vfr 400 front brake bleeding help!
tt tim
PostPosted: 20:36 - 24 Sep 2004    Post subject: vfr 400 front brake bleeding help! Reply with quote
my vfr had no front brake travel at all the minute you touched the leaver it was on,it only moved about 3 mm then the brakes were on full and slightly sticking,so i slakend the nipples to see if the cylinder would travel further and the leaver went all the way back so i let it go then tightend the nipples up,so now i have no brake at all so i want to bleed it back up but not as hard,but i cant cos if i open the niplle with a pipe on pull the leaver hold it in close it,then open it it just sucks the same fluid back in as if its just moveing the same fluid in and out,ive donr loads a car brakes and ive followed the manual is there a certain way to do it or could my master cylinder be faulty?
triumph tt 600
honda vfr 400
kev
I Hump Things
PostPosted: 21:49 - 24 Sep 2004    Post subject: Reply with quote
Loosen the nipple, pull the leaver in then with it held to the bar tighten the nipple back up and keep doing that then your brakes will work.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Retro-Man
PostPosted: 21:57 - 24 Sep 2004    Post subject: Reply with quote
yep like kev says
also helps to have a piece of clear tubing pushed over the nipple as this helpsto stop air going back in
a brake bleed bottle will cost a fiver from your local motorist shop..
https://domharnessphotography.webs.com
kev
I Hump Things
PostPosted: 21:58 - 24 Sep 2004    Post subject: Reply with quote
Or an empty coke bottle and an old bit of pipe is free. Very Happy
Guest
PostPosted: 22:03 - 24 Sep 2004    Post subject: Reply with quote
Like this .........
kev
I Hump Things
PostPosted: 22:04 - 24 Sep 2004    Post subject: Reply with quote
Thats the kiddy. Thumbs Up
PostPosted: 22:10 - 24 Sep 2004    Post subject: Reply with quote
Just remember that the contents of the bottle is not Iron Bru.
Frost
PostPosted: 11:02 - 25 Sep 2004    Post subject: Reply with quote
make sure you start to dot he nipple up BEFORE the level reaches the bar. pull it in and let it out the tinyest bit and you could suck air back into the system
The last post was made 22 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 55.32 Kb
