted and the guys in the garage said it was fine.
when i push down on the chain it moves about 3-5 mm BUT if i push up on the bottom of the chain it moves a good 2-3 inchs. just wondering if this is the norm as i dont want it flying off!
its a honda xr 125 55 plate
Taught2BCauti...
PostPosted: 18:03 - 02 Mar 2012    Post subject: Reply with quote
Take a point about half-way between the front and rear sprockets, on the bottom run of the chain. You should be able to push it down and lift it up a total of about 1" to 1.75" (25mm to 43mm) max.
Now rotate the back wheel so that the point you just checked is on the top run of the chain, and check the movement again - if you have no tight spots or kinks in the chain, it should be the same.
It's not unusual for a new chain to need adjusting once or twice during the first month, as it beds itself in.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
donniemateno
PostPosted: 13:59 - 03 Mar 2012    Post subject: Reply with quote
just taken picture of the slack. too me looks way to much
stonesie
PostPosted: 14:11 - 03 Mar 2012    Post subject: Reply with quote
You see that plastic thing attached to the swing arm? hook the end of a tape measure in there under the swinger and take some measurements.
donniemateno
PostPosted: 16:40 - 03 Mar 2012    Post subject: Reply with quote
before i do i take it the chain shudnt b able to touch the plastic?
cb1rocket
PostPosted: 16:54 - 03 Mar 2012    Post subject: Reply with quote
no but it need adjusting so you have 25 - 45mm of play up and down in total.
Yes your only be able to push the chain down 3 - 5 mm, but its the overall slack from when you hold the chain to it highest point and push it down to it lowest point. That is where it should be about 25 - 45mm
donniemateno
PostPosted: 17:08 - 07 Mar 2012    Post subject: Reply with quote
sorry about slow reply! been snowed under please find attached pictures of the free play of the chain 2.5 inch of play in total
Mikey3
PostPosted: 17:49 - 07 Mar 2012    Post subject: Reply with quote
should be really about 2-3cm of movement. If the chain is bowing then its too slack, also, rotate the wheel to make sure the freeplay is consistent all the way round the chain, if there's tight spots, it could be time to start looking for new chain and sprockets.
HTH
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
Babba This post is not being displayed because the poster is banned. Unhide this post / all posts.
donniemateno
PostPosted: 07:17 - 08 Mar 2012    Post subject: Reply with quote
best methods to clean? dont want to do what ym bike instructor did and take the tip of my finger off!
donniemateno
PostPosted: 07:45 - 08 Mar 2012    Post subject: Reply with quote
and i think where i might be going wrong is the weight of someone sitting on it... i remember now when i took it to the garage to have a look at iit after a week he got me to sit on it to check the tension
PostPosted: 10:49 - 08 Mar 2012    Post subject: Reply with quote
It's an XR125 a Dirt bike, 1" of Chain slack is far too little.
hoptop
PostPosted: 11:39 - 08 Mar 2012    Post subject: Reply with quote
here a video i found for you may be useful
h*tp://www.ehow.com/video_4956935_adjust-motorcycle-chain.html
stephen james need help ..........................................
The last post was made 13 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 74.45 Kb
