'Scratchy' gear change on 750 slingshot??
Quikmac
PostPosted: 21:36 - 05 Mar 2012    Post subject: 'Scratchy' gear change on 750 slingshot?? Reply with quote
It's done 27,000 miles and runs nicely, but change through the lower gears 1st neutral, to 2nd, seems a bit 'scratchy' is the only word I can think of. It feels as though there is no lubrication on the gear change mechanism. Any ideas anyone?? Twisted Evil Question
Forward, cultivate and speed!
Ariel Badger
PostPosted: 22:11 - 05 Mar 2012    Post subject: Reply with quote
Make sure that your clutch is adjusted correctly, sounds like you may have a bit of drag.
Quikmac
PostPosted: 22:21 - 05 Mar 2012    Post subject: Re: 'Scratchy' gear change on 750 slingshot?? Reply with quote
BLUEX5 wrote:
Lubricate the gear change mechanism? Also check if the ball joints are about to die.
Are gear change mechanisms kept bone dry then? Does your left hand crank case cover not have a gasket on it?
Quikmac
PostPosted: 22:26 - 05 Mar 2012    Post subject: Re: 'Scratchy' gear change on 750 slingshot?? Reply with quote
Mmm! HAve just changed clutch lever and adjusted the lever end clutch adjuster. Could be that. What do you mean by 'dragging'?
Ariel Badger
PostPosted: 22:32 - 05 Mar 2012    Post subject: Reply with quote
Drag is when the plates do not separate sufficiently and it causes trouble with gear changes. As said make sure your linkage is all well oiled and you can get problems with old or the wrong grade of oil in a wet clutch.
Quikmac
PostPosted: 22:40 - 05 Mar 2012    Post subject: Reply with quote
Bike was a bit 'unserviced' when I got it. I Intend to change the oil but will check the quality of existing oil before I do. Ta M8!
Rebel This post is not being displayed because the poster is banned. Unhide this post / all posts.
Quikmac
PostPosted: 19:30 - 06 Mar 2012    Post subject: Reply with quote
AS SUSPECTED! A couple of turns on the clutch lever adjuster did the trick. I unscrewed it to put a new lever on and didn't put it back in EXACTLY the same place. Thanks all! Twisted Evil
The last post was made 13 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 62.2 Kb
