| el_oso |
 el_oso World Chat Champion
| Crazyd943 |
 Crazyd943 Two Stroke Sniffer
| Walloper |
 Walloper Super Spammer
| Taught2BCauti... |
 Posted: 23:40 - 06 Mar 2012 Post subject: |
Sounds like someone changed the chain and rear sprocket, but forgot to do the front sprocket.
Shouldn't cause too many problems if you change the front sprocket now, and just keep an eye on the chain and rear sprocket until it settles-in.
Next time, change all three of them at the same time. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
 Posted: 00:20 - 07 Mar 2012 Post subject: |
While it is best to replace a full set at once (as said, the new bits will rapidly wear to match the old bits), if the expensive chain and the rear sprocket are OK while the cheap front sprocket is worn out if you put on a new front sprocket all you will do is land up with the cheap front wearing a bit more quickly for a while.
So in your situation, being a tight git I would just swap the front sprocket. But double check the chain (make sure nobody has taken a couple of links out of the chain to disguise the wear).
Fronts being smaller suffer more wear, but to compensate are usually made from far harder steel.
| Walloper |
The last post was made 13 years, 319 days ago. Instead of replying here, would creating a new thread be more useful? |
